Old 08-08-2005
belyo belyo is offline
Newbie
belyo is on a distinguished road
Reel Mixing
There has been loads of information on this subject already, and some of it has helped, but not my specific situation, or i just didn't understand it. I'd like to keep my music analogue for as long as possible in the process. I have a Fostex R8, with board and i'd like to basically (all things being equal) to run all 8-tracks of a tape into a machine (re-set up everything downstairs) and concentrate on mixing old stuff when i don't fell like recording new stuff. Then, eventually output to CD. What, in the analogue realm, would best help me work that way?
thanks,
B
Old 08-08-2005
MadAudio's Avatar
MadAudio MadAudio is offline
Damned if I do
MadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond repute
You need a mixdown deck, typically a 1/4" 2-track machine that can run at 15ips.
Newest endeavor: Playing drums in a live band version of 7 Door Sedan's music.
"Do yourself a favour just shut up, read up then put up." --muttley600
Old 08-08-2005
Newbie
i'd like to be able to tranfer all 8-tracks analogue, so that after listening to it a month later, if i feel like this sound needs to be louder/softer, i don't have to stop what i'm doing, reload the old reels, find the song, and re-mix the whole thing. Sounds like i need another 8-track recorder of some kind, that isn't a reel-to-reel...
Old 08-08-2005
MadAudio's Avatar
Damned if I do
Hmm, I guess I'm not clear on what you want to do then.
Old 08-08-2005
Raw-Tracks Raw-Tracks is offline
Force of Nature
Raw-Tracks has a reputation beyond reputeRaw-Tracks has a reputation beyond reputeRaw-Tracks has a reputation beyond reputeRaw-Tracks has a reputation beyond reputeRaw-Tracks has a reputation beyond reputeRaw-Tracks has a reputation beyond reputeRaw-Tracks has a reputation beyond reputeRaw-Tracks has a reputation beyond reputeRaw-Tracks has a reputation beyond reputeRaw-Tracks has a reputation beyond reputeRaw-Tracks has a reputation beyond repute
I think if that's what you're after, you should dump all 8 tracks into a computer and mix the tracks on the computer. That way your mixes are fully recallable and can be accesses immediately.
Eric
Practice Your Mixing Skills!
Mix Our Tracks in Your DAW!
www.Raw-Tracks.com
Online Mixing Forum
Old 08-08-2005
Newbie
Raw-Rracks, do you know if there is a non-$600 dollar way to do that. i was checking out some of those m-audio things, and i may be able to get by with a 4/6-in, but i'd rather not limit myself...
Old 08-08-2005
MadAudio's Avatar
Damned if I do
Layla 3G maybe? What's your budget for an interface?
Old 08-08-2005
The Ghost of FM's Avatar
The Ghost of FM The Ghost of FM is offline
French Mofo
The Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond repute
It sounds like what you need is a mixer with total recall automation which can store exact fader, send and eq positions tied to a SMPTE time code system which moves the faders in real time to how you did your mixdown originally.
These systems offer a rehearsal, write and play mode to tweak your mixes now or 20 years from now when you wish to fine tune an old mix.
Companies like SSL, Neve, Trident and Sony Oxford offer systems like this starting for around $400,000.00 dollars.
Cheers!
Old 08-08-2005
Herm's Avatar
Herm Herm is offline
1K Silver Member
Herm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond repute
I think for what you want to do you could pick up the m audio delta 1010.
It will allow you to transfere 8 analog tracks into the computer and mix to you hearts content. But they do cost about 450.00.
Its about the cheapest way of doing what you want. plus the m audio stuff sounds pretty good. (For digital that is)
Old 08-08-2005
Force of Nature
I'm pretty sure that your Fostex has unbalanced -10db outputs. If that is the case, you could go with the M-Audio Delta-1010LT PCI card. That will give you the 8 anlaog inputs you require. It comes bundled with some software that will probably allow you do mix. I think you'll probably want to get some better software though. You should be able to pick the card up for about $200.
http://midiman.com/products/en_us/Delta1010LT-main.html
That's got to be the cheapest way to do what you want.
Eric
www.Raw-Tracks.com
Online Mixing Forum
Old 08-09-2005
jpmorris's Avatar
jpmorris jpmorris is online now
Tape Wolf
jpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond repute
Fostex made an 8-channel MIDI-controlled analogue mixer:
http://www.cassiel.com/gearhead/dcm100.html
..this might be what you're looking for. They turn up on ebay fairly regularly.
Whats The Point Of Mixing Anyway!! Raydio Mixing / Mastering 35 04-08-2005 19:25
Reel to Reel Baz97 Analog Only 5 06-03-2002 20:55
Reel to Reel JimJoe Analog Only 2 04-19-2002 03:04
Reel to Reel please help Axis Analog Only 9 04-14-2002 19:42
Cassette and Reel to Reel Recording Head Configurations? Ron Schilling Analog Only 4 01-12-2002 10:54
