Old 08-08-2005
EddieVergunst EddieVergunst is offline
Junior Member
EddieVergunst has a reputation beyond reputeEddieVergunst has a reputation beyond reputeEddieVergunst has a reputation beyond reputeEddieVergunst has a reputation beyond reputeEddieVergunst has a reputation beyond reputeEddieVergunst has a reputation beyond reputeEddieVergunst has a reputation beyond reputeEddieVergunst has a reputation beyond reputeEddieVergunst has a reputation beyond reputeEddieVergunst has a reputation beyond reputeEddieVergunst has a reputation beyond repute
Thumbs up Tascam 414 MKII 110/220V..
Hi,
I just bought a Tascam 414 MKII on eBay.. it went for 100$.. couldn't let that deal slip, seeing as they go for around 300$ new over here. Now maybe I should've thought twice about that.
It occured to me only later that off course the voltages in the US are different than in Europe. You use 110 while we use 220.
So..I'm not too informed as far as electronics and stuff goes, so my question is, will I be able to use the US power supply if I just buy one of those plug adapters (from flat US blades to round EU blades)? Or will I need a transformer of some kind (I really hope this is not the case).
Hope you guys can help me out.
Thanks
Old 08-08-2005
arjoll's Avatar
arjoll arjoll is offline
Force of Nature
arjoll has a reputation beyond reputearjoll has a reputation beyond reputearjoll has a reputation beyond reputearjoll has a reputation beyond reputearjoll has a reputation beyond reputearjoll has a reputation beyond reputearjoll has a reputation beyond reputearjoll has a reputation beyond reputearjoll has a reputation beyond reputearjoll has a reputation beyond reputearjoll has a reputation beyond repute
You will need a step-down or autotransformer to convert your 220 volts down to 120 volts. There's more info on it in this thread.
Your other option - and it is probably more economical - would be to replace the external power supply on this unit. Just get one with the same voltage and same or higher current rating (amps) and you should be right. Make sure that its the same type - either AC or DC - and if you're not sure take it into a reputable electronics store and they should be able to help you.
Cya
Andrew
Old 08-08-2005
Junior Member
Thanks for clearing that up for me.
Well, I do have a power supply here. Specs are: Input: 100-240V 17W 50/60Hz
Output: 3-12V 1000Ma
So I guess that would work right? The supplied power supplies' output is 12V 650Ma.
But how do I find out if it is AC or DC?
Old 08-08-2005
Junior Member
Ok, I found out that this is the adaptor I have:
http://www.digitekco.com/ad_tp.htm
So..it says AC/DC regulated. So I'm assuming this means I can safely use it with the 414?
Old 08-08-2005
A Reel Person's Avatar
A Reel Person A Reel Person is offline
It's Too Funky in Here!!!
A Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond repute
Arrow Yes!
It should also be (NEG)-tip and (POS)-sleeve, for the proper polarity.
The actual Tascam PS-P2 wallwart power supply is 12Vdc/500ma output.
Your replacement supply should be fine, as long as the polarity matches.
Many replacement wallwarts have switch selectable voltages and polarity.
I've also gotten [2] 414mkII's off Ebay recently, & at $85/ea. (total/delivered). At that price I think you (I) can hardly go wrong! Although I tend to favor high-end Porta's and larger systems, the 414mkII is a nice unit for the low bid price that I paid. So nice, that I got 2. I wasn't inclined to buy the 414mkII new/retail at $249, although I've bought (2) 424mkIII's new/retail at $329 & $279, respectively. Once I hit the $85/delivered pricepoint on the used 414mkII, it became a very attractive deal!
It makes me reminisce about the days of buying the brand new 244 retail for $1100, in 1982! Whew! Now I'm picking up 244's left and right for avg $70!
Beatles and other Classic Rock covers!! Yeah, Yeah, Yeah!!!
637 songs by 191 bands.
Tascam 414 Mk2 + preamps? kollontai77 Analog Only 5 03-08-2005 04:06
Tascam 414 receives no power ssb7171 TASCAM User Forum 3 10-01-2003 17:23
Tascam 424 MKII for sale half Free Ads for Music / Recording Equipment 0 04-25-2002 18:13
Can I connect my mic to a pre-amp then to my Tascam 414 MKII ?? xBodix TASCAM User Forum 6 04-11-2002 00:12
Tascam 414 mkii band recording Abbott TASCAM User Forum 3 01-25-2002 16:24
