Synchronizing tape and computer
Hi,
I'm sorry if this question has already been answered before... I would like to know, is there any software capable of synchronizing an analog tape with a computer? The tape would be playing along with a wav file synced together. Of course the sync signal coming from the software would be recorded on one of the tape's tracks first, and then played back in one of the soundcard's input to sync both together. Thanks, Me-Uzik |
The easy way is to have the tape deck as the master, and the computer as the slave. Sonar will accept a MIDI-borne sync signal and do its best to match the wave data against the tape. To make the magic happen, you need an external sync box. I use the Philip Rees TS-1, which I think is still being made. Tape to MIDI sync boxes are easy to find on ebay. To slave the deck to the computer, it gets a lot harder. You have to have a deck capable of accepting incoming sync signals (the Fostex R8 and Tascam TSR-8 can do this). Then you must also procure a sync unit by the manufacturer of the deck, the MTC-1 for Fostex, or various Tascam boxes (MMC100, MMC1000, ES50). Then you get the software to act as master. I have the equipment to do this, but I haven't yet tried it since the easy way (tape as master) is better for what I'm doing. *EDIT* in both cases, you record a sync tone (usually on the last track) generated by the sync box in record mode. Then you switch the box into replay mode, and it will generate a MIDI clock to drive the sequencer/audio software. |
Thanks.
It would be great if there was a software doing exactly what the sync box is doing to replace it, after all it's probably a signal that a software could reproduce I would think... Thanks again, Me-Uzik |
| Wilco's Jeff Tweedy on analog tape shortage | Bigsnake00 | Analog Only | 10 | 07-22-2005 18:48 |
| Analog Tape to Computer with Overdubs | themaddog | Analog Only | 3 | 02-04-2005 00:03 |
| FD-8 to Computer retrospective | pjenne | Fostex Forum | 0 | 01-07-2003 15:39 |
| decision making time: tape or computer? | phyglenaut | Digital Recording & Computers | 10 | 02-27-2002 01:35 |
| decision making time: tape or computer? | phyglenaut | Alesis Forum | 3 | 02-26-2002 19:17 |
