Old 08-07-2005
SKYflyer SKYflyer is offline
Senior Member
SKYflyer has a reputation beyond reputeSKYflyer has a reputation beyond reputeSKYflyer has a reputation beyond reputeSKYflyer has a reputation beyond reputeSKYflyer has a reputation beyond reputeSKYflyer has a reputation beyond reputeSKYflyer has a reputation beyond reputeSKYflyer has a reputation beyond reputeSKYflyer has a reputation beyond reputeSKYflyer has a reputation beyond reputeSKYflyer has a reputation beyond repute
PA vs Powered Mixer: Differences?
Is a powered mixer just a PA and a mixer combined?
So are the only differences that a powered mixer will have more inputs and the ability to do stuff like use equaliser settings, whereas a PA will only have a small amount of inputs?
Thus, having a PA and a mixer, one would have the equivalent to a powered mixer?
Are there any other perhaps hidden advantages or disadvantages to having a PA with a mixer vs having them combined as a powered mixer? (other than the mere convenience of having both devices as one)
Thanks.
EDIT: wait a minute... there must be more differences than i thought between a PA and a powered mixer. This quote further deepened my confusion: "The problem with buying a new PA head is that you need some kind of preamping between your keyboards and the amp. That will mean an additional expense unless you buy a 'powered mixer'."
Does this mean that powered mixers have some sort of preamping inside? I thought that the line level signals that were supposed to be inserted into powered mixers or PA's meant that they were already preamplified...
Old 08-07-2005
mr.rich mr.rich is offline
Senior Member
mr.rich will become famous soon enough
well a pa is just a name for all the peices put together to make a live system. your mixer, amps, speakers, outboard, monitors, mics... all add up to the pa. but a powered mixer just lumps the mixer and amp together in one thing.
that quote is pretty odd to me as well. i dunno why you would need an amp for somthing just to turn around and run it into another amp unless the signal was really damn weak. all actual console mixers should have a pre, this is your trim.
if your trying to build a small pa id say to get a small board, a couple amps, a couple wide range cabinets and a couple monitors.
mics>board>amp>speakers.
aux send>amp>monitors.
ive never really used a powered console live that sounded very good.
Old 08-07-2005
BadAE's Avatar
BadAE BadAE is offline
Senior Member
BadAE has a reputation beyond reputeBadAE has a reputation beyond reputeBadAE has a reputation beyond reputeBadAE has a reputation beyond reputeBadAE has a reputation beyond reputeBadAE has a reputation beyond reputeBadAE has a reputation beyond reputeBadAE has a reputation beyond reputeBadAE has a reputation beyond reputeBadAE has a reputation beyond reputeBadAE has a reputation beyond repute
PA nornaly means a set of FOH powered by an amp that is feed by a mixer.Thus, Mixer, power amp(s), and your FOH speakers.You may have other things in between your FOH and mixer, but this set up is the basic.
A powered mixer is a mixer that have a power amp bulit into it. All mixer have preamp and it need not be a powered mixer. Powered mixer are good only for indoor and small vanue. It is good for band practise where you dont need a lots of power: it basicly is use for vox and your keyboard. It have an advantage of compactness.
Old 08-07-2005
Senior Member
BadAE, you used the term "FOH" a lot in your post... what does "FOH" mean?
Old 08-07-2005
mshilarious's Avatar
mshilarious mshilarious is offline
Faithful Departed
mshilarious has disabled reputation
FOH is Front of House; it means the main speakers for the audience, as opposed to the monitors for the band.
Old 08-07-2005
AudioBond AudioBond is offline
Newbie
AudioBond is on a distinguished road
Yeah... I'm gonna hafta go ahead and second the opinion that a powered mixer isn't really the way to go... For small applications, they get the job done, but if you have even the slightest inkling of wanting to expand, you will only limit yourself... Get yourself a mixing console (doesn't hafta be a big one... you can find a lot of smaller, affordable ones out there...) a couple of power amps, some decent full range cabinets to start and try your best to work a graphic EQ into your budget! These things will save your neck! You'll prolly want a 1/3 octave EQ... that's pretty much the standard. Later on you may want to add a crossover and some subs, but that can be the "expansion" I mentioned earlier... this way you aren't locked into X number of inputs that are connected to a specific amp that you may outgrow sooner than you realize etc... you can get more/bigger cabinets, subs and crossover, better amps, a better/larger console etc... as your requirements grow. And yes... the basic setup would be Mics > Console > EQ > Power Amp(s) > Cabinets.
I may be WAY off on this part... but... I haven't run into too many powerd mixers that have inserts on them either... this is key for adding compressors/gates etc... More things that you may wish to add later down the line.
Hope this isn't too confusing! haha! Just let me know if it isn't clear and I hope it helps!
later!
-Chris
Attention Newbies: Copy and Save This For Reference!!! (Pt 2) Buck62 Newbies 12 04-25-2005 09:40
Difference between SEND and INSERT in cubase Gabriel Sousa Digital Recording & Computers 4 01-27-2003 12:48
help using the mixer together with the amp washburn10 Recording Techniques 0 02-09-2002 13:13
help mixer + amp washburn10 Digital Recording & Computers 0 02-09-2002 13:11
Is it possible to connect a powered mixer to a porta 02? toz71 TASCAM User Forum 1 01-18-2000 01:02
