Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 08-06-2005
Bonz Bonz is offline
Junior Member
Bonz will become famous soon enoughBonz will become famous soon enough
Opinions Wanted
Ok we're talking WinXP w/ 933Mhz P-III 512m Ram/ P4PA-UL Board with a 32MB e-geForge2 MX400 Graphics Card storing data on a 80g HD and using a 4g HD for system boot and Cubase SX Program.
I'm experiencing serious problems right now. With my projects containing audio, I'm getting serious flutter and hesitation during record & playback.
So I'm thinking the processor is weak and I need more. But as I search through the post, many others are running on 128m Ram with less than a 933Mhz Processor and I don't read these types of problems. I absolutely don't want to go out and buy anything to upgrade until I'm certain what the problem is.
I, basically record in 32bit Float ... don't know if I left anything out but I need some thoughts on what might be happening.
Anybody Please
Thanks Gang
Old 08-07-2005
Junior Member
Update
Well, I appreciate that noone at least posted replies that were insulting given that I really didn't wish to waste time sorting through bs and hopefully getting an answer.
As it turns out, the one important piece of hardware that I failed to mention in my original post was my soundcard. So, I did a google search for latency issue, given that even though I read the manual regarding this, I really didn't grasp the concept that well. As it turns out, I found a site that broke it down in terms that i could understand. Which led me to check my settings on my soundcard against what my Project Setup settings were. Whalla ... I found that I was recording at 32bit Float but my card settings were at 48.100 sample rate. So I re-adjusted some settings on the card and mapped them to what my preferences were and it appears I have solved my issue.
Old 08-07-2005
crankz1's Avatar
crankz1 crankz1 is offline
crankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond repute
Way to go .... good to hear you've sorted yourself out.
Providing your soundcard brand and drivers used can, sometimes, be a vital bit of info needed in diagnosing issues.
By the sound of your issue, I would have suspected buffer settings to be the culprit.
~It all works out in the end~
Old 08-07-2005
Junior Member
Thanks .. I'm using an M-Audio Delta- 66 card 4/ins 4/outs w/breakout box
secured to a PCI slot. Not sure if it's the best in town but it's what I bought when I was putting this workstation together. If anybody has thoughts on a better sound card please let me know ...
Old 08-07-2005
Atterion Atterion is offline
The Dark Knight
Atterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond repute
If it works for you then great. I have used Delta cards for several years now and have had no problems, or regrets.
Torment, Violent Aggression,
Systematic State of Oppression.
The Heretics, All Swing From The trees,
Cast To Hell, With Their Disease. DARKENED
Contraband - mix opinions wanted FattMusiek MP3 Mixing Clinic 3 07-08-2005 01:14
First try using a Bass PODxt, opinions wanted dabluesman MP3 Mixing Clinic 3 12-16-2003 10:53
Opinions wanted minusone Drums and Percussion 1 01-18-2002 16:24
Opinions wanted KaosDG MP3 Mixing Clinic 3 06-22-2001 15:27
Roland Boss ME-30 Opinions Wanted Lethal Other Equipment and Reviews 4 02-04-2000 08:16
