Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 08-04-2005
Nakatira's Avatar
Nakatira Nakatira is offline
That Norwegian Bastard
Nakatira has a reputation beyond reputeNakatira has a reputation beyond reputeNakatira has a reputation beyond reputeNakatira has a reputation beyond reputeNakatira has a reputation beyond reputeNakatira has a reputation beyond reputeNakatira has a reputation beyond reputeNakatira has a reputation beyond reputeNakatira has a reputation beyond reputeNakatira has a reputation beyond reputeNakatira has a reputation beyond repute
70`s drum recording; encountering problems.
I`ve been recording my old band now for a week and we`ve been trying to get that dead 70`s sound with removed bottom heads and proper muffling, most of those things are under control.
I`ve also tuned the kit down as low as possiple, the kit is a 14 snare 12,14,16 toms and ect. the toms are suited with pinstripe heads.
But the problem is that the heads keep on dropping in tune or getting out of tune, we have to tune them at least to times each day.
I thought it was ok the first day, as I thought it needed some time to settle in, but all the time is a bit to much.
any tips or clues to give an old 70`s prog drum freak.
Old 08-04-2005
Nakatira's Avatar
Sorry one more thing We play on a premier drumkit, wich is suposed to be good aint it, at least it was priced that way.
Old 08-04-2005
cobradenim's Avatar
cobradenim cobradenim is offline
Senior Member
cobradenim has a reputation beyond reputecobradenim has a reputation beyond reputecobradenim has a reputation beyond reputecobradenim has a reputation beyond reputecobradenim has a reputation beyond reputecobradenim has a reputation beyond reputecobradenim has a reputation beyond reputecobradenim has a reputation beyond reputecobradenim has a reputation beyond reputecobradenim has a reputation beyond reputecobradenim has a reputation beyond repute
Tune the drums higher.
Old 08-04-2005
Nakatira's Avatar
I was thinking about that but then I have to sacrefice the killer sound of the low pitched drums.
but anyway thanks for replying
Old 08-04-2005
cobradenim's Avatar
Senior Member
Just a little bit at a time until you get a happy medium.
Old 08-04-2005
tilinmyowngrave tilinmyowngrave is offline
Force of Nature
tilinmyowngrave has a reputation beyond reputetilinmyowngrave has a reputation beyond reputetilinmyowngrave has a reputation beyond reputetilinmyowngrave has a reputation beyond reputetilinmyowngrave has a reputation beyond reputetilinmyowngrave has a reputation beyond reputetilinmyowngrave has a reputation beyond reputetilinmyowngrave has a reputation beyond reputetilinmyowngrave has a reputation beyond reputetilinmyowngrave has a reputation beyond reputetilinmyowngrave has a reputation beyond repute
Um... I know this is easier said than done but... Get bigger toms. Those help.
"However Simon thought of the beast, there rose before his inward sight the picture of a human at once heroic and sick."- Lord of the Flies
Old 08-05-2005
drummerdude666's Avatar
drummerdude666 drummerdude666 is offline
immature
drummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond repute
To stop the tuning changing then buy some things that stop it from changing it.
They are little plastic things that sit on the lugs and stop it from turning. Sorry i can't be more desciptive. I'll try and find a ink for you later tonight.
Ever notice that people labelled eccentric are usually geniuses?
Old 08-05-2005
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
Put the tom mics up inside the drums. Use 421s if you can. Floor toms in the 70s tended to have bottom heads. You must also be in a really dead room.
As far as tuning goes, tuning a drumset twice a day when they are being played constantly isn't that bad. Remember, if the room isn't huge, the heat and sweat that the drummer produces changes the temperature and humidity of the room. Changes in temp and humidity will affect the drum tuning.
Everything is fine, just keep tuning the drums.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 08-05-2005
Nakatira's Avatar
Thanks for the help guys, I`ll try miking with the mike inside the drum that sounded intresting.
Anyway tuning the drums two times a day made me better at tuning drums, so something good came out of it, and offcourse the sound it self is worth it, but as I`m not a drummer I just wanted to see if there was a trick I was missing out on.
Would apreciate a link to the stuff you were talikng about drummer dude.
Old 08-05-2005
my2cents my2cents is offline
Senior Member
my2cents will become famous soon enough
Lug Locks. I can't vouch for their effectiveness.
Old 08-05-2005
MadAudio's Avatar
MadAudio MadAudio is offline
Damned if I do
MadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond repute
I can. They work. And they look like little squares of plastic with a hole in the middle.
Newest endeavor: Playing drums in a live band version of 7 Door Sedan's music.
"Do yourself a favour just shut up, read up then put up." --muttley600
  #12
Old 08-05-2005
Senior Member
what '70s drum sound are you going for? what recordings are good examples of the sound you're trying to achieve?
  #13
Old 08-05-2005
lilblakdak's Avatar
lilblakdak lilblakdak is offline
Newbie
lilblakdak is on a distinguished road
Ditch the pinstripes, and get some blackdots. Then mike like Farview said. Then if you still hae too much ring, get out the toiletpaper and duct tape.
You expected some witty comment didnt you?
  #14
Old 08-05-2005
Nakatira's Avatar
I`m gonna check out thoose Lug Locks "thanks for the help guys".
I`ve never tried blackdots, but I will give those a shot.
the sound were going for is, quite close to prog acts such as camel, jethro tull and early king crimson (court of the krimson king, wake of posseidion).
really dark and dry sound, that sort of hits you in the face quite "modestly"
but again thanks for the replies guys your all a tremendous help.
  #15
Old 08-05-2005
Tim Brown's Avatar
Tim Brown Tim Brown is offline
Why 2K?
Tim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond repute
Blackdots are going to give you a boxy type of sound.
Then what you want is Evan's oilheads. They do one thing, and they do it well - That 70's "Thuddy" kind of studio drum sound.
Also, let me turn you onto a killer prog act from back then.
Gnidrolog
They are quickly becoming a favorite for me.
Tim
  #16
Old 08-05-2005
White_Rabbit's Avatar
White_Rabbit White_Rabbit is offline
Newbie
White_Rabbit is on a distinguished road
How strange, only last night I was lying in bed listening ever-so-intently to In The Court Of The Crimson King, thinking about how awesome the drums sounded back then, considering posting here asking for tips on how to get such a sound, only to wake up this morning to find a thread on the front page all about it, this site rules!
Reality is perception, belief is deception.
  #17
Old 08-05-2005
lilblakdak's Avatar
Newbie
The reason I suggested blackdots is that almost everyone used them in late 70's early 80's from Bonham and Paice to Alex Van Halen and Peter Criss.
  #18
Old 08-05-2005
msmales555's Avatar
msmales555 msmales555 is offline
Senior Member
msmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond repute
Synchronicity!
  #19
Old 08-05-2005
Nakatira's Avatar
That album really kicks ass, I just love the way it starts with 21ct scizoid man.
They sure could swing those drum sticks back then.
Will check out Gnidrolog, I`ve heard about them but never got around to give em` a listen.
and thanks for the advice about the evans oilskin will check them out as well.
we just finnished our last drum track today, so I will post a link in the near future if anyone is intrested.
thanks for the input everyone.
  #20
Old 08-06-2005
ez_willis's Avatar
ez_willis ez_willis is offline
Virtual Ninja
ez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond repute
Are the heads seated on the drum properly?
Originally Posted by 60's guy View Post
You win.
  #21
Old 08-06-2005
immature
I can't find a link anywhere for the Lug Locks. Sorry.
But they DO work, so get down your local music store and get them to find you some
  #22
Old 08-06-2005
Nakatira's Avatar
Yeah I do think so, I had a friend over who`s been playing for years to put them on and do the intial tuning, after that I went on with tuning em down as far as I could and lots of muffling.
I`m sure I`ll get a hold of thos lug locks, thanks for trying drummerdude.
keep up the good work guys.
Can I get advice from those who have a home studio? Chrisku13 Studio Building & Display 56 08-21-2006 23:20
First drum recording advice? VesuviusJay Drums and Percussion 12 03-25-2003 23:25
Drum recording advice? VesuviusJay Recording Techniques 33 03-20-2003 21:53
9 Drum Tracks in Two Days... remote drum recording... Blue Bear Sound Recording Techniques 58 03-01-2002 07:15
Drum Machine/ Drum Pad for Recording swingandstrings Drums and Percussion 2 12-21-2001 06:40
