Old 08-02-2005
cjacek's Avatar
cjacek cjacek is offline
Analogue Enthusiast
cjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond repute
Question Doing a full alignment ...
A full alignment for my TEAC 3440 costs about $200.00 CND plus taxes in the area where I live. If it would be my only recorder then I'd surely pay the price for someone to do it but I have several that may need to be brought up to spec, perhaps not now but one day. At least this should be done. My question is: Is it at all feasable to do this by oneself ? Where do I begin ? What would be the overhead for the equipment I'd need ? Is it really tough to do or is there info where I can learn how step by step .. ?
Thanks!
Daniel
Old 08-02-2005
evm1024's Avatar
evm1024 evm1024 is offline
1K Silver Member
evm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond repute
Not bad
Thanks!
Daniel
That is not a bad price for doing the service work. The thing that you will need that is out of the ordinary is a scope for azimuth alignment. You will need a MRL tape and a signal generator (you can use your notebook for signal generation using free software and the sound card).
You should have some scales as well (fish scales work) if you want to do the motor torque which does help mantain the tape to head contact.
My first 3440 alignment took me about 4 hours. It is well worth your effort to learn to do this.
The scope just needs to do x-y with audio bandwidth so it can be an older model. Some are available for less than $100.
I use a 200 nWb/M MRL tape that I happen to have. Using this tape and setting the levels to read -2 Vu sets the tape for 250 nWb/M at 0VU which is the recommended level for Ampex 456. I tried to set it for 320 nWb/M but did not have the adjustment range on my deck. This would be the norm for 499. With some component changes you could set it for "standard" 499. But whoi wants to? BY setting to 456 and using 499 you could record at 0 VU and have extended headroom or record at +3 VU and have a lower noise floor.
Feel free to send me questions. If I don't know them off the top of my head I can put my 3440 on the bench and take a look.
Regards
In Sunny Vancouver ..... (Washington)
Old 08-02-2005
cjacek's Avatar
Analogue Enthusiast
Regards
Thanks a lot my friend! I'll definitely ask more should the need arise.
~Daniel
Old 08-02-2005
The Ghost of FM's Avatar
The Ghost of FM The Ghost of FM is offline
French Mofo
The Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond repute
I used to ponder the same thought, Daniel, about doing my own calibrations on my MS-16 and then when I added up the price of the calibration tape, scope and other test gear, it just didn't make financial sense when I could get my technician to come over to the house for a couple of hundred and let him do it once every few years.
Perhaps, for a 1/4" machine, the price gap gets smaller so you might still consider going the full DIY route but for 1" machines like mine, I happily leave it to the pros.
Cheers!
Old 08-02-2005
evm1024's Avatar
1K Silver Member
forgot the multimeter
Forgot to say a 3 or 4 digit multimeter for reading voltage levels.
Regards
Old 08-02-2005
snipeguy's Avatar
snipeguy snipeguy is offline
Andy Goldsworthy Wannabe
snipeguy has a reputation beyond reputesnipeguy has a reputation beyond reputesnipeguy has a reputation beyond reputesnipeguy has a reputation beyond reputesnipeguy has a reputation beyond reputesnipeguy has a reputation beyond reputesnipeguy has a reputation beyond reputesnipeguy has a reputation beyond reputesnipeguy has a reputation beyond reputesnipeguy has a reputation beyond reputesnipeguy has a reputation beyond repute
Originally Posted by The Ghost of FM
.....when I could get my technician to come over to the house for a couple of hundred and let him do it once every few years.
Cheers!
Ghost,
Would this technician be willing to come to Guelph to do a Otari 8 track? and maybe my 2 track Revox as well.
Quite frankly, I'd rather just go sailing.
http://www.myspace.com/harripalm
Old 08-02-2005
French Mofo
Originally Posted by snipeguy
Ghost,
Here's their contact info;
http://www.tele-tech.ca/addinfo.html
Patrick is the technician.
Cheers!
Old 08-03-2005
Blackdog.sn's Avatar
Blackdog.sn Blackdog.sn is offline
Junior Member
Blackdog.sn is on a distinguished road
Cheers!
Man Tele-tech is expensive. The service guy charges $90/hour. Wont be getting my M-35 repaired for a while
Old 08-03-2005
Beck's Avatar
Beck Beck is offline
Analog Partisan Ranger
Beck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond repute
Stuff I use for aligning tape reel-to-reel decks:
Winscope
Freeware oscilloscope for Windows.
I’ve installed it on Win 98, and XP using compatibility mode install.
http://polly.phys.msu.su/~zeld/oscill.html
Operation/Maintenance Manual for Deck
TEAC E-3 Head Demagnetizer
Fostex TT-15 Test Tone Oscillator
MRL Calibration Tapes http://home.flash.net/~mrltapes/
Radio Shack Digital Multimeter, Model 22-811
http://www.radioshack.com/product.as...%5Fid=22%2D811
Some good links:
Spring Scales:
http://www.sciencelab.com/page/S/CTGY/20846
How-to and info:
http://www.recordingwebsite.com/articles/tapecal.php
http://audio.utac.net/pg/tape/align.html
http://www.barryrudolph.com/greg/align.html
http://home.swipnet.se/herbalifeinfo/Audio/engRULL2.htm
http://www9.dw-world.de/rtc/infotheq...ng/magrec.html
More calibration tape info (nice chart)
http://www.tangible-technology.com/m.../mrltapes.html
-Tim
«:: «::B::» «::E::» «::C::» «::K::» ::»
"Where in the hell are the red M&M's?"
~My Lil' Sister, 1976
Old 08-03-2005
cjacek's Avatar
Analogue Enthusiast
Winscope
Some good links:
Spring Scales:
How-to and info:
-Tim
Man, Tim! How can I even begin to thank you for printing all this out and finding all those links ?? Thank you so much my friend! I do have a lot of reading ahead of me, don't I ?
Thanks again!
Daniel
Old 08-03-2005
cjacek's Avatar
Analogue Enthusiast
Cheers!
Perhaps letting someone else service it instead would be a definite plus, at least a real time saver but then again it would be nice to know all this shit, wouldn't it ? Thanks for the input Jeff.
Daniel
  #12
Old 08-03-2005
cjacek's Avatar
Analogue Enthusiast
Thanks again guys!
~Daniel
  #13
Old 08-03-2005
mr.rich mr.rich is offline
Senior Member
mr.rich will become famous soon enough
id say get a tech to to major calibrations ( motor tension, card adjusts, head shit) but buy yourself an mrl and learn to bias and adjust rec playback lvs. this will give you a great insight into whats going on with your deck, will give you the abilty to over bias certain freqs for differant types of stuff and speed settings and those are things you should be doing before every session. a tape machine can sometimes shift bias by just being turned off and on. its wierd.
  #14
Old 08-04-2005
cjacek's Avatar
Analogue Enthusiast
Actually that's great advice. Thanks! Yeah, that will allow me to change tapes as I please without having to shell out big bucks each time I feel like biasing to another tape ... Plus, I think that's also the simpliest way to start getting to know all of this stuff. Thanks.
Daniel
**Making Your Beats Full Sounding??? Raydio DJ & Hip Hop Production 43 07-28-2005 05:52
buying XP Home full version oem beezelbubba Digital Recording & Computers 42 01-09-2005 05:29
Any Full Sail Graduates RD423 Mixing / Mastering 11 10-22-2004 20:36
MR-8 Card Full! sungardn Fostex Forum 7 05-05-2004 07:05
Full disk 'Error=64' vf160 glynb Fostex Forum 2 02-12-2004 07:32
