Old 08-02-2005
tuggy's Avatar
tuggy tuggy is offline
Newbie
tuggy is on a distinguished road
newbie here!
hi,
i'm just inside of this "home recording" stuff.. and want to dig more into it. i've got a yamaha p-250 stage piano, guitars, basses.. etc. i know i need a good soundcard (at least better than my on-board sound card . i decided to but m-audio audiophile 2496. i want to record audio and use some softsynths. is 2496 ok for all these? and what else do i need ? (preamp you may say, but i don't know what preamp does )
"face the storm"
Old 08-02-2005
Fieva's Avatar
Fieva Fieva is offline
myspace.com/fieva
Fieva has a reputation beyond reputeFieva has a reputation beyond reputeFieva has a reputation beyond reputeFieva has a reputation beyond reputeFieva has a reputation beyond reputeFieva has a reputation beyond reputeFieva has a reputation beyond reputeFieva has a reputation beyond reputeFieva has a reputation beyond reputeFieva has a reputation beyond reputeFieva has a reputation beyond repute
Originally Posted by tuggy
hi,
A preamp boosts the signal from your mic so that your soundcard or mixer can get the signal and it can be recorded.
Heavyhitta Beats
Hustle Magic
Old 08-02-2005
guitarboi89 guitarboi89 is offline
Dedicated Member
guitarboi89 has a reputation beyond reputeguitarboi89 has a reputation beyond reputeguitarboi89 has a reputation beyond reputeguitarboi89 has a reputation beyond reputeguitarboi89 has a reputation beyond reputeguitarboi89 has a reputation beyond reputeguitarboi89 has a reputation beyond reputeguitarboi89 has a reputation beyond reputeguitarboi89 has a reputation beyond reputeguitarboi89 has a reputation beyond reputeguitarboi89 has a reputation beyond repute
okay a preamp basically takes the electrical signal from a microphone or elec guitar and boosts it so it can be recorded
Old 08-02-2005
fraserhutch's Avatar
fraserhutch fraserhutch is offline
Flypaper for freaks
fraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond repute
newbie here
Abuse is just down the hall
Seriously, welcome.
The fact that no one understands you doesn't mean you're an artist...
Old 08-02-2005
tuggy's Avatar
Newbie
hmm what happens if i just plug my guitar and try to record audio ?
and what else do i need?
(btw. thanks fraserhutch)
"face the storm"
Old 08-02-2005
tuggy's Avatar
Newbie
in fact, what i want to do is pretty simple (not for me, but most of you ). i want to record audio and use softsynths, and sequence them in a program like cubase.
"face the storm"
Old 08-02-2005
Fieva's Avatar
myspace.com/fieva
If you recorded your guitar only (with no amp or preamp), you might get a weak signal or no signal at all. I go from my mic (or in your case mic and instruments) to my preamp, then from the preamp to a hardware compressor, compressor to mixer, mixer to soundcard. For cubase if you use a midi controller or a keyboard with midi capability if you want softsynths or instrument plugins.
Heavyhitta Beats
Hustle Magic
Old 08-02-2005
tuggy's Avatar
Newbie
so, i've got a guitar, an amp, a soundcard and a computer running a sequencer program. what else do i need ?
"face the storm"
Old 08-02-2005
Fieva's Avatar
myspace.com/fieva
a midi controller for softsynths, monitors are good too (i need some my damn self...i had to tweak my speakers to make them flat), while your at it go get all the free plugins you can....you never know when one might do the job for you.
Heavyhitta Beats
Hustle Magic
Old 08-02-2005
tuggy's Avatar
Newbie
i have a stage piano with speakers, so i'm planning to use them for monitoring. i'll use it for midi controlling, too.. what do you mean by plug ins ?
"face the storm"
Old 08-02-2005
Fieva's Avatar
myspace.com/fieva
a plug in is extra software that can be used in programs such as cubase, n-track, acid, sonar...etc. it's usually in .dll format and has to be placed in the vst folder of whatever software you're going to use. If you want to see some plugins check www.kvr-vst.com for more info and some downloads.
Heavyhitta Beats
Hustle Magic
  #12
Old 08-02-2005
Kevin Deschwazi's Avatar
Kevin Deschwazi Kevin Deschwazi is offline
Brittunculus
Kevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond repute
welcome to the BBS.
It sounds horrible!
If you must go direct (micing the amp is the best option, or the instrument if it's an acoustic) then you need a direct injection box. A guitar pickup will output an unbalanced signal at a very low level, the DI will balance the signal and raise it to a useable level.
You can get DI boxes which do nothing but serve this one purpose but it's probably better to get a microphone preamp which also has DI (or 'instrument') input/s. That way you'll be able to use it with mics as well. (As has been said the mic pre will take the weak 'mic level' signal and boost it to 'line level' suitable for recording). If you want a good budget recommendation the M Audio DMP-3 is a good dual channel mic pre with DI inputs.
Or you could use one of those amp modeller/pod things. Like I said nothing beats micing the amp or instrument though. Having said that you can get a decent bass guitar sound by going direct although I'm sure there are some who would disagree with me there.
So how many tracks are you wanting to record at once and what is your budget? The 2496 is a decent entry level card but you will only be able to record two mono sources simultaneously (or one stereo) with that card.
  #13
Old 08-02-2005
Fieva's Avatar
myspace.com/fieva
Originally Posted by Kevin DeSchwazi
welcome to the BBS.
It sounds horrible!
You can get DI boxes which do nothing but serve this one purpose but it's probably better to get a microphone preamp which also has DI (or 'instrument') input/s. That way you'll be able to use it with mics as well. (As has been said the mic pre will take the weak 'mic level' signal and boost it to 'line level' suitable for recording. If you want a good budget recommendation the M Audio DMP-3 is a good dual channel mic pre with DI inputs.
I'd listen to Kevin on this one. I know a little about amping and micing guitars to get you in the right direction, but Kevin seems more knowledgable than myself on this part. Hey Kevin, what type of music do you record and what's your setup?
Heavyhitta Beats
Hustle Magic
  #14
Old 08-02-2005
tuggy's Avatar
Newbie
thanks kevin.
i'm planning to use only one source at once. hmm, i heard about DI boxes before..
my budget allows me to buy only the soundcard now, so it seems like i'll be messing with VST's for a while
"face the storm"
  #15
Old 08-02-2005
Fieva's Avatar
myspace.com/fieva
kvr does have quite a bit of freeware plugins to get you started. Which sequencer are you using?
Heavyhitta Beats
Hustle Magic
  #16
Old 08-02-2005
Brittunculus
I record all sorts of stuff but mainly acoustic guitar music at the moment because that's what i write and play myself. I'm just a hobbyist so i only really record friends for favours and I seem to be moving in acousticy singer/songwriter circles at the moment.
My set up is very humble, prosumer stuff. TL Audio, DMP-3, VTB-1 and Electro harmonix 12AY7 preamps. Several mics by MXL, Studio projects, Audio technica et al. A M Audio 1010LT soundcard and a P4 windows PC running cubase SE.
My lava lamp is aquamarine
I'll be putting some stuff up on soundclick soon so keep 'em peeled.
  #17
Old 08-02-2005
tuggy's Avatar
Newbie
cubase.. i was looking for some freeware plu ins, kvr will help a lot, thanks fieva
"face the storm"
  #18
Old 08-02-2005
Brittunculus
kvr is a great site but here are a few of my favourites to get you started:
http://www.kjaerhusaudio.com/classic-series.php
http://www.digitalfishphones.com/mai...em=2&subItem=5
10 Newbiest Newbie MOTIF Questions the learninator Keyboards and Sound Modules 1 08-02-2004 20:16
Newbie FAQ Jotosuds Newbies 4 02-03-2004 08:20
Gear question....newbie to newbie... Michaelyu5 Newbies 16 01-15-2004 19:16
