Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 08-02-2005
Garry Sharp's Avatar
Garry Sharp Garry Sharp is offline
Lost Cause
Garry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond repute
Weird signal recognition problem
I use Cubase SE and an EMU 0404 card. All works great (by my standards anyhow)
Yesterday I bought a new pre (an SPL Goldmike) that has both 1/4" and XLR outputs. I also got an XLR to 1/4" TS adapter cable, thinking I would use the XLR out.
When I did this, the soundcard picked up the signal fine (I monitor direct off the card). But when I armed a Cubase audio track for recording, it didn't "see" the signal. When I switched to using a plain 1/4" lead off the pre, it recorded fine, so there are no issues with the 0404's settings, it seems. Is there something about how the XLR / 1/4" cable would be wired that means that though the soundcard recognises the signal, Cubase doesn't? Very strange.
It doesn't really matter because the EMU's inputs are unbalanced anyway, I am not losing anything by using the straight 1/4" out from the pre, I just wondered....
Couple of our songs on Mixposure here
Old 08-02-2005
Atterion Atterion is offline
The Dark Knight
Atterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond repute
Is there any way you could check to see if the XLR outs on the Pre are working (XLR out to XLR in on a mixer for example). You never know, you might have a faulty unit???
Torment, Violent Aggression,
Systematic State of Oppression.
The Heretics, All Swing From The trees,
Cast To Hell, With Their Disease. DARKENED
Old 08-02-2005
Lost Cause
They were working because the soundcard picked up the signal quite happily, I heard it through my monitors and saw the levels on the EMU control panel. Just Cubase didn't get it.
Old 08-03-2005
The Dark Knight
Well, provided you plugged both sets of cables into the same physical inputs on your Emu and got signals in your hardware both times, I'm stumped!?!?!? You did use the same inputs both times right???
Old 08-03-2005
Lost Cause
Yes, I did. Strange isn't it? And when I used the XLR DI out from my bass amp in the same way - it recorded perfectly!!
Old 08-03-2005
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
Did you try it again to see if it happened again?
Start with the cable that worked, put it in record and record for a little bit. Then, while still recording, change the cable out and continue to play. If it still doesn't recognize the one cable, your system is haunted. Call a priest.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 08-03-2005
The Dark Knight
And if he is using that same computer to post these questions, our computers may become possessed as well. AAAARRRRGGGGHHHH!!!!!
Old 08-03-2005
Lost Cause
Well I am sorry Farview and Atterion - you are both doomed Possessed it is. Anyway, I just got a good vocal take off the 1/4" so I don't care anymore....
Now, how can I get this ghost to find the "make it sound great" button....
Old 08-03-2005
The Dark Knight
Threaten it with exorcism.
Old 08-04-2005
Lost Cause
No need. It said it was leaving to solve the Mid East problem, which was less challenging than making my stuff sound good
Old 08-07-2005
The Dark Knight
Oh, it's that bad????
Weird problem, help please P Hallin Digital Recording & Computers 13 01-27-2005 12:45
weird phase problem BrettB Digital Recording & Computers 3 04-16-2003 21:47
