Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 08-01-2005
ColdAsh ColdAsh is offline
Dedicated Member
ColdAsh is an unknown quantity at this point
Cubase only recognising 2 inputs on delta 66
http://homerecording.com/bbs/showthread.php?t=164865
I know its kind of a double post but I doesnt seem to be getting any responses in the Computer Recording section so I thought some Cubase users might be able to give me some insite on the situation
Old 08-02-2005
hueseph's Avatar
hueseph hueseph is offline
Dedicated Member
hueseph has a reputation beyond reputehueseph has a reputation beyond reputehueseph has a reputation beyond reputehueseph has a reputation beyond reputehueseph has a reputation beyond reputehueseph has a reputation beyond reputehueseph has a reputation beyond reputehueseph has a reputation beyond reputehueseph has a reputation beyond reputehueseph has a reputation beyond reputehueseph has a reputation beyond repute
Have you enabled the vst inputs? In VST5.01 it's under the Panels drop down menu. In newer version like SX, SE or SL, I believe it's in the devices menu. At any rate you need to enable these inputs before you can make use of them. Othere things to check, make sure you are using the correct ASIO and not microslop mapper or something to that effect.
All is vanity and a striving after the wind.
Old 08-02-2005
Dedicated Member
Yeah i knew that. The problem is that only inputs 1 and 2 show up in the device menue and in the preferences menue (or setting, whatever it is). And I'm definately using ASIO drivers
Old 08-02-2005
Carter's Avatar
Carter Carter is offline
Total gear slut
Carter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond repute
I would pull the card out and reinstall including the drivers.
Carter
MCF Productions
Old 08-02-2005
Atterion Atterion is offline
The Dark Knight
Atterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond repute
If you only have 2 inputs enabled than that is all you will see. At the top of the "VST Connections" window click the "add" button, which should bring up a selection of all available hardware inputs and outputs. Select what you want, give it a name, and you should be good to go.
Note: you can use the same inputs over again. i.e. you can set up 2 stereo input pairs from your Delta-66 (Named like Stereo In 1/2 and 3/4 for example). And also setup 4 individual Mono inputs for each of the hardware inputs. Now you'll have 6 total input faders in your mixer, and added flexability. (I'm just referring to your Analog I/O, you could add more via S/PDIF).
If this don't help then you should definitely try reinstalling your hardware (And get the latest driver's from M-Audio, the ones that came with my Delta-44 didn't work with certain programs either until I updated them).
Torment, Violent Aggression,
Systematic State of Oppression.
The Heretics, All Swing From The trees,
Cast To Hell, With Their Disease. DARKENED
Inputs 1&2 On Delta 1010LT punkin Digital Recording & Computers 6 01-14-2005 13:59
Delta 44 / Cubase Recording/Playback/Mixdown Help! kpnutz52 Digital Recording & Computers 2 06-28-2004 07:51
Cubase 2, Delta 1010LT, input levels very low ticker Cubase User Forum 0 06-09-2004 15:04
Cubase (and others) doesn't like my Delta soundcard... ?? Bigus Dickus Digital Recording & Computers 0 12-12-2002 13:22
Mac, Cubase, Delta 1010, JBl advice framos Newbies 2 04-28-2002 20:22
