Go Back   Home Recording > Equipment Forums > MIDI Mania
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 07-31-2005
c7sus's Avatar
c7sus c7sus is offline
Disenfranchised Member
c7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond repute
Fruity Loops Demo
I got this yesterday, and can't get my JV1010 to respond to it.
I'm getting MIDI through my Midisport2x2, but nothing seems to pass through to the Roland.
So last night I was using the audio to audition drums.
The snares sound like a screendoor slamming, and there wasn't a single kick drum that was useable at all. Same with all the toms. EVERYTHING distorted! I checked gain levels and they seem okay, but the sounds out of this are awful.
Anyway, I'm sure I'm doing something wrong, but I gotta say I'd be pissed as hell if I paid $150 for this.
Old 08-01-2005
Phyl's Avatar
Phyl Phyl is offline
Master of the Obvious
Phyl is a splendid one to beholdPhyl is a splendid one to beholdPhyl is a splendid one to beholdPhyl is a splendid one to beholdPhyl is a splendid one to beholdPhyl is a splendid one to beholdPhyl is a splendid one to behold
Check to see which midi channel you're sending the info on, then go into the Roland sys info settings to see which channel it's set to receive midi on.
My Roland XV5050 defaults to receiving MIDI on channel one.
Old 08-02-2005
ssscientist's Avatar
ssscientist ssscientist is offline
Info you can use...
ssscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond repute
My FL plays back just fine.
Maybe you've got some kind of distortion as a master effect. Try opening up a new song and programming a simple drum beat with no effects...
I'm not sure what you mean by 'can't get my JV1010 to respond to it'. If you're expecting FL to be configured to play the drum kit from your JV you'll need to do a little setup work.
First, under the Options menu you'll find an 'enable midi output' option. Check this. Then go to the Channels menu and the first item will be 'add one'. This will bring up a list - choose 'midi out'. You'll want to set the channel to 10, then use the keyboard to choose a sound. If you want to keep your sounds on separate channels (kick, snare, etc.) just create more midi outs and rename them.
Fruity Loops Demo get2sammyb MIDI Mania 2 06-21-2005 23:28
Fruity Loops Demo Zona Mona Newbies 3 08-05-2004 23:38
fruity loops as a vst wrapper postalblue Cakewalk / Sonar Forum 2 01-30-2003 08:07
Making 'real' drums in Fruity Loops. Meshuggah Recording Techniques 11 11-11-2002 13:01
fruity loops demo help? PKTrain Drums and Percussion 0 08-21-2002 20:53
