Go Back   Home Recording > User Forums by Brand > Cool Edit Pro / Adobe Audition Forum
Reply    Audiofanzine Music-software Music-software News Music-software Medias Music-software Tests Music-software Articles Music-software User Reviews Music-software Classifieds Ads
Old 07-30-2005
FattMusiek's Avatar
FattMusiek FattMusiek is offline
hates cables.
FattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond repute
Can I add plugins that end with .dll into Audition?
I used Cool Edit Pro 2.0 for years and recently upgraded to Adobe Audition. I know that "Refresh Effects List" in Edit Waveform view will update plugins that were installed on your computer. I downloaded some seemingly nice plugins in .zip form and extracted them into the "vstplugins" folder in the Adobe directory but they still don't show up. In these .zip files are two files; one is a .dat and one is a .dll. My question is are these even compatible with Audition? And if so, how can I make them show up as usable plugins?
Listen to my songs at:
http://www.nowhereradio.com/artists/...y.php?aid=2076
The purpose of a cable is to get stuck under everything in its path.
Old 07-31-2005
ozpeter ozpeter is offline
Dedicated Member
ozpeter is on a distinguished road
Audition 1.5 supports VST plugins - well, most - but not VSTi instruments. You can create your own VST folder and add it to the list of those that Audition scans, if you wish. Unsupported plugins will often appear in the 'unsupported' list, but not always.
What plugins are you trying to use?
Old 07-31-2005
FattMusiek's Avatar
hates cables.
These are the plugins I tried downloading:
http://www.stormrecordingstudio.co.uk/VST.htm
Where do I create the VST folder? Also, where is the unsupported list? Thanks for your help.
Old 08-01-2005
Wireneck's Avatar
Wireneck Wireneck is offline
Fretboard Acrobat
Wireneck has a reputation beyond reputeWireneck has a reputation beyond reputeWireneck has a reputation beyond reputeWireneck has a reputation beyond reputeWireneck has a reputation beyond reputeWireneck has a reputation beyond reputeWireneck has a reputation beyond reputeWireneck has a reputation beyond reputeWireneck has a reputation beyond reputeWireneck has a reputation beyond reputeWireneck has a reputation beyond repute
You can create the VST folder anywhere on your hard drive. When you go into the effects list there is an option that says something like "add VST directory", then you just browse and find your folder, then it will ask you to refresh your effects list. The "unsupported" list should be somewhere in the effects menu. Usually VSTi will show up here if you have them installed.
Old 08-02-2005
Dedicated Member
I tried the "Exciter" effect and found that it appeared in Audition under the name of "Container - Synthedit" - and it failed to work (or so it seemed). I believe that's not uncommon with Synthedit-created effects and Audition.
Old 08-02-2005
thajeremy's Avatar
thajeremy thajeremy is offline
registered abuser
thajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond repute
I was unable to get any of them to work....
Lyrical critique: A Means to an End Strat Man Songwriting, Singing & Vocals 1 05-10-2005 06:51
Does guitars low end and Bass low end tend to fight for the same low end? videodrone Recording Techniques 15 04-28-2003 13:48
High end Sparkle? Stratomaster Mixing / Mastering 5 06-30-2002 00:33
