Old 07-29-2005
cjacek's Avatar
cjacek cjacek is offline
Analogue Enthusiast
cjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond repute
Question TEAC RC-70 remote OK for TASCAM 388 ??
I have a couple of TEAC RC-70 remotes (for my 3440's) and was wondering if it would be compatible and safe to use with my 388 as well ?
Thanks as always for your help!
Daniel
Old 07-29-2005
Beck's Avatar
Beck Beck is offline
Analog Partisan Ranger
Beck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond repute
Daniel,
I'm pretty sure the only difference between the RC-70 and RC-71 is one is branded TEAC and the other Tascam. I know people use the RC-71 with the 3440. The control layout and proprietary 12-pin connector are the same.
If you want to be more than "pretty sure" maybe Ghost, Herm or ARP will be along to confirm.
-Tim
«:: «::B::» «::E::» «::C::» «::K::» ::»
"Where in the hell are the red M&M's?"
~My Lil' Sister, 1976
Old 07-29-2005
Beck's Avatar
Here’s a quick test if you have a multimeter.
The pins on the RC-70 connector should be as follows if it's the same as the RC-71:
1 play
2 Fast Forward
3 Rewind
4 Stop
5 Pause
6 Record
7 No connection
8 Common (ground)
9 No connection
10, 11 & 12 for LEDs
If you connect your multimeter between pin 8 and any pin (1-6) you should have continuity when you press the corresponding button.
-Tim
Old 07-29-2005
cjacek's Avatar
Analogue Enthusiast
I have no multimeter but thank you very much, Tim, for replying. The question popped up when I saw your auction for your RC-71 ... and then your list for possible machines where it could be used ... I actually never thought that the RC-70 (for my 3440) has so many possibilities! Anyway, would I do any electronic damage if I were just to try out the remote on my 388 ?
Thanks again Tim!
Daniel
Old 07-29-2005
Beck's Avatar
The safest way to check is to plug the remote in, but don't push any of the buttons on the remote yet. First try the record and pause buttons on the 388. The LEDs should light on the remote as well even though you aren't using the remote's buttons to engage. If the lights on the remote light according to the mode of the 388 I'd say you're good to go.
The other pins on the remote are just for normally-open momentary buttons, so you can't really hurt anything. The worst that could happen if it's not wired exactly the same is that certain buttons may have no affect or a button might engage a different mode than what the label says. I really don't think anything will start smoking.
Old 07-30-2005
cjacek's Avatar
Analogue Enthusiast
I will try exactly that .. Thanks Tim.
My new TASCAM 388 + LOTS of pictures!! cjacek Analog Only 86 08-19-2008 13:12
Dell PC Media Center remote control and cubase?? lomarrius Cubase User Forum 2 01-05-2005 08:37
Tascam 388 Recommendations lofipower Analog Only 18 06-27-2004 11:13
Newbie needs gear selection help Reilley Analog Only 116 09-25-2003 23:46
Need Teac Remote Control carguymike Free Ads for Music / Recording Equipment 0 03-06-2001 08:04
