Go Back   Home Recording > Equipment Forums > Keyboards and Sound Modules
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 07-29-2005
EVT EVT is offline
Dedicated Member
EVT has a reputation beyond reputeEVT has a reputation beyond reputeEVT has a reputation beyond reputeEVT has a reputation beyond reputeEVT has a reputation beyond reputeEVT has a reputation beyond reputeEVT has a reputation beyond reputeEVT has a reputation beyond reputeEVT has a reputation beyond reputeEVT has a reputation beyond reputeEVT has a reputation beyond repute
sample rate 32.01/44.1
Hello,
I was wondering how much of a difference it would make if I set my sampler to 32.01 for sequences/backing drums for live shows. I use a lot of different drum machines, so I'm putting them into my roland sp-808 to only have to bring the sampler for shows. Will it make a big difference in sound? I am going to run the sampler into the pa? For recording I would go with the higher sample rate, but I was running out of space on the disks, so I was trying to increase my sample time hoping it wouldn't make a huge difference
thanks,
evt
You are not the only person out of place on this PLANET!
Corrientes website: http://corrientesmusic.com/
Corrientes Forum: http://corrientesmusic.com/phpBB2/
Old 07-29-2005
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
I find there's a big difference between 32KHz and 44.1KHz.... particularly at 16-bit.... whether that's noticeable in a Live situation is another story... try it and see!
Old 07-29-2005
gemsbok gemsbok is offline
Dedicated Member
gemsbok has a reputation beyond reputegemsbok has a reputation beyond reputegemsbok has a reputation beyond reputegemsbok has a reputation beyond reputegemsbok has a reputation beyond reputegemsbok has a reputation beyond reputegemsbok has a reputation beyond reputegemsbok has a reputation beyond reputegemsbok has a reputation beyond reputegemsbok has a reputation beyond reputegemsbok has a reputation beyond repute
for live it should work fine. i have converted samples much lower than that and have gotten useable sounds with my gig band.my ensoniq sampler limits me to 64 meg so i feel your pain in conserving memory. a good rule of thumb is to look at the material your sampling frequency wise and take the sample rate and cut it in half. in your case 32k sample rate in theory should give you up to 16k recording frequency range. thats a pretty full range and should allow you to get away with just about any sample with a decent quality. the other factor would be how your roland converts the samples downward. like bear said try.
Bit and Sample rate question... Flight 16 Cubase User Forum 14 08-30-2004 10:19
bit vs sample rate ohthatguy Other Equipment and Reviews 1 08-09-2004 23:40
Trying to burn a song with a 48k Sample rate hegui Roland, Boss, VS Series Forum 4 06-12-2003 14:34
Any way to change the sample rate.... after recording? gamut1 Cakewalk / Sonar Forum 2 11-20-2001 05:14
Changing sample rate Lambo Cool Edit Pro / Adobe Audition Forum 2 03-25-2000 11:59
