Go Back   Home Recording > Special Forums > Live Events
Old 07-29-2005
taylorguitarman taylorguitarman is offline
Junior Member
taylorguitarman is on a distinguished road
House System For Bar Bands
I'm wondering what a good setup would be for a house system to handle bar bands. A coworker of mine owns a bar and I'll like to help her get setup for handling shows. (Maybe I'll even get to play soundman).
Beyond stereo micing the band and running through a PA, what would be an adequate system that would accomodate most bands? How many channels/monitors/speakers etc would be nice to have?
What are a few typical setups for live shows in bars?
If there are any good weblinks please direct me to them or post what you use/used at a venue.
Old 07-29-2005
boingoman boingoman is offline
moldin' oldie
boingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond repute
That needs some more info.
How big is the bar
What type of music
and so on.
I have seen everything from a six-channel powered mixer and some 12"/horn boxes and on up be plenty.
At a minimum, I'd say six-twelve channels, four each SM57 and 58, a couple of cheap DIs, a couple 15" powered speakers, perhaps, and a pair of monitors. That will get you through a lot of situations, and you can always rent a few systems to check them out.
Be aware- any permanent installation may require a permit and inspection, depending on local codes, especially if you hang speakers. A professional rigger should be called in for this, and probably would be required for insurance.
Old 07-29-2005
Junior Member
It's a biker bar so typical rock bands to the best of my knowledge and the bar is a decent size (a few hundred people comfortably). Not sure if it's supposed to be a permanent installation or not (likely not), just sort of doing some research to give the owner a few options from the cheap 4 channel Behringer setup to somewhere upwards 10k.
So lets assume the following band:
Drummer
Keyboardist
Bassist
Vocal/guitarist
2 guitarists
Would bands be happy with just SM57's an 58's? That's what I was thinking of for the mics. Maybe a couple Beta's too. Then something like a 14:4:2 MixWizard board with 2 15" speakers and a sub. And a few monitor speakers too. Then a T.C Electronics or Lexicon unit for reverb and possibly an EQ (or is the board EQ sufficient)?
Old 07-29-2005
moldin' oldie
Drummer
Keyboardist
Bassist
Vocal/guitarist
2 guitarists
Sounds like you are on the right track.
Most bands will never comment or even notice your mics. Anyone who cares that much will probably bring their own mics. You may want to think about a drum mic kit, with a kick mic and a condenser for cymbals, though in many small clubs cymbals can get by just fine on their own.
I did sound for a rock cover cover band playing in clubs just like this one for a couple of years.
They used a 16 channel Mackie, JBL MPro 415s for tops (very very excellent speaker for the money, I recommend them highly), older trapezoid JBL 2X15 subs, model SR4715, and four Peavey wedges. Pretty kickin' little system. The newer JBL Mpro subs do okay, as do offerings from Yorkville and other mfrs.
I would consider getting a couple cheap comps for vocals, and a cheap multigate for the drums. Don't forget eq for the monitors.
Old 07-29-2005
mshilarious's Avatar
mshilarious mshilarious is offline
Faithful Departed
mshilarious has disabled reputation
One thing I really want to add to my live/recording rig is a dbx Driverack PA. Takes care of compression, EQ, feedback, and crossover . . . a pretty damn clever unit. I wouldn't be looking for reverb or effects, probably more trouble than it's worth. Other than that I think you're on the right track.
I wonder if for a permanent install anybody ever hangs mini condensers above the drum riser? Any luck with that?
Old 07-31-2005
Tim Brown's Avatar
Tim Brown Tim Brown is offline
Why 2K?
Tim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond repute
Heres what I would do (and I ran sound for years)
Sennheiser 815
It's a decent general purpose live mic. MF has a 3-pack for $110 ($36 each, which is hard to beat.) Pick up 3 of these packs. You can use trhem for vocals, amps, and toms/snares.
6 boom mic stands for $99 (MF) Get two of these.
Kicks (get a pair of ATM pro-25's. Look for them on sale.)
It's a bar, you won't need overheads.
Mixer: I would go with a Mackie 1604 Vlz Pro. Why?
Because it will allow you to have 4 monitor sends from the house - you can use the 4 submixes as effects sends.
Don't worry about "stereo" live. Most people ruun what is called "dual mono" Which is where the sentire system is set up in stereo, but nothing is panned except the effects. The reason for this is, if you hard pan stuff to the left, the people on the right won't be able to hear it as well...and vice versa.
PA speakers: There's a whole slew of them out there. Personally, since this is on a Budget, I'd go with Peavey Black Widows. They can deliver ass pounding low end, and survive. Unless you're kicking out the bucks for SRX JBKL's, you are not getting "Real" JBL drivers. Think about it for a moment - you can't actually expect that speaker cabinet that costs $400 to contain "real" JBL drivers that sell for $350 each.
At least if you get Black Widows, you are getting a top of the line driver.
I would go with Front loaded boxes, rather than horn-loaded boxes. Generally, the "gains" fro ma hornloaded box, get EQ'd out, because they sound kind of "honky" (cup your hands and talk through them - that's also what a horn-loaded speaker box does to a speaker, and usually that "honk" gets EQ'd out. So, there is no advantage to using a hornloaded box. Plus, A hornloaded box is trying to deliver sound 200 feet away, when you want to deliver sound in the 25' to 100' range.
Peavey got a bad reputation becaue people underpowered their systems. Most people have no idea what kind of power ratios to use - if the speaker says 400 Watts RMS, they power it with 400 watts, but thge best amplifiers on the market are rarely better than 75% efficient. So what does that mean? It means for every 100 watts, you have 25 watts of distorted signal.
so a 400 watt amp, is really only delivering 300 watts of clean signal.
So, how do you get around this?
For top boxes, I go 1.5X the RMS rating. For subs, I go 2X the RMS rating.
So if your top box is looking for 400 Watts @ 8 ohms, you need an amplifier that delivers 600 Watts @ 8 ohms.
For starters, I would go with two 18" Speakers (stacked), with a 15"+1" Horn box on top of that on each side. You're gonna want a lot of low end to make sure you can deliver that AC/DC chest pounding thump (you said this is a Biker Bar) and that generally means Southern & Hard Rock -which means chest pounding low end.
For Power, don't play around...Crown, Crest, QSC, or my favorite Yorkville.Yorkville Amplifiers are not very well known, but let me tell you - they will compete with Top of the Line Crown and Crests, for a fraction of the cost.
Actually, if you're buying NEW gear - I would suggest you take a Serious look at Yorkville PA cabinets as well. You can get a great deal on them.
http://www.musiciansbuy.com/YORKVILL...AP6040KIT.html
This Amp (The AP6040) kicks SERIOUS Butt! 2000Watts per Channel @ 4 ohms for $1,250. One of these is great for driving four 18" speakers.
Now, you need to remember the inverse law. For every doubling of distance, the sound drops 3 db's. So if you're at 120 db's @ 3 feet, @ 6 feet - you've got 117, @ 12 feet - you've got 114, 24 feet- you've got 111 db's, 48 feet -you've got 98 dbs.
Also, get decent wedges.
I would get a pair of Stereo 31 band EQ's (Behringers would be fine)
A couple of compressors.
At least a quad gate for the drums.
and 2 effect units (one multieffect for ver for the drums) and a delay unit or multi-effect for vocals. (Behringers are fine here as well. I've got a pair of their multi-effects and they are great for every thing, and you can get them new for under $150.
Cables: Make sure you budget enough for the cables.
Go with 12-gauge speaker cables with Speakon ends.
Snake: Do NOT, I repeat - Do NOT buy a cheapo snake. It weill cost a little more now, but you'll get a good life out of it.
Tricks of the trade:
Buy some "bike" hooks like you would hang a bike from the ceiling of a garage with, and put them in the joists in the ceiling, and hang the snake that way. It gets it out of everyone's way, and you won't have to worry about anybody tripping over it.
You can set an amplifier to "bridge" mode, and connect the speakers op using a pair of banana plugs on the amplifier, but revers the polarity on the B channel, and it will give you more than the amplifer is rated to deliver. Why? Too long to go into it, but it works.
Dave Rat from Ratsound wrote an article about it. (look for Ratsound online - they started out as Black Flag's sound guys, and now they do bands like Red Hot Chili Peppers. They have a decent amount of info on their website.)
The key is, you have to think "how will this gear work as a SYSTEM", and not "I'll just buy whatever I can afford", because you might just be throwing your cash away if you do that.... some speaker designs don't work well with others.
for example: Idiot design of the century goes to the 2x15" with a 1" Horn in one speaker box. Why? It just doesn't work well together.... mainly because people tend to think "I don't need subs if I get that!"
WRONG!
Those boxes won't deliver the same kind of low end thump that a dedicated sub will.
Also, Youcan run your subs from an effects send, and only turn the bass guitar and kick drum up through them (guitar and vocals don't need to be in the subs anyway. Ask any soundman - we usually are rolling off or high-pass filtering the guitars, because they are fighting the bass guiatr in the low register, so for definition - we'll hi-pass the guitarists and vocals. Actually, I tend to hi-pass everything but the bass guitar and kicks, and sometimes- depending upon the size of the kicks, I'll even hi-pass those to help get a tighter kick sound...i.e, lose some of the floppiness because some drummers tune their drums way too low.)
Sorry for the mega shopping list, but if you want to put in a house sound system for a 200 person bar - this is what you're basically looking at. This type of system would rent for about $200-300 a night, depending upon the variables (where you are, and if you went above and beyond for extra's , like D112 kick mic's, etc. BUT - keep in mind, the ATM pro-25 will worjk great, I actually prefer it over the D-112's.)
Also, you could buy ATM pro-25's for the entire drumkit, and virtually do away with the noise gates because they are hypercardioid mic's. I would still want a gate for the kick to make sure the mallet strike is clean.
Tim
Old 07-31-2005
Cave Dweller Cave Dweller is offline
Dedicated Member
Cave Dweller will become famous soon enough
just a couple of side notes on Tim's post...
Graphic EQ- i would go with the best EQ that you can afford. the behringers are very limited. with out getting into alot of details, they sound bad. they are almost useless for doing monitors with, and forget about running FOH through them. i think it would really be a bottleneck in your system.
also, invest in sm58's and 57's. guys in bar bands who play the circuit often expect to see those mics, and can be thrown off when tere is something else. as boingoman said, if they want to use something else they will bring it.
Yorkville amps can be an ok value for the money, just watch out for the limiters...they are very noticable, and they kick in 6db before maximim output. i'm going to have to disagree with Tim here, they will not compete with highend crowns or crests. they are a decent midprice amp, but they are nowhere near something like a crown macrotech, or a QSC EX4000
and don't forget about LIGHTING! thats a whole other can of worms
Old 07-31-2005
moldin' oldie
Also, amplifier efficiency is how much power an amp can put out per watt it pulls from the wall, not what Tim said. A 75% efficient amp will pull say 1000W out of the wall, and be able to put 750W to the speakers.
Old 07-31-2005
Tim Brown's Avatar
Why 2K?
Hmm, I had been told that efficienicy had to do with how much it put out, and never heard a word about how much it drew (and that came from a soundman who worked for both Judas Priest and Yes) but what I said is true. There's not a commercial grade Amplifier out there that does a whole lot better than 75% output of clean power. The K2's are good, but I don't trust them for Hard Rock/Metal.
Tim
Old 08-01-2005
Dedicated Member
a decent power amp is going to give you clean power right up to it's maximum output. however, as you approach the maximum output, transients are going to activate the amps limiters (or if it is a poor design, it will just clip).
for live music, operating at about 75 - 85% of the amp's maximum output is a good range because you don't have to worry about limiters/clipping. recorded music is much less demanding, because it's (hopefully) been mastered, and it will have much less transients because of that.
Efficenicy is the relationship between the AC line power, and the amps output.
Old 08-01-2005
moldin' oldie
Tim
I was in a bit of a hurry. Thanks for not jumping on me for my reply, I didn't want to sound like I was ragging on you, or anything. First, I wanted to say it seems we all agree on the basics, a good set of tops and subs are pretty much the minimum way to go for a hard rock band in a club this size.
taylorguitarman, the rest of this is pretty off-topic, if you want to skip it.
EDIT------
I wrote a long-winded reply that basically came down to this:
I find amp specs to be pretty honest. A Crown MT2400 that is rated at 500W@8ohms will indeed put 500 clean watts into an 8ohm load. The amp is capable of more into that load, but you are correct in the sense that distortion will increase.
Many modern amps, though, can be pushed almost to clip without audible distortion, with almost any load it is rated for.
All amps distort all the time, no matter the power output. It is just a matter of degree, and whether or not you can hear it.
But like I said, I find published specs to be pretty honest. A 1000W per channel amp will indeed put out 1000 clean sounding watts, under the right conditions.
  #12
Old 08-02-2005
moldin' oldie
This is one of the things I was trying to get to. Max output power and rated output power can be widely different things, especially on older amps. I've got an old Crown PB2 rated for 325W@8ohms. It can put out clean peaks of 460W, and will put out 375W for longer with audible distortion, before the amp clips. You could easily be putting out more power than the amp is rated for, but think you were getting less, as the amp isn't clipping, but is still distorting.
  #13
Old 08-02-2005
Tim Brown's Avatar
Why 2K?
No way man, I wouldn't jump on ya about that - it's all a learning process. Hell, I ran a 10K soundsystem from around late 1986 through mid 1993, and it was just one big learning process.
The most important things I learned: I didn't like Rane equipment, especially their EQ's, or anything that said Furman on it.
Tim
  #14
Old 08-02-2005
PapillonIrl's Avatar
PapillonIrl PapillonIrl is offline
Medicated Member
PapillonIrl is on a distinguished road
One thing that I have learned is that if you concentrate more on that stage sound than the FOH, you will get the better bands back easier.
Drunk people don't care whether you have EV or Peavey FOH. The bands will appreciate as many monitor mixes and the best wedges as you can get.
Having said that, find someone who doesn't sell gear, but know their stuff, and pay them alot to find you a second hand rig. There's alot of people trying to move substandard stuff out there... And I don't just mean Guitar Center.
Nathan
  #15
Old 08-03-2005
VSpaceBoy's Avatar
VSpaceBoy VSpaceBoy is offline
..loading
VSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond repute
Good post guys, I'm taking some notes!
  #16
Old 12-04-2005
Garak's Avatar
Garak Garak is offline
Dedicated Member
Garak is on a distinguished road
I've worked in live sound for the past 5 years setting up shows, mixing foh and montiors in clubs, areans and outdoor festivals...
Anyway I'd go with a self powered PA, something with the power amps built right into the back of the cabinets. That way the amps are matched to the speakers and there is usually pretty damn good protection built in. I like the Mackie SRM-450, we got 8 of them in our rental inventory and they are out every weekend in the bars, tougher than they look. For alittle more low-mids there is the yorkville EF500P, its a wooden cabinet so its twice as heavy but its more directional so you hear them less on stage.
For subs the matching mackie sub sucks, we only have 4 of 8 left working. So lately we have been sending out yorkville LS800p, single 18" powered by an onboard 1500watt amp. Lots of bottom end for a club. Also these subs have a built in active crossover. So you go XLR out from the console, down the snake and right into the back of the sub, then out from the sub into the powered tops.
Lots of choices out there in monitors, again self power cabinets are the way to go, every montior can be its on mix this way too. We use yorkville NX-550p and some others by Opera. Actually we have the older NX520P and have had quite a few horns blow, I hope they have fixed the problem with the 550, they are great little monitors. For our big rig we use yorkville TX-5M which are top notch, expensive though, each cabinet requires a stereo amp where they are bi-amped.
As for consoles, the Allen & Heath Mixwizard 16:2DX is hard to beat for the price. 6 Aux sends, 4 for montiors, 2 for external or onboard effects. Great Allen and Heath EQ's, two sweeps and high and low. Don't buy mackie for live sound, the EQ's suck.
You don't need alot of processing in a bar but you will want atleast 1 31 band eq for each monitor mix and 2 for the main stereo mix. Buy good EQ's, the behringers are junk, they color the sound big time when set flat, inserting one is like turning on a low pass filter. With the mixwizard you have 2 channels of built in effects that don't sound that bad, one verb for vocals and one for drums. There are lots of choices in external reverb units, I like my TC electronic M-One. Comps and gates are always extra in a club, not really required but can help to solve a few problems.
As for mics, stick with the shure SM-58 or beta58 on vocals, some people get pissy if you put any other mic in front of them. Its not that they are the best but most musicans are use to them. Have a few SM-57's for gutiar amps and snare, again not always the best but people know them. Lots of other choices out there but cover the basics first. Akg D112 or Beta52 for kick drum. DI's are DI's but have both active and passive, atleast 2 of each.
Buy good cables with neutrik connectors, nothing else really will stand up to the abuse of a bar. I'd get atleast 32 XLR cables and a 16 channel 8 return snake. Don't use cheap power bars, the breakers pop at the worst time, get a few quad boxes done up on 12/3 cable. Also get 3 or more dedicated circuits wired up to the back of the stage just for sound.
As for Mic stands, shell out the cash and get K&M stands. Not only are they the standard but they are pretty tough and will last 10 times longer than cheap ultra stands.
I could go on for hours, anyway check out the lounge at http://srforums.prosoundweb.com/ that forum is the place to learn live sound. Read lots and lots before posting, it is a professional site and they have rules that must be followed. Chances are your questions have already been answered a dozen times over in there archives so search first.
  #17
Old 12-04-2005
Garak's Avatar
Dedicated Member
Another little blurb on power amps...
Modern amps use swtiching powersupplies and actually draw less power at anyone time than they can put out for short amounts of time. Durning point where alot of power is required it actually draws most of that power from capacitors rather than directly from the wall. The power from the wall is constantly charging the capacitors. Its kinda like a bucket with a steady stream of water coming in and every once in a while you tip the bucket. The actuall output of the amp is really limited by the rail voltages in the amp and the load on the amp. Ofcourse the power comming in has to have enough current to keep some water in the bucket.
You can never really over power a cabinet, the bigger the power amps the better. As a rule they say your power amps should be twice the RMS rating of the speaker. So on a 3way tri-amped rig, with 50 watt horn, 400watt 15" and a 1000watt 18", your going to want stereo power amps that can put out atleast 100 watt, 800watt and 2000watt per channel.
Anyway I'd still go with powered gear this day in age. By the time you factor in cables, processing and power amps, self powered cabinets are cheaper and simpler.
You will get lots of mixed reviews, alot of people don't like the mackie SRM-450's others don't like yorkville. Some swear by JBL EON's or even Peavey. They all have offerings which are worth looking at around the same price range and each has pros and cons. I swear by the mackies and the yorkies because we have put them through hell for the past 5 years and the are mostly still kicking. The mackie subs have shown there limits and the NX-520p also has its issues but atleast yorkville has the great even if you break it warranty. Lots of people out there will snob the works of this stuff and won't mix on anything less than an EAW or l' acoustics rig. Anyway there is good and bad peavey, behringer, mackie, yorkville, JBL, EV, Opera, etc... Its just a matter of sorting through the reviews, hype, snobs, people who haven't learned anything new in 20 years, people who haven't learned anything before the last year, etc...
Ireland/UK ONLY !! Modified EV eliminator PA System PapillonIrl Free Ads for Music / Recording Equipment 1 03-05-2008 06:51
Stressed out...can't get system to recognize new 40GB audio drive. PapillonIrl Digital Recording & Computers 12 05-02-2002 11:05
new bands daled Songwriting, Singing & Vocals 3 01-11-2002 16:27
new system, mother board compatability mboud Digital Recording & Computers 4 05-14-2001 11:55
PC DAW Digest TAE Digital Recording & Computers 0 11-25-2000 09:03
