Console names and part names
Can you guys help me out so i know what basic 101 consoles
names are. If i was going to collect consoles which old ones should i buy? What part inside the consoles should i look for and know the names of ? like example Allen bradley resistor and pots, Spector power amps stuff like that will help me out to know about consoles more What do most Collectors buy? for consoles? and the parts in the consoles? |
This is just coming from someone w/ a general understanding -- I'm no expert, but I do know that names like Neve, Amek, Otari, Allen & Heath, and Harrison have made some pretty PHAT consoles in days of old. If you pick up one of those puppies in good working order, you'd be the talk of the neighborhood in some form or fashion.
Not sure what you're really......wanting to do this for, but good luck. -callie- |
like Neve, Amek, Otari, Allen & Heath, Harrison, Midas, sensa sound
What parts brand names did they have in these types of consoles and what are some popular model names/numbers that collectors like to buy? |
K45 K45sbwh
K45ss Ksm75 K45sbwh Ksm90 Ksm103 K45sbwh Ksm110 Ksm150 K5thsbp Ksm151 Ksm152 K5 K5asbp K5a K5ss K5asbp Ksm5 Kp50 Kv25h Kn25wpbh Kv25g Kg25h Kn25pbh Kg25g Kp2671 Kn2b6peh Kt265 Kd2661 Kn2b6peh Kp26m1x Kb26g |
a) 6 capacitors are included in the kit but are actually not used:
C14 = 47pF; C8,15,27 = .01uF; and C11, 20 = 0.1uF. You should use one of these 0.1uF caps in the C27 position, and just add the others to your junk box. Note that the 0.1uF C15 is still used on the board. b) 3 resistors are included in the kit but are actually not used: R5 = 4.7 ohms; and R11,13 = 10K You should just add these extra resistors to your junk box. Note that the 220-ohm R11 is still used on the board. c) The following 7 missing resistors will be sent to everyone: 100K = R10, 17, 18, 20, 21 27K = R29 4.7K = R13 d) #26 magnet wire was sent with kit, instead of #28 wire, making it difficult to get all 36 turns onto T3. A length of #28 wire will be sent to all customers e) C35, across the IF transformer (T2) in the RF Amp section, was omitted from the text and Parts List. The value of C35 required to resonate on 40m with the T2 primary is 100pF. This cap will be sent to all customers. |
-ALL pots are designated by type, value, taper, and # of sections (mono, stereo or quad), e.g. "Type B, 20KA mono".
-Type "A" Pots: Square aluminum case with black plastic cover, for older German production units- Not Listed and No Longer Available! -Type "B" Pots: Round, brass case w/long D-shaft for older China production processors, and some new ones. -Type "C" Pots: Small, square, plastic-body w/plastic D-shaft (center -detent), Mixers ONLY. -Type "D" Pots: Small, square, plastic-body w/plastic D-shaft (21-detent), Pro-series processors ONLY. -Faders are designated as "SMALL" (5/16") or "WIDE" (1/2") width. Please measure the width of the original for the correct part#. -Faders are also designated as mono or stereo, which are single and dual, respectively. -Please note that the 100mm faders for models MX3242X and MX8000/9000 appear identical but have different pinouts. -Please note that 60mm faders may be Panasonic or Alps. They do not retrofit each other. Panasonic is identified by an "M" on the body of the fader, and Alps is stamped with the name. We realize that this may seem a bit confusing, but the more accurate you are in matching a part to the correct part#, the more accurate your parts order will be. MANY POTS LOOK IDENTICAL. CHECK ALL I.D. MARKS CAREFULLY! |
CRYSTAL QUA-0008 CRYSTAL 8 MHz HC49U 5.00
CRYSTAL QUA-0009 CRYSTAL 12 MHz HC49U 5.00 CRYSTAL QUA-0010 CRYSTAL 12.288 MHz HC49U 5.00 CRYSTAL QUA-0011 CRYSTAL 16.9344 MHz HC49U 5.00 CRYSTAL QUA-0037 CRYSTAL 32.768 kHz, DDX3216 |
HARDWARE 0MET-001 Adjuster set MB8000, 6 parts (Meter Bridge Hardware) 10.00
HARDWARE 0PLA-025 Rubber foot 12.8mm x 6.2mm Blk (4pk) 2.00 HARDWARE 0PLA-030 Plastic snap rivet, black, 2 parts 2.00 HARDWARE 0PLA-035 Switch spacer for Mixer 14.2mm 2.00 HARDWARE 0PLA-037 Pot Shoulder Washer (large), 19” units 2.00 HARDWARE 0PLA-065 Pot shoulder washer for Alps Pots 1HE |
POTENTIOMETER 0POT-003 POT 50KB stereo Mixer, Type C 6.50
POTENTIOMETER 0POT-004 POT 50KC stereo Mixer, Type C 6.50 POTENTIOMETER 0POT-005 POT 500KC stereo Mixer, Type C 6.50 POTENTIOMETER 0POT-006 POT 50KG stereo Mixer, Type C 6.50 POTENTIOMETER 0POT-007 POT 10KAC stereo Mixer, Type C 6.50 POTENTIOMETER 0POT-008 POT 50KCA stereo Mixer, Type C 6.50 POTENTIOMETER 0POT-010 POT 10KB mono Mixer, Type C 6.50 POTENTIOMETER 0POT-011 POT 50KB mono Mixer, Type C 6.50 POTENTIOMETER 0POT-012 POT 50KG mono Mixer, Type C 6.50 POTENTIOMETER 0POT-016 POT 1KB mono 7.50 POTENTIOMETER 0POT-017 POT 1KC mono, Type B 7.50 POTENTIOMETER 0POT-018 POT 1MA mono, Type B 7.50 POTENTIOMETER 0POT-019 POT 5KA mono, Type B 7.50 POTENTIOMETER 0POT-020 POT 10KA mono, Type B 7.50 POTENTIOMETER 0POT-021 POT 10KB mono, 21-detent, Type B 7.50 POTENTIOMETER 0POT-023 POT 20KA mono, Type B 7.50 POTENTIOMETER 0POT-024 POT 20KB mono, Type B 7.50 POTENTIOMETER 0POT-025 POT 20KB mono with tap, Type B 7.50 POTENTIOMETER 0POT-027 POT 50KB mono, Type B 7.50 POTENTIOMETER 0POT-029 POT 50KW mono, Type B 7.50 POTENTIOMETER 0POT-030 POT 50KW mono with tap, Type B 7.50 POTENTIOMETER 0POT-031 POT 100KA mono, Type B 7.50 POTENTIOMETER 0POT-034 POT 500KA mono, Type B 7.50 POTENTIOMETER 0POT-036 POT 5KB/10KB stereo, Type B 12.00 POTENTIOMETER 0POT-037 POT 10KA stereo, Type B 12.00 POTENTIOMETER 0POT-038 POT 10KB stereo, Type B 12.00 POTENTIOMETER 0POT-039 POT 10KC stereo, Type B 12.00 POTENTIOMETER 0POT-040 POT 20KA stereo, Type B 12.00 POTENTIOMETER 0POT-042 POT 50KW stereo, Type B 12.00 POTENTIOMETER 0POT-043 POT 100KC stereo, Type B 12.00 POTENTIOMETER 0POT-045 POT 100KB stereo, Type B 12.00 POTENTIOMETER 0POT-046 POT 100K quad, Type B 24.00 POTENTIOMETER 0POT-069 POT 100KC stereo 21-detent, Type D 7.50 POTENTIOMETER 0POT-070 POT 10KC stereo 21-detent, Type D 7.50 POTENTIOMETER 0POT-071 POT 50KG mono with tap 21-detent, Type D 7.50 POTENTIOMETER 0POT-072 POT 10KA mono 21-detent, Type D 7.50 POTENTIOMETER 0POT-073 POT 5KZY mono 21-detent, Type D 7.50 POTENTIOMETER 0POT-074 POT 10KB mono 21-detent, Type D 7.50 POTENTIOMETER 0POT-075 POT 50KB mono 21-detent, Type D 7.50 POTENTIOMETER 0POT-076 POT 20KA mono 21-detent, Type D 7.50 POTENTIOMETER 0POT-077 POT 50KA mono 21-detent, Type D 7.50 POTENTIOMETER 0POT-078 POT 1KA mono 21-detent, Type D 7.50 POTENTIOMETER 0POT-079 POT 1MA mono 21-detent, Type D 7.50 POTENTIOMETER 0POT-080 POT 100KA mono 21-detent, Type D 7.50 POTENTIOMETER 0POT-081 POT 1KB mono 21-detent, Type D 7.50 POTENTIOMETER 0POT-082 POT 50KG mono 21-detent, Type D 7.50 POTENTIOMETER 0POT-084 POT 100K stereo 21-detent, Type D 7.50 POTENTIOMETER 0POT-113 Pot Alps 10KA/05 21-detent (T1951) 7.50 POTENTIOMETER 0POT-115 Pot Alps 50KG mono 21-detent (T1951) 7.50 POTENTIOMETER 0POT-116 Pot Alps 100KD mono 21-detent (MX882) 7.50 POTENTIOMETER 0POT-117 Pot Alps 10KA mono center-detent (DX1000/B300) 7.50 POTENTIOMETER 0POT-118 Pot Alps 10KB mono (AC112/GX112) 7.50 POTENTIOMETER 0POT-119 Pot Alps 10KC mono (DX1000) 7.50 POTENTIOMETER 0POT-120 Pot Alps 100 KC mono center-detent(DX500) 7.50 POTENTIOMETER 0POT-121 Pot Alps 20KB mono (DX1000) 7.50 POTENTIOMETER 0POT-122 Pot Alps 50KB mono center-detent 7.50 POTENTIOMETER 0POT-123 Pot Alps 50KG mono center-detent 7.50 POTENTIOMETER 0POT-124 Pot Alps 1KA mono 21-detent 7.50 POTENTIOMETER 0POT-125 Pot Alps 10KA mono (GX112) 7.50 POTENTIOMETER 0POT-126 Pot Alps 50KA/05 mono (AC112/GX210/GX212) 7.50 POTENTIOMETER 0POT-127 Pot Alps 50KA/05 mono center-detent (GX112) 7.50 POTENTIOMETER 0POT-128 Pot Alps 50KB mono 7.50 POTENTIOMETER 0POT-129 Pot Alps 100KB mono (GX210/GX212) 7.50 POTENTIOMETER 0POT-130 Pot Alps 100KA/05 mono 21-detent (DE2200/MIC2200) 7.50 POTENTIOMETER 0POT-131 Pot Alps 50KA mono (GX Series) 7.50 POTENTIOMETER 0POT-132 Pot Alps 5KA mono (GX Series) 7.50 POTENTIOMETER 0POT-133 Pot Alps 5KZY mono 21-detent (T1953) 7.50 POTENTIOMETER 0POT-134 Pot Alps 20KG mono 21-detent (GEQ3102) 7.50 POTENTIOMETER 0POT-135 Pot Alps 50KA mono 21-detent (T1952) 7.50 POTENTIOMETER 0POT-136 Pot 10KB mono, Type B 7.50 POTENTIOMETER 0POT-137 Pot Alps 5KA mono 21-detent (XR4400) 7.50 POTENTIOMETER 0POT-139 Pot Alps 50KG mono 21-detent (T1953) 7.50 POTENTIOMETER 0POT-140 Pot Alps 500KC/05 21-detent (XR4400) 7.50 POTENTIOMETER 0POT-141 Pot Alps 100KA/05 mono 21-detent (T1951) 7.50 POTENTIOMETER 0POT-142 Pot Alps 20KA mono 21-detent (T1952) 7.50 POTENTIOMETER 0POT-143 Pot Alps 100KA/10 mono 21-detent (PEQ2200) 7.50 POTENTIOMETER 0POT-144 Pot Alps 50KB mono 21-detent (T1952) 7.50 POTENTIOMETER 0POT-145 Pot Alps 10KB mono 21-detent (T1952/T1954) 7.50 POTENTIOMETER 0POT-146 Pot 100KG mono ALPHA 7.50 POTENTIOMETER 0POT-147 Pot Alps 100KD stereo 21-detent (MX882) 7.50 POTENTIOMETER 0POT-148 Pot Alps 100KA mono (DX1000) 7.50 POTENTIOMETER 0POT-149 Pot Alps 20KA stereo 21-detent (HA4400) 7.50 POTENTIOMETER 0POT-150 Pot Alps 50KG stereo 21-detent (T1951) 7.50 POTENTIOMETER 0POT-151 Pot Alps 5KB stereo 21-detent (MX882) 7.50 POTENTIOMETER 0POT-152 Pot Alps 10KB stereo 21-detent (EX100/HA4400) 7.50 POTENTIOMETER 0POT-153 Pot Alps 10KB stereo 21-detent (Tube Series) 7.50 POTENTIOMETER 0POT-154 Pot Alps 10KA stereo 21-detent (EX1200) 7.50 POTENTIOMETER 0POT-155 Pot Alps 10KC stereo 21-detent (EX1200) 7.50 POTENTIOMETER 0POT-156 Pot Alps 50KG mono with tap 21-detent 7.50 POTENTIOMETER 0POT-157 Pot Alps 100KA stereo 21-detent (HA4400) 7.50 POTENTIOMETER 0POT-158 Pot Alps 10KC stereo 21-detent (T1954) 7.50 POTENTIOMETER 0POT-159 Pot Alps 100KC stereo 21-detent (T1951/T1953) 7.50 POTENTIOMETER 0POT-160 Pot Alps 5KB stereo center-detent (DX100/500) 7.50 POTENTIOMETER 0POT-161 Pot Alps 10KA stereo center-detent (DX100/500) 7.50 POTENTIOMETER 0POT-162 Pot Alps 10KAC stereo center-detent 7.50 POTENTIOMETER 0POT-163 Pot Alps 10KB stereo center-detent 7.50 POTENTIOMETER 0POT-164 Pot Alps 50KB stereo center-detent 7.50 POTENTIOMETER 0POT-165 Pot Alps 50KC stereo center-detent 7.50 POTENTIOMETER 0POT-166 Pot Alps 50KCA stereo center-detent 7.50 POTENTIOMETER 0POT-167 Pot Alps 100KC stereo center-detent(DX1000) 7.50 POTENTIOMETER 0POT-168 Pot Alps 500 KC stereo center-detent 7.50 POTENTIOMETER 0POT-169 Pot Alps 10KA mono 21-detent (T1954) 7.50 POTENTIOMETER 0POT-170 Pot Alps 5KA mono center-detent (GX112) 7.50 POTENTIOMETER 0POT-171 Pot Alps 50KA mono center-detent (GX112) 7.50 POTENTIOMETER POT-0009 POT 5KZY mono Mixer, Type C |
#12
What was I thinking? In that case, please read the following in reverse order. Part Number Format Description Datasheet RF4500 Bulk Double Conversion Tuner View RFDR08-51 Bulk Cellular Converter n/a RFDR08-55 Bulk Cellular Converter n/a RFDR09-51 Bulk GSM Converter n/a RFDR09-55 Bulk GSM Converter n/a RFDR19-51 Bulk PCS Converter n/a RFDR19-55 Bulk PCS Converter n/a RFDR20-51 Bulk WCDMA Converter n/a RFDR20-55 Bulk WCDMA Converter n/a RFUR08-50 Bulk Cellular Converter n/a RFUR08-56 Bulk Cellular Converter n/a RFUR09-50 Bulk GSM Converter n/a RFUR09-56 Bulk GSM Converter n/a RFUR19-50 Bulk PCS Converter n/a RFUR19-56 Bulk PCS Converter n/a RFUR20-50 Bulk WCDMA Converter n/a RFUR20-56 Bulk WCDMA Converter n/a Thanks man! ![]() |
#13
Good grief!
Now I need consoling!
I prefer to err on the side of perfection.~ ez_willis |
#14
Lookin' for some new meat, wally? Hey Ghost, if you dream in analog, and wally's lookin' into analog gear, then.........???????????? You might want to fire the coffee pot up. An essay on wally's new POTENTIOMETER 0POT-021 POT 10KB mono, 21-detent, Type B 7.50 The issues involving wally's new POTENTIOMETER 0POT-021 POT 10KB mono, 21-detent, Type B 7.50 has been a popular topic amongst scholars for many years. There are many factors which influenced the development of wally's new POTENTIOMETER 0POT-021 POT 10KB mono, 21-detent, Type B 7.50 . While much has been written on its influence on contemporary living, spasmodically it returns to create a new passion amongst those who study its history. Often it is seen as both a help and a hinderence to so called 'babies', trapped by their infamous history. With the primary aim of demonstrating my considerable intellect I will now demonstrate the complexity of the many faceted issue that is wally's new POTENTIOMETER 0POT-021 POT 10KB mono, 21-detent, Type B 7.50 . Social Factors Society is a simple word with a very complex definition. Upon Peter Pinkleton-PishPosh's return to Britain he remarked 'class will refelect the inner hero' [1], he globalised an issue which had remained buried in the hearts of our ancestors for centuries. No symbol is more potent than wally's new POTENTIOMETER 0POT-021 POT 10KB mono, 21-detent, Type B 7.50 in society today. It is quite good. Nothing represents every day life better than wally's new POTENTIOMETER 0POT-021 POT 10KB mono, 21-detent, Type B 7.50 , and I mean nothing. Society is powered by peer pressure, one of the most powerful forces in the world. As long as peer pressure uses its power for good, wally's new POTENTIOMETER 0POT-021 POT 10KB mono, 21-detent, Type B 7.50 will have its place in society. Economic Factors There has been a great deal of discussion in the world of economics, centred on the value of wally's new POTENTIOMETER 0POT-021 POT 10KB mono, 21-detent, Type B 7.50 . We will begin by looking at the Inter-Spam model of economics. Cost Of Living wally's new POTENTIOMETER 0POT-021 POT 10KB mono, 21-detent, Type B 7.50 When displayed this way it becomes very clear that wally's new POTENTIOMETER 0POT-021 POT 10KB mono, 21-detent, Type B 7.50 is of great importance. Of course the cost of living cannot sustain this instability for long. Strong fluctuations in investor confidence have been seen over the past two financial years. Political Factors Politics - smolitics! Comparing the electoral politics of most Western and Eastern European countries is like comparing wally's new POTENTIOMETER 0POT-021 POT 10KB mono, 21-detent, Type B 7.50 ilisation, as it's become known, and one's own sense of morality. One quote comes instantly to mind when examining this topic. I mean of course the words of jazz singer Bartholomew Shandy 'political change changes politics, but where does it go?' [2] Primarily, he is referring to wally's new POTENTIOMETER 0POT-021 POT 10KB mono, 21-detent, Type B 7.50 . If our political system can be seen as a cake, then wally's new POTENTIOMETER 0POT-021 POT 10KB mono, 21-detent, Type B 7.50 makes a good case for being the icing. One of the great ironies of this age is wally's new POTENTIOMETER 0POT-021 POT 10KB mono, 21-detent, Type B 7.50 . Isn't it ironic, don't you think? Conclusion In conclusion, wally's new POTENTIOMETER 0POT-021 POT 10KB mono, 21-detent, Type B 7.50 may not be the best thing since sliced bread, but it's still important. It fills a hole, puts out 'fires', and figures show it's a winning formular. Let's finish with a thought from star Ozzy Travolta: 'I wouldn't be where I am today without wally's new POTENTIOMETER 0POT-021 POT 10KB mono, 21-detent, Type B 7.50 .' [3] -------------------------------------------------------------------------------- [1] Flankton - The Complete History - 1999 Fantastico Publishing [2] Shandy - Ice Cold - 1994 Pitter Patter Publishing [3] Go mad for wally's new POTENTIOMETER 0POT-021 POT 10KB mono, 21-detent, Type B 7.50 - Issue 132 - Kendeal Books Tom Hix was right, I am at the top of my game. It sucks though, cause I'm the only team! ![]() |
#15
Top THAT APL!!
Go on, top it! ![]() |
#16
Someone should console your momma for pro-creating. |
#17
I'm in pain.
#18
Hey now, don't forget these classics!
01B22-ND EVM-C7GA01B22 200 OHM CERMET POTENTIOMETER(201 Panasonic - ECG Obsoleted by Manufacturer - - - - - - - - Non-Stock 1.29000 1 - 1FA12-ND EVM-M1FA01B12 POT 100 OHM SQ SIDE (101) Panasonic - ECG Obsoleted by Manufacturer - - - - - - - - Non-Stock 0.74000 1 - 1FA13-ND EVM-M1FA01B13 POT 1K OHM SQ SIDE (102) Panasonic - ECG Obsoleted by Manufacturer - - - - - - - - Non-Stock 0.74000 1 - 1FA55-ND EVM-M1FA01B55 POT 500K OHM SQ SIDE (504) Panasonic - ECG Obsoleted by Manufacturer - - - - - - - - Non-Stock 0.74000 1 - 3099P-502-ND 3099P-1-502 5.0K OHM 3/4 RECT CERM MTD POT Bourns Inc. Obsoleted by Manufacturer - - - - - - - - Non-Stock 7.90000 1 - 3314S-102ECT-ND 3314S-1-102E POT 1K OHM 4MM SQ CERM SMD Bourns Inc. Obsoleted by Manufacturer - - - - - - - - 0 1.44000 5 - 3314S-503ECT-ND 3314S-1-503E POT 50K OHM 4MM SQ CERM SMD Bourns Inc. Obsoleted by Manufacturer - - - - - - - - 0 1.44000 5 - 3314S-101ECT-ND 3314S-1-101E POT SMD 4MM SQ CERM 100 OHM Bourns Inc. Obsoleted by Manufacturer - - - - - - - - 0 1.44000 5 - 3314S-105ECT-ND 3314S-1-105E POT 1M OHM 4MM SQ CERM SMD Bourns Inc. Obsoleted by Manufacturer - - - - - - - - 0 1.44000 5 - 3314S-201ECT-ND 3314S-1-201E POT 200 OHM 4MM SQ CERM SMD Bourns Inc. Obsoleted by Manufacturer - - - - - - - - 0 1.44000 5 - 3314S-203ECT-ND 3314S-1-203E POT 20K OHM 4MM SQ CERM SMD Bourns Inc. Obsoleted by Manufacturer - - - - - - - - 0 1.44000 5 - 3314S-253ECT-ND 3314S-1-253E POT 25K OHM 4MM SQ CERM SMD Bourns Inc. Obsoleted by Manufacturer - - - - - - - - 0 1.44000 5 - 3316F-101-ND 3316F-1-101 100 OHM 6MM RD CARBON ST POT Bourns Inc. Obsoleted by Manufacturer - - - - - - - - Non-Stock 0.41000 1 - 3316F-202-ND 3316F-1-202 2.0K OHM 6 MM RD CARBON ST POT Bourns Inc. Obsoleted by Manufacturer - - - - - - - - Non-Stock 0.41000 1 - 3316F-203-ND 3316F-1-203 20K OHM 6MM RD CARBON ST POT Bourns Inc. Obsoleted by Manufacturer - - - - - - - - Non-Stock 0.41000 1 - 3316F-204-ND 3316F-1-204 200K OHM 6MM RD CARBON ST POT Bourns Inc. Obsoleted by Manufacturer - - - - - - - - Non-Stock 0.41000 1 - 3316K-103-ND 3316K-1-103 10K OHM 6MM RD CARBON ST POT Bourns Inc. Obsoleted by Manufacturer - - - - - - - - Non-Stock 0.41000 1 - 3316K-104-ND 3316K-1-104 100K OHM 6MM RD CARBON ST POT Bourns Inc. Obsoleted by Manufacturer - - - - - - - - Non-Stock 0.41000 1 - 3316K-501-ND 3316K-1-501 500 OHM 6MM RD CARBON ST POT Bourns Inc. Obsoleted by Manufacturer - - - - - - - - Non-Stock 0.41000 1 - 3316P-103-ND 3316P-1-103 10K OHM 6MM RD CARBON ST POT Bourns Inc. Obsoleted by Manufacturer - - - - - - - - Non-Stock 0.41000 1 - 3316P-104-ND 3316P-1-104 100K OHM 6MM RD CARBON ST POT Bourns Inc. Obsoleted by Manufacturer - - - - - - - - Non-Stock 0.41000 1 - 3316P-501-ND 3316P-1-501 500 OHM 6MM RD CARBON ST POT Bourns Inc. Obsoleted by Manufacturer - - - - - - - - Non-Stock 0.41000 1 - 3316W-101-ND 3316W-1-101 100 OHM 6MM RD CARBON ST POT Bourns Inc. Obsoleted by Manufacturer - - - - - - - - Non-Stock 0.41000 1 - 3316W-105-ND 3316W-1-105 1.0M OHM 6MM RD CARBON ST POT Bourns Inc. Obsoleted by Manufacturer - - - - - - - - Non-Stock 0.41000 1 - 3323P-101-ND 3323P-1-101 100 OHM 1/4 SQ CERM ST SL POT Bourns Inc. Obsoleted by Manufacturer - - - - - - - - Non-Stock 1.33000 1 - Page1/18 (Next) Page Generated at: 0:03:33 7/28/2005 - Help With This Screen Copyright © 1995-2005 Digi-Key Corporation 701 Brooks Avenue South Thief River Falls, MN 56701 USA Phone: 800-344-4539 or 218-681-6674 Fax: 218-681-3380 Email: webmaster@digikey.com Privacy Statement | Terms & Con
"See ya on the flip-side" |
#19
Seems like alot of old men acting like women and little girls posting trash
#20
#21
...do as wally does.
#22
________________________________________________________________
#23
Nope, I'd say we are acting exactly like old men PS I apologize to the handful of chicks who do post here! Please continue to talk to us! We're very lonely and poorly adjusted socially! |
#24
"We don't like their sound, and guitar music is on the way out." --Decca Recording Co. rejecting the Beatles, 1962. |
#25
holy shit. we are freaks.
| Brand Names part 2 | Griffinator | Guitars and Basses | 2 | 11-21-2005 16:42 |
| Please critique lyric: "Masquerade Mansion" | Cheeky Monkey | Songwriting, Singing & Vocals | 8 | 08-09-2004 13:45 |
| Part One of the Logic Audio Saga: "The Celebration" | pisces7378 | Digital Recording & Computers | 1 | 05-17-2001 14:50 |
