Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 09-08-2000
bball jones's Avatar
bball jones bball jones is offline
Force of Nature
bball jones is on a distinguished road
I am happy to report that my CD-R is intact and working fine. But, I am having this little problem with the finished product - (cd).
At the start of every track there is an almost inaudible click - at first I didn't notice it. But now it is starting to drive me crazy. I am using the adaptec software that came with the Teac CD-R. Would moving on to something like Red Roaster eliminate the introductory clicks ?
Old 09-08-2000
Emeric Emeric is offline
Emeric has a reputation beyond reputeEmeric has a reputation beyond reputeEmeric has a reputation beyond reputeEmeric has a reputation beyond reputeEmeric has a reputation beyond reputeEmeric has a reputation beyond reputeEmeric has a reputation beyond reputeEmeric has a reputation beyond reputeEmeric has a reputation beyond reputeEmeric has a reputation beyond reputeEmeric has a reputation beyond repute
Possibly another program may work better for you. Avoiding the obvious, these clicks are not apparent on the source material of course.
Are you burning "track at once" or "disc at once". Try disk at once if you haven't already. If you do decide to switch software, check out Wavelab, expensive but a very good integrated burner.
Old 09-08-2000
Force of Nature
Thumbs up
I been doin' disc at once-
'cause me, being the time conscience idiot I am, think this is the fastest way. I most definately will check out the track at once options.
Several times I have been - this close - to bringing Wavelab home. Hasn't happened yet.
thanks Emeric
Old 09-09-2000
donaman donaman is offline
Newbie
donaman is on a distinguished road
Smile I have your answer...
the reason for the clicks in the end of the tracks in DAO is because Adaptec is a piece of crap. CD "time code" is measured in minutes, seconds then frames. I'm pretty sure theres 75 frames/second. What happens in adaptec is that if the track does not end on an exact frame, adaptec fills the end of the frame and the sudden change in amplitude causes your click. Go into your audio editor set the view to frames and turn snapping on. End your track on an exact frame and the clicks go away.
Old 12-15-2005
Norman@TTL Norman@TTL is offline
Newbie
Norman@TTL is on a distinguished road
Yes, I have Red Roaster, and it usually works fine. I get a very loud click sometimes at the beginning of a WAV file I import, and here's how I've learned to solve it: When recording (in Cakewalk Pro Audio), I offset the timing of the song so that it doesn't start right at 00:00:00 (going to frame 05 or so instead). I start recording at 00:00:00 and the resulting WAV file is clean.
However, Roaster isn't on the market anymore. Now you have to get the lowest level of Amplitude from Magix (who bought the software from SEK'D). I hear it isn't cheap.
If you get an old version of Roaster, beware of some strange things: It has to recognize your sound card in order to work, and it has to recognize your CD-R drive in order to burn. If you have a new drive (put out since the last version of Roaster), Magix may not be able to help you get support for it. These problems may not occur in Samplitude, since it's been updated more recently.
--Norman
Old 12-15-2005
Track Rat's Avatar
Total Gear Slut
Wow. A five year time delay. That's what I call latency.
Mike
Old 12-15-2005
Robert D Robert D is offline
Close to the Edge
Robert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond repute
LMAO !
-RD
Old 12-15-2005
SouthSIDE Glen's Avatar
SouthSIDE Glen SouthSIDE Glen is offline
independentrecording.net
SouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond repute
That's one loooong click!
G.
Glen J. Stephan,
SouthSIDE Multimedia Productions
RECORDING RESOURCES AND INFO SITE:
