Sync 2 VF160 together
A friend asked me if I wanted to buy his VF160 (with burner) for $350. He also has some headphones and speakers with it.
I have one and love it. Has anyone used midi to sync 2 of them together? How did ot work out for you?
WARNING: THIS POST DOESN'T CONTAIN ANYTHING HELPFUL http://www.myspace.com/veritasrs __________________________________________________________________________________________________ Last edited by dragon: at 04:10 |
When I upgraded from VF16 to VF160 I sync'd the machines to transfer my existing songs, before I sold the 16. I'm kinda sorry now I didn't keep it. The sync is straightforward although I seem to remember you have to sync MIDI and audio. The issue is how you combine the outputs for mixdown and monitoring, and the aux sends (if you use them). THe Fostex USA website, support section FAQ covers this topic.
Orc |
Any other ideas? -ray |
I'm not sure that mixing two SPDIF signals is quite so easy - I think you'd have to have both VF-type machines slaved to the digital clock on the submixer.
It's a while since I read the Fos FAQ but I think they suggest sacrificing two tracks on machine #2 to bring in the stereo out (SPDIF) of machine #1. Machine 2 is set to slave for both MIDI and SPDIF. The advantage of this is that it means your monitoring arrangements aren't too different from a single machine, and you can still use internal mixdown, on machine #2. If you already lose channels as external effects returns or for external MIDI modules then maybe a small mixer between the two could combine the output of VF #1 and the other returns. (On the other hand, with all those tracks you could print your MIDI tracks and effects to audio!) The aux busses could be submixed using a small mixer, but internal effects would have to be set up separately on each machine. I think I need to stop talking about this - I'm beginning to think I want to do it! Orc |
| Studio Clocks | Dr Unedumacated | Recording Techniques | 9 | 02-07-2008 21:07 |
| vf160 and multiple adat sync | slmnsam | Fostex Forum | 1 | 03-30-2005 07:19 |
| How to set up sync tracks or sync tones | buddyC | Digital Recording & Computers | 1 | 08-28-2001 11:53 |
| Here is a solution for Midi Sync with a VR800 as the Master using Cakewalk! | Rish | Fostex Forum | 0 | 12-12-2000 13:32 |
| Help on using Sync feature on a 4 track | futuredays | Analog Only | 3 | 09-28-2000 17:26 |
