Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 07-15-2005
david7287 david7287 is offline
Newbie
david7287 is on a distinguished road
Computer Speakers with cubase LE
I just got a fire pod and i want to use my computer speakers that are connected through my sound card with Cubase LE. The phone jack on the firepod is all that will work. I looked through the manual but didnt find anything. Please help!!
Old 07-15-2005
ukejammin ukejammin is offline
Newbie
ukejammin is on a distinguished road
you might need to make sure the presonus asio driver is selected in device properties vst multitrack, also sometimes you need to bring up the presonus mixer. hope that helps.
Old 07-15-2005
apl's Avatar
apl apl is offline
Stand Up Comity
apl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond repute
The Firepod and internal soundcard are incompatible, since there is no way to sync them. You should monitor through the Firepod. You can plug your speakers into the appropriate Firepod outputs.
The fabulous Naiant Mics, perfect for acoustic instruments!
If you don't have DavidK's CD, you are a loser.
My tunes. Thanks!
NB
DA BEARS!
Old 07-15-2005
Newbie
So how can i master and mix my recordings after being finished with the firepod.................just slected something in the VST outputs?
Old 07-15-2005
apl's Avatar
apl apl is offline
Stand Up Comity
The normal method is to use the Firepod to send the mix to the monitors. I suppose you could turn off the Firepod, and redirect your software to use your internal soundcard, but that would be atypical.
Why wouldn't you want to monitor through the Firepod?
My tunes. Thanks!
NB
DA BEARS!
Old 07-17-2005
PHILL2796 PHILL2796 is offline
Newbie
PHILL2796 is on a distinguished road
Are computer sp. external if so hook them up to the firepod.
You should go into the bios and disable the onboard sound.
Old 07-18-2005
msmales555's Avatar
msmales555 msmales555 is offline
Senior Member
msmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond repute
monitors
i had the same dilemma when i first got my firepod so i just bought a pair of monitors. but i still like to use my cpu speakers to see how the mix translate to other spearker systems. if you want to do this you have to go to device setup and change the driver from the presonus one to the regular soundcard that your cpu uses (mine is 'something multimedia'). the only thing that sucks is that when you do this, all of the input routings change back to inputs 1 and 2 and you have to go back and change everything if you want to record some more. . . . . but if you are done recording and just want to check out what your song sounds like using you cpu speakers before you export it, then it works great.
Uh oh, computer can't handle Cubase!? JonathanRay Cubase User Forum 9 04-25-2005 18:55
What is causing this horrible feedback on my Bose speakers? WinstonCowboy Mixing / Mastering 2 04-16-2004 12:03
can anyone suggest computer SPEAKERS (not monitors) jhira001 Mixing / Mastering 2 01-27-2004 01:18
sound is delayed when it comes out of my computer speakers jportolese Cakewalk / Sonar Forum 17 06-22-2002 14:43
mia output levels + multimedia speakers? clazymike Digital Recording & Computers 14 01-03-2002 11:43
