Super Noob question- Use QS-8 to play soft synths?
Hello all- I ask for your mercy in advance for what I am guessing is a horribly noobie question:
I have an Alesis QS-8 and use it to sequence in Sonar 4. I am new to the world of soft synths and was wondering if there is a simple way to also use the Alesis as a midi controller (keyboard) in order to play the soft synth lines into Sonar. I would then want to go back to having the Alesis play its own sounds for my other QS-8 MIDI tracks. Is this do-able? If so, what do I have to do with the QS-8 to make this work? Thanks in advance for any assistance!
LSM |
First you need to set up an audio track with the synth you want to use in the FX bin
Then setup a MIDI track with the input set to the MIDI port your QS8 is attached to and the output set to the synth you just setup in the audio track. Set the output of the audio track as you normally do (e.g. wave out...) Now when you press a key on your QS8 you should be hearing the soft synth Once you record the MIDI (and/or the synth audio) you can go back to using the QS8 for its internal sounds Good luck Erich |
Thank you!
Thanks so much, Erich- Sounds easy enough, for sure! I will try it tonite- sure it will work.
Regards, LSM
LSM |
| soft synths | paresh | Newbies | 3 | 05-14-2005 14:53 |
| ASIO Cardbus? Soft Synths only!! | Polaris20 | Digital Recording & Computers | 0 | 03-29-2005 05:52 |
| Major problem: Record analog from Minidisc to CEP. Both tracks play = soft soft sound | kritzer | Cool Edit Pro / Adobe Audition Forum | 2 | 11-04-2003 10:27 |
| soft synths with cakewalk | banjoal | Cakewalk / Sonar Forum | 1 | 11-17-2002 17:27 |
| Help integrating Soft Synths and General MIDI setup for Recording | laj35 | Recording Techniques | 2 | 05-18-2002 01:59 |
