View Poll Results: How would you rate your experience with the D2424LV
Amazing 6 75.00%
Good 1 12.50%
Okay 0 0%
Less than Okay 0 0%
I sold the son-of-a-gun 1 12.50%
Voters: 8. You may not vote on this poll
Old 07-12-2005
Clintage Clintage is offline
Newbie
Clintage is on a distinguished road
Question Fostex D2424LV Experience...
What's been your experience with the D2424LV? Good? Bad? Okay?
I've owned mine for a coupe of years now and it performs like a champ. I'm incredibly happy with it and I'd buy another in a heart beat if I had the money (which isn't that much considering the piece of gear you're getting).
How's it treating you?
Clintage
Old 07-12-2005
rboyce_boston rboyce_boston is offline
Junior Member
rboyce_boston is on a distinguished road
Can I ask what digital mixer (or DAW interface) do you use with your D2424LV? I'm thinking about upgrading from my VF-16, and the D2424LV seems like the most bang for the buck. But I'd like to hear some other user's real world experience with which mixer would make the most sense with the D2424LV. Thanks.
Also...has anyone ever tried linking/syncing any of those Fostex hard-disk recorders (D-80, D-160, D2424LV, etc.) with their VF-16 or VF-160? If so, how did you do it, and how do you mix down to a common stereo source?
TIA,
ray
Old 07-12-2005
PHILL2796 PHILL2796 is offline
Newbie
PHILL2796 is on a distinguished road
I had one tried to use it for live tracking keep breaking down .
BIG JUNK PILE.
Went and got a Alesis so far so good.
Old 07-13-2005
ausrock's Avatar
ausrock ausrock is offline
Feeling Monolithic
ausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond repute
Well that's probably the first time I've seen a bad word about the Fostex "D" series recorders. I've had a D160 running faultlessly for a few years and I'm acquainted with other guys using "D" recorders without any problems..........they normally are "rock solid".
I will add that I'm not refering to actual H/drive failures (which can happen regardless of which brand recorder they are in)......just the Fostex itself.
Old 07-13-2005
Newbie
Could be I just got a bad one maybe made on a friday or monday??
Old 07-13-2005
Dom Franco's Avatar
Dom Franco Dom Franco is offline
Force of Nature
Dom Franco has a reputation beyond reputeDom Franco has a reputation beyond reputeDom Franco has a reputation beyond reputeDom Franco has a reputation beyond reputeDom Franco has a reputation beyond reputeDom Franco has a reputation beyond reputeDom Franco has a reputation beyond reputeDom Franco has a reputation beyond reputeDom Franco has a reputation beyond reputeDom Franco has a reputation beyond reputeDom Franco has a reputation beyond repute
Wink It is a great machine and it has paid for itself many times over.
I have used my D2424Lv to record several commercial CD projects, and made my money back for the unit many times over. On the other hand I spent a fortune on ADAT's and Tapes, and I couldn't give those junkers away...
I kept one ADAT just in case a customer needs it for a transfer or mixdown etc.
Dom
Old 07-15-2005
Newbie
TIA,
ray
I use my fostex D2424lv with 2 Behringer MX3242's. I chose that mixer because it was inexpensive but completely in-line. It has a linking feature, meaning you can hook multiple MX3242's together. I have all of my stuff in a tall, rolling rack because sometimes I have to roll it into the drum room if I'm doing everything myself, otherwise I would've bought something a bit more stationary and all-in-one. They aren't digital, but the work pretty well. Obviously, they aren't the best mixers on earth, but they aren't bad.
I sync my Fostex with my computer and Echo Layla24 and transfer all of the tracks to Cubase SX for mixing and mastering. I use the ADAT lightpipe interface to keep all the tracks seperate. Works great. But I've also done some rough mixes not transferring the tracks into the computer. Sound fairly good, but at that stage it's all about the mixing. Then I mixdown to Wavelab on my computer.
I used to own a Roland VS1680 and it was good at the time, but I love this setup much more. Although, not quite as portable.
Clintage
Old 07-15-2005
Junior Member
Clintage-
Thanks for the info.
How many channels of ADAT can you simultaneously send/receive on your D2424LV? Are there 3 "in" ADAT ports as well as 3 "out" ADAT ports?
Thanks,
ray
Old 07-18-2005
Newbie
Clintage-
Thanks,
ray
It has 3 ADAT inputs and 3 ADAT outputs, for a total of 24 in and 24 out simultaneously. Although, my Echo Layla sound card only has 1 in and 1 out so I have to sync up the Fostex and do 3 passes for each song to transfer the tracks into the computer.
Old 07-26-2005
junplugged's Avatar
junplugged junplugged is offline
Busy Writing/Producing...
junplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond repute
Clintage
I don't see that mixer model, I guess they changed.
Old 07-26-2005
junplugged's Avatar
when you guys synch up to upload to sound card, is it realtime?
  #12
Old 04-08-2006
MCI2424's Avatar
MCI2424 MCI2424 is offline
1K Silver Member
MCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond repute
Clintage
It is as close as I can get to the sound of my 2" MCI machine. A great sounding machine if you have to go digital. The converters are nice sounding as opposed to the harshness I have experienced on a few others (Alesis to name one).
I use mine alot for pre-production, and have dumped many tracks right to tape regularly when the performance warrants it.
"Tascam, Fostex or Studers don't make hit records...........people do"
MCI2424 - 2007
connecting Fostex D2424LV gusfinley Fostex Forum 7 11-15-2004 06:47
Some light on D2424LV, please Fede Fostex Forum 7 08-20-2003 08:02
First Experience with Fostex: Not Good donovan1968 Fostex Forum 6 03-17-2003 20:43
Connecting Fostex 280 to computer buda69 Newbies 4 02-03-2002 19:36
Fostex FD-8 with Yamaha Qy700 tokion Fostex Forum 1 01-18-2002 17:06
