Cubase SX 2 to Pro Tools
Is there any way to load and mix in Pro Tools a project that's been recorded in Cubase SX 2???? If so, how? Is there any converter?
Thanx |
I'm pretty sure that you have to do an OMF mixdown. YOu may want to put a beep or something for a marker so you can line up your tracks. Either that or you could mix down each track to a .wav file and load it into pro tools.
Even then the Pro Tools rig would have to be able to import OMF- not all of them can.
Best bet, though it takes a while, setting start and end points and bouncing each track as Echelon mentioned. Then all the tracks will line up in Pro Tools no problem. Or any other program, for that matter. Take care, Chris |
you guys should check this out:
http://www.cubase.net/phpbb2/viewtopic.php?t=15100 somebody wrote a script for cubase that wouls allow you to bounce down all of your tracks individually automatically. just set the parameters and walk away. i haven't had a chance to try it yet, but it seems very promising.
........let's walk down and f**k them all!
| Would you GIVE BACK your Pro Tools system? | SteveD | Cakewalk / Sonar Forum | 22 | 01-15-2006 17:54 |
| Vegas Pro vs. Pro Tools, Cubase,... | Bloodbought | Recording Techniques | 13 | 05-17-2003 12:20 |
| exporting cubase sx files to pro tools? | dune5233 | Cubase User Forum | 2 | 05-11-2003 04:47 |
| Pro Tools Mac VS Nuendo PC | Jason James | Digital Recording & Computers | 8 | 11-22-2002 15:54 |
| Where is the middle ground between PRO TOOLS and MOTU??? | pisces7378 | Digital Recording & Computers | 9 | 06-02-2002 19:37 |
