Sonar/Delta 1010 "Audio Driver Error"
I'm using the latest drivers, and they work with everything else. But I cant select any of the inputs or outputs in Sonar for my tracks, and I keep getting an audio driver error telling me that they either dont support the current format or they are in use by another program.. neither of which seems to be true. Also, Monitor Mixer is in the input section but not the output section.
Sounds like it would be a wise move on your part to call Sonar tech support - if it's not pirated that is. You may have installed it improperly. If it IS pirated.....well.....You're gonna hafta figure it out. The owners manual plainy explains how to avoid your audio driver problems. Occasionally I get that message saying the drivers are in use by another program, but a quick re-start fixes that hiccup. Your other issues are nothing I have ever had to deal with, and I have your same exact set up.
Seem's to have fixed itself, I dont exactly know why. Thanks anyways!
| Delta 1010 driver install | Flash | Digital Recording & Computers | 6 | 05-01-2005 16:49 |
| cubase "AUDIO ENGINE RECORD ERROR"? | sense | Cubase User Forum | 20 | 11-03-2004 17:56 |
| New PC, Sonar/Delta 1010 audio problems | terrapintaco | Digital Recording & Computers | 2 | 07-14-2003 09:59 |
| Crazy Delta 1010 driver problem, help... | tubedude | Digital Recording & Computers | 4 | 11-20-2002 21:57 |
| Another Delta 1010 setup problem. | JimH | Digital Recording & Computers | 20 | 08-09-2001 18:49 |
