Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 07-05-2005
jasonm jasonm is offline
Newbie
jasonm is an unknown quantity at this point
Disconnecting amplifier speaker.
Hi,
I'm looking to record electric guitar from the line out on my Laney LC15. However, what I would ideally like to do is disconnect the speaker first by unclipping it from the two speaker clips in the back. So basically the question is - is this safe to run the amp like this or could it damage it in some way?
Thanks
Old 07-05-2005
boingoman boingoman is offline
moldin' oldie
boingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond repute
Yeah, it would probably hurt the amp. Don't do it.
Old 07-05-2005
ggunn ggunn is offline
Crystal Flavolian
ggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond repute
Originally Posted by jasonm
Hi,
Thanks
Don't do it. For probably more info than you really want...
http://www.w8ji.com/demonstation.htm
This site speaks of high frequency transformer coupled RF circuits, but the same principles apply.
Gordon in Austin
http://www.crystalflavola.com
Old 07-05-2005
moldin' oldie
Cool link. We could used that a month or so ago in another thread.
Old 07-05-2005
Newbie
Thanks guys.
So what if I were to connect the amp to a load other than the speaker? As long as it matched (8 ohms in this case) it should be fine? I'm guessing that might get a bit hot though.
Old 07-05-2005
Farview's Avatar
Farview Farview is online now
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
Yes you can use a load resistor. (not a normal resistor)
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 07-05-2005
Crystal Flavolian
Thanks guys.
Yes, but as Farview says, it needs to be a load resistor. These are usually big, wirewound thingies. Check the watt rating of the resistor, too; it should be at least twice the output of your amp. If you fry the resistor, you probably won't know it until your amp fails due to a short or no load condition.
The safest thing to do would be to get a power attenuator (power brake, hot plate) and dial its output way down so you can monitor the power section of your amp while you are recording.
Gordon in Austin
How does diaphragm size/polar pattern relate to mic applications? Chris F Microphones 963 5 Days Ago 16:53
Attention Newbies: Copy and Save This For Reference!!! (Pt 1) Buck62 Newbies 11 03-27-2009 15:57
Attention Newbies: Copy and Save This For Reference!!! (Pt 2) Buck62 Newbies 12 04-25-2005 09:40
facts about speaker power ratings gusfinley Guitars and Basses 18 01-07-2005 15:49
Speaker Amplifier Popcorn Newbies 3 03-19-2001 23:28
