How do you load plugins into Cubase LE?
I'm considering making the switch to Cubase LE from Cool Edit Pro 2.0 after three years of using CEP. I've got a few questions. How do you upload plugins (such as Waves plugins) to use in LE? How do I get sound to play back? (My monitors play through my Delta 44). Where can I find good tutorials to learn this program quickly?
Thanks for your time!
Listen to my songs at: http://www.nowhereradio.com/artists/...y.php?aid=2076 The purpose of a cable is to get stuck under everything in its path. |
Plug ins are straightforward - there is a plug in folder nested in the Cubase programme folder, you just drag the .dll files into it.
Cubase will recognise your delta 44, you just select it as your recording and playback device. The pdf manual that comes with Cubase is not too bad, but if you want a step by step guide Cubase SX Power is in all the bookshops and about 90% of it is applicable (I use Se which is very similar to LE). You are going to have to accept a bit of a learning curve, but it's not too bad and you only have to do it once ![]()
Couple of our songs on Mixposure here |
My Delta 44 doesn't appear anywhere in the device list in LE, but it does in CEP.
Where do I select my Delta 44 to play back audio?
In the VST connections tab, I cant remember right where it is because I'm at work, just go to the top where the file menu is, I think its the 2nd to last pull down menu.. oh here it is. 1. Open the Device Setup dialog from the Devices menu. 2. Select the VST Outputs device in the list to the left. The available output ports on your audio hardware are listed.
Carter MCF Productions |
| Cubase VST/32 5.1 pop/crackle noise | Buzi | Cubase User Forum | 0 | 11-29-2004 11:31 |
| Cubase Sx vs Sonar 3 | Frantz | Cubase User Forum | 31 | 08-31-2004 17:05 |
| cpu load: 100% for 15 minutes during cubase mixdown..normal?? | earworm | Digital Recording & Computers | 10 | 08-14-2004 03:09 |
| CuBase cross platform Question... | giles117 | Cubase User Forum | 14 | 08-06-2004 08:02 |
| Non-newbie Cubase SX sync issues | Taufactor | Cubase User Forum | 2 | 08-04-2004 14:24 |
