Old 07-02-2005
grinnin grinnin is offline
Didgeridoo specialist
grinnin is on a distinguished road
Monitoring with reverb?
New to computer recording, just built a standalone DAW computer and loaded it up with Sonar 4P. Using a Firepod interface
I am recording acoustic instruments, and enjoy monitoring with some reverb to get in the groove while playing. This was easy with my old Fostex vf16, but I don't know how to do it with the computer set up. Is it possible to monitor the input with reverb added, but record the straight signal to the track? Don't know if the software will do this or if there is some way to it with the firepod.
Old 07-02-2005
Paul881's Avatar
Paul881 Paul881 is offline
Look Mom, I can play!
Paul881 has a reputation beyond reputePaul881 has a reputation beyond reputePaul881 has a reputation beyond reputePaul881 has a reputation beyond reputePaul881 has a reputation beyond reputePaul881 has a reputation beyond reputePaul881 has a reputation beyond reputePaul881 has a reputation beyond reputePaul881 has a reputation beyond reputePaul881 has a reputation beyond reputePaul881 has a reputation beyond repute
I have the cut down version of sonar so it might be a little different with Sonar
Go to Options>Audio>input monitoring and select the inputs you want to monitor by clicking on them/it to highlight them/it. Always run the wave profiler when you make any changes in the audio panel (unless you have asio drivers in which case, the wave profiler is disabled).
That should allow you to monitor the inputs without printing the signal with the fx. Simply by clicking "off" the fx in the track-view track removes the fx after you have recorded your track.
ASUS P4PE MoBo/vs 1007 BIOS/2.4 Gig P4 CPU/2 Gig RAM/Win XP/Delta 66+omni /SP-5B monitors/Sonar 7 PE/Trilogy/Atmosphere/Stylus RMX/Absynth3/Kontakt2/BFD XFL/BFD Percussion/BFD Jazz and Funk/POD XT/Z3ta+/Rapture/Lounge Lizard/Akoustik Piano /Latigo/Darbuka
Old 07-02-2005
Samantha C.'s Avatar
Samantha C. Samantha C. is offline
Newbie
Samantha C. has a reputation beyond reputeSamantha C. has a reputation beyond reputeSamantha C. has a reputation beyond reputeSamantha C. has a reputation beyond reputeSamantha C. has a reputation beyond reputeSamantha C. has a reputation beyond reputeSamantha C. has a reputation beyond reputeSamantha C. has a reputation beyond reputeSamantha C. has a reputation beyond reputeSamantha C. has a reputation beyond reputeSamantha C. has a reputation beyond repute
Hi there.
You can monitor with effects in Sonar 4 if you have your latency set low enough. You'll likely need it profiled for 2ms or lower (if possibile on your system). Otherwise you'll hear a noticable delay from when you strike a note on your acoustic and actually hear it in your headphones (the time it takes Sonar to process the signal in real time).
Also, since you'll be monitoring through Sonar, you'll likely need to mute your firepod outputs via the firepod control panel, otherwise your signal will be doubled.
To try it out, just open up Sonar and throw a reverb in the effects bin. Go to Track > Input Monitor / Echo (or select the Input Echo button the track itself).
Good luck and have fun.
Samantha
Old 07-02-2005
Newbie
Hahaa... Posted at the same time!
Old 07-02-2005
Paul881's Avatar
Indeed...and managed not to say the same thing
Old 07-02-2005
Wow, thanks for the fast responses! I will give these ideas a try.
Asus a8v, Athlon 64 3000+, 1 gb dual channel DDR RAM, 160gb SATA, firepod, SONAR 4 Producer
Old 07-02-2005
guttadaj guttadaj is offline
Perpetual Newbie
guttadaj is on a distinguished road
Another way to handle it (mainly if you have less-than-ideal latency) would be to add the reverb effect to the track at 100% wet and then modify its output level to mix at a good level with the dry signal echoed from the firepod. Set the reverb to no predelay (that will sorta be built in with your latency). Just another way to skin that cat.
-Jeff
Old 07-02-2005
Newbie
-Jeff
Well said Jeff. I should have thought of that.
Old 07-02-2005
Hard2Hear's Avatar
Hard2Hear Hard2Hear is offline
Retired from Audio
Hard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond repute
Or be lazy like me and buy a cheap reverb unit to hook up to your monitoring system.
I always have to give the stupid, lazy point of view.
H2H
Old 07-02-2005
Perpetual Newbie
H2H
Good point, H2H. I am also prone to those points of view but, most of all, usually find myself tied to the "no extra money to spend whatsoever" point of view.
-Jeff
Old 07-02-2005
Newbie
H2H
So funny... that is what I do as well! But I figured that's what he did previously with his old system.
  #12
Old 07-03-2005
Hard2hear said “Or be lazy like me and buy a cheap reverb unit to hook up to your monitoring system. ”
Not sure how to do that with this system. I am currently monitoring with the firepod before the signal even reaches the computer. If I were to put a reverb in the signal path before the firepod input it would be recorded with the reverb. Not sure with the pod if I can hook up an outboard reverb in an effects loop that is only sent to the headphone output and not the recorded track.
Samantha said “So funny... that is what I do as well! But I figured that's what he did previously with his old system.”
Nope, the Fostex VF16 had built in effects.
  #13
Old 07-03-2005
Paul881's Avatar
-Jeff
If you have a limited budget, may I recommend the Lexicon 960L? One free with every $million recording studio http://www.riverproaudio.co.uk/river...SSORS_356.html
Go to the bottom of the web page for details. Thats about $20,000 in US dollars.
  #14
Old 07-07-2005
Well, tried using the sonar plugins during recording. Latency is a problem, so it looks like I''l be using an effects loop with the firepod for monitoring with reverb.
  #15
Old 07-08-2005
Paul881's Avatar
So you didn't like the idea of paying $20k for a hardware reverb unit then?
80's reverb drums and reverb mixing walters Recording Techniques 28 05-17-2005 08:20
Generic Drum Reverb RecordingMaster Drums and Percussion 5 04-08-2005 18:21
Realtime Monitoring (w Reverb) of Live Sound flourish Digital Recording & Computers 1 03-03-2005 13:34
Y-Cables and Audiofile, DMP3 and Reverb flourish Digital Recording & Computers 0 03-02-2005 22:35
Reverb Articles cordura21 Recording Techniques 4 05-17-2002 16:43
