Sonar 4P acting wierd
Just started trying Sonar and I like it! Much. It´s feels stable and competent. But this odd thing happened: A project file I made using the program and had worked on for a copuple of days suddenly wouldn't open, with the error message: "The file you are trying to open isn't compatible with this version of SONAR."
Wtf??!! |
I've seen and heard of this before - although still don't know the cause.
Perhaps there is a problem with one of the plugins you used. If so, you can get around this by opening the project in Safe Mode (hold the Shift Key down while opening the project). This will prompt you to load your plugins one by one. Don't load any of them to start, just to see if you can get the project to open. If successful, you can repeat, adding one plugin at a time to see if you can isolate the problem one. Hope this helps. |
Ok, tried it, but alas, it did not work. The error comes up even if I choose "no to all" plugins to open...
Hope this doesnt happen alot. Several days work can get lost this way. Are some plugins known to do this? I have had problems with SIR myself. But only in one project (the same). It just wouldnt play on account of dropouts... |
Depending on how much work you have put into the project, you might want to contact Cakewalk Tech Support.
WTF!!! It's an epidemic!!!! Is some one maliciously out there trying mess with Sonar. Check this out:
http://homerecording.com/bbs/showthread.php?t=161613 and this: http://forum.cakewalk.com/tm.asp?m=510784 Does anyone know how to fix this problem?
Life's like a box of chocolates, so pick up something sweet and stick with it!] |
I would also agree with the advice of Mod Bod in the cakewalk forum - always use project files to save your work, leaving bun files to the final moment before completion and always make multiple copies. This will also load your files faster too ![]()
ASUS P4PE MoBo/vs 1007 BIOS/2.4 Gig P4 CPU/2 Gig RAM/Win XP/Delta 66+omni /SP-5B monitors/Sonar 7 PE/Trilogy/Atmosphere/Stylus RMX/Absynth3/Kontakt2/BFD XFL/BFD Percussion/BFD Jazz and Funk/POD XT/Z3ta+/Rapture/Lounge Lizard/Akoustik Piano /Latigo/Darbuka |
It has happened again! With another project. I am very close to crying and kicking in my monitor!
No, changing names and copying doesn't work. Nor does it seem to have anything to do with any special plugins. It happens when my comp has frozen, stuttering on a sample (it does this sometimes, it probably has something to do with my soundcard). Between working and non-working file I have not added any new plugins. The thing that happened was the comp freezing up (several convolution-based plugs made this happen, even though the cpu count was at 29%). |
Ok, looking in over at Cakewalks forum it has become clear that this happens when one is forced to reboot the comp when SONAR is still running. And that Cakewalk basically seem to not give a shit, or being able to help or fix this.
Check this thread: http://forum.cakewalk.com/tm.asp?m=4...atible񶆥 |
Ok, to save yourself from this happening, take these steps: Let SONAR auto-update, but choose the "every xx changes" instead of time. This way the autosave won't interfere with playback/recording. Be careful with convolution-plugs. Don't run more than one at a time.
| Sonar 4.......some questions | Magnum | Cakewalk / Sonar Forum | 25 | 07-15-2006 11:27 |
| Sonar and UAD1 fans | Middleman | Cakewalk / Sonar Forum | 18 | 01-29-2005 01:38 |
| MTC and sync problems with Sonar and Akai DPS16 | PhillipT | MIDI Mania | 3 | 01-12-2005 14:50 |
| Q80 to Sonar = bad midi transfer | Lostinspice | Cakewalk / Sonar Forum | 8 | 08-05-2003 07:12 |
| Just an idea for Sonar.... | Still' Dreamin' | Cakewalk / Sonar Forum | 10 | 08-14-2002 16:11 |
