Old 06-29-2005
ido1957's Avatar
ido1957 ido1957 is offline
4K Silver Member
ido1957 has a reputation beyond reputeido1957 has a reputation beyond reputeido1957 has a reputation beyond reputeido1957 has a reputation beyond reputeido1957 has a reputation beyond reputeido1957 has a reputation beyond reputeido1957 has a reputation beyond reputeido1957 has a reputation beyond reputeido1957 has a reputation beyond reputeido1957 has a reputation beyond reputeido1957 has a reputation beyond repute
Front to Back Reverb Settings
I'm trying to get a bit more depth in my recordings - front to back. I can get one instrument loduer than another but I'm wondering is there a setting on my reverb unit that could help with front to back effect?
I track using reverb but I am very "newbie" and tend to keep the same settings all the time so there is no difference between tracks.
I do not have an eight channel reverb - like a Lexicon 960 - only a stereo reverb. I assume a 960 would give you the ability to adjust depth on a variety of tracks during so downmix.
I usually track with reverb - or can I do it on downmix with a stereo reverb unit?
Thanks
Old 06-29-2005
sweetnubs's Avatar
sweetnubs sweetnubs is offline
Force of Nature
sweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond repute
Reverb is commonly used to set "front and back depth" in a mix. The idea is the more reverb applied to a track the "farther back" it appears in the mix. Pretty much as simple as that. If you are tracking everything with reverb then it is harder to use this technique. I usually try to track without effects but sometimes you gotta, especially if the person's playing is compromised without them. You can always put reverb in the headphone feed so the musician hears reverb while tracking but the actual track is recorded dry. This way you can control the amount of reverb during the mixing.
Old 06-29-2005
SouthSIDE Glen's Avatar
SouthSIDE Glen SouthSIDE Glen is offline
independentrecording.net
SouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond repute
Along with the reverb, sometimes using a little EQ cut to deaden some of the high frequencies in the 'verbed signal (say, above 5 or 6kHz) gives an increased feeling of depth. The flipside is also true, slightly enhancing the higher freqs can enance the "presence" and bring a sound "forward" in the mix.
G.
Glen J. Stephan,
SouthSIDE Multimedia Productions
RECORDING RESOURCES AND INFO SITE:
Mixing secrets by sonusman s_o_n_u_s_m_a_n Mixing / Mastering 261 05-14-2009 19:26
Standard Reverb RecordingMaster Recording Techniques 2 04-05-2005 09:14
settings for reverb from a delay pedal? AlfredB Guitars and Basses 3 03-27-2005 17:49
Getting good reverb out of an audio track in Pro Audio 9? Faust Cakewalk / Sonar Forum 10 06-19-2004 08:04
Putting reverb on a soundfont Faust Cakewalk / Sonar Forum 1 06-10-2004 08:56
