Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 06-27-2005
Bassmusic808 Bassmusic808 is offline
Junior Member
Bassmusic808 is on a distinguished road
Contemporary Mixing Techniques?
Hello. I'm not sure if this was brought up in another thread, (if so please direct me), but I was wondering if there are any contemporary or "trendy" mixing techniques that are currently being used today? Something that people didn't do say maybe 5 years ago.. I hear that using lots of compression is something heard in popular music.. Anything else??
Old 06-27-2005
JazzMang's Avatar
JazzMang JazzMang is offline
He's Junktastic!
JazzMang has a reputation beyond reputeJazzMang has a reputation beyond reputeJazzMang has a reputation beyond reputeJazzMang has a reputation beyond reputeJazzMang has a reputation beyond reputeJazzMang has a reputation beyond reputeJazzMang has a reputation beyond reputeJazzMang has a reputation beyond reputeJazzMang has a reputation beyond reputeJazzMang has a reputation beyond reputeJazzMang has a reputation beyond repute
Just listen to the music on the radio.... It seems we all need to use more 'suck' in our songs to make them trendy.
BAM! (Filling the BAM quota)
www.myspace.com/thefallenskies
Old 06-28-2005
Paranfer Paranfer is offline
Newbie
Paranfer is on a distinguished road
In fact, there's some * RULES * to follow, but without a 10 000 $ - 100 000 $ studio
monitors, we can't really say anything to help that much, I mean to be able to produced materials like * PROFESSIONNAL *.But here's some guidelines that I'm pretty
sure you would like to know.
First of all, record your sessions the best way you can, like a 24 bits and 48 khz or 32 bits and 196 khz ( professional studio ) recording session ( if you can't, then do it at 16 bits 44.1 khz ).
Second, when recording, track each instruments also around -6 db, don't push it to distortion ( if your soundcard got a * mixer software or something like that, check if the level exceed 0 db, so use your ears and your eyes,be sure not to * Clip *, because after, it's too late ).
Third, when it's time to mixdown, apply all the effects and things like that on every
track you want some, all the effects you want in the song gotta be there,but remember
not to exceed - 6db ( on your master fader and try to keep this master fader at 0 db ) for this mixdown, people call it headroom, really helpful for the * mastering * time.
So do the best mixdown you can by keeping the level of your master fader around
- 6 db and export this session as a stereo intervealed tracks
( most people do it that way ) or as a multiple mono tracks ( 2 mono tracks ),
and export this mixdown the best way you can ( 24 bits 48 khz .... )
Fourth,open a new session with the mixdown you made ( the stereo or the mono mixdown, try it both way and see and hear the difference )
You now have 2 tracks at - 6 db with faders at 0 db
On this mix use a little of this in that order ( usually on a bus ):
First, use a little bit of EQ,
Second, use a compressor but don't compress to much ( ratio 2:5 )
Third, you can EQ again to had a smooth sound but be carefull.
Fourth, use a limiter to be sure nothing exceed 0 db on the master fader.
Fifth, try differents ways of using these * master tools * and hear what it sounds like.
Finally,export this mixdown again the best way you can.When it's time to burn it to a cd,then convert the songs at 16 bits and 44.1 khz.
With these guidelines,I think this is a good start to understand what kind of
* mixing techniques * engineer used, but like I said, I don't own a 100 000 $
recording studio.Also, read some articles about acoustic treatments because
maybe the room you're mixing in is a BIG problem,maybe your monitor speaker don't
handle from 50-20000 khz, where you should placed your speaker in the room....
So that's it, and I think a lot of people have their on way of doing things,
I guess people will post a lot in here, but I was giving it a start, so here is it...
The only thing that God promised us is death.
Until then, it's me, my people and my music.
Old 06-28-2005
ez_willis's Avatar
ez_willis ez_willis is offline
Virtual Ninja
ez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond repute
Autotune and Bobbleheads!
Originally Posted by 60's guy View Post
You win.
Old 06-28-2005
Newbie
Forgot to say something real important !
I forgot to say something really important in my last post,so here it is:
DON'T FORGET TO PAN ONE RIGHT AND PAN THE OTHER LEFT ( STEREO )
DON'T FORGET TO PAN RIGHT AND PAN LEFT
Old 06-28-2005
Newbie
Also the ratio is like ( 2,5:1 ),not 2:5,sorry i hit the wrong....
Old 06-28-2005
Junior Member
Thanks for all the info Paranfer. I'll have to read through it a few times to get it.
I know technology has changed quite a bit in the past decade, so I was wondering if techniques have changed also. I guess you might need those expensive equipment to use some of those techniques, hm?
Old 06-28-2005
Newbie
Not really, I own a 10 000 $ home recording studio since 2000,I'm an Audiovisual Technicien and i can say that by sharing each other knowledge,by reading a lot of
articles, it's going better and better and better.But everything i post before is what
MOST of the people do in the industry,But like I said,ACOUSTIC ROOM,( 20 000 $ ),
MONITOR SYSTEM ( 20 000 $ ),is what make a COMMERCIAL CD.BUT,with a 5000 $
or 10 000 $,you CAN REALLY do some great things, and also have a good sounds,
just keep working and working and working and reading and reading and experimenting...until you have a 100 000 $ recording studio.HA ! HA !HA !.
Just do the best you can and one day I'm pretty sure YOU gonna be satisfied.
Old 06-28-2005
treymonfauntre's Avatar
treymonfauntre treymonfauntre is offline
Magic Bag Of Sounds
treymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond repute
i bet you got a pretty bad grade in your elementary school english class
Old 06-28-2005
mixandmaster mixandmaster is offline
Senior Member
mixandmaster is on a distinguished road
I can't think of a single mixing "innovation" in the last five years that I hadn't heard in some form before...I would say that people are finding ways of pushing the edge of the frequency spectrum with hip hop having led the way with subbass usage, but other than that, not much has changed. Certain genres have mixing "characteristics" that fall in and out of style, but no significant or groundbreaking "techniques" come to mind.
Nothing like automation, digital editing, and even multitracking, etc. that were here way more than 5 years ago.
I think the gear manufacturers are focusing on making things more affordable in terms of their innovation rather than developing NEW boxes/effects/whatever.
papa
www.mixandmaster.com
Old 06-28-2005
FALKEN's Avatar
FALKEN FALKEN is offline
FALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond repute
things in the last 5 years are a lot more dry.
  #12
Old 06-28-2005
Newbie
Yes,you're right, BUT I'M a French Canadien,First,english is my second language,I think
anyway that people are able to undestand me anyway,I would like to see how you do
in french,
Peût-être que tu n'arrivera pas a saisir un seul mot de c'que j'viens d'dire,
c'que je peut t'dire c'est que j'suis un technicien en audiovisuel et je possède un certificat de niveau collégial,donc je connais très bien mon français comme tu connais
ton anglais,j'pourrais donc m'passer de tes commentaires alors que la plupart des gens
ici me comprennent quand je pose des idées.Si tu m'as compris,réplique avec une phrase complète que je peux comprendre, ne français,bien sûr. OK !
Anyway I'm here to share each other knowledge,that's it......
I don't need this kind of post when most of the people understand me when I'm posting.
  #13
Old 06-28-2005
Newbie
My last post was for TREYMONFAUNTRE.I know I've a bad english,but I think
there's another way to say to people, * I bet you got a pretty bad grade in your elementary school english class *, just tell me you don't understand me
clearly,your the first to tell that and I don't like the way you've done it.Like I said,FRENCH is my FIRST language.
  #14
Old 06-28-2005
7string's Avatar
7string 7string is offline
Force of Nature
7string has a reputation beyond repute7string has a reputation beyond repute7string has a reputation beyond repute7string has a reputation beyond repute7string has a reputation beyond repute7string has a reputation beyond repute7string has a reputation beyond repute7string has a reputation beyond repute7string has a reputation beyond repute7string has a reputation beyond repute7string has a reputation beyond repute
Originally Posted by Paranfer
In fact, there's some * RULES * to follow...
<mucho deletedo>
Wow. Very informative! I tried the two separate tracks as well as the stereo interweaved and A/B'd them. What a difference! The separate tracks seems to widen the stereo field a bit more and was much cleaner, although much quieter. I even tried bringing up the stereo tracks under the separate tracks a bit just to see what it would do, but I didn't like it.
<edit> Forgot to add this:
What I did was run the two separate tracks into a bus as well as the stereo tracks. That bus was compressed. Then that bus was sent to another bus which was dithered and then in to another bus for limiting. I used separate busses so I could keep track of what was going on at each stage. It seemed to even everything out more. I'm going to spend some more time listening back and forth and see which I like more.
Again, very informative and I enjoyed the experiment!
7
Friends don't let friends mix drunk...
You can lead a horse to water... but he has to put on his own scuba gear...
I'd give my right arm to be ambidextrous...
I like the tempo but I don't like the beat. I give it a 6, Dick...
  #15
Old 06-28-2005
Newbie
No problem my friend,it's a pleasure.It's all good if that help and if you enjoyed the experiment ! Just keep doing it better and better....and enjoy my friend !
Whats The Point Of Mixing Anyway!! Raydio Mixing / Mastering 35 04-08-2005 19:25
Curious about stereo mixing techniques jake-owa Mixing / Mastering 17 10-14-2003 03:17
Mixing techniques for Cool Edit Pro 2.0(or other versions) Atillah Cool Edit Pro / Adobe Audition Forum 1 07-19-2002 21:55
Novice Mixing VSpaceBoy Mixing / Mastering 3 06-11-2002 15:08
