Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 06-27-2005
TropicAllegro TropicAllegro is offline
Newbie
TropicAllegro is on a distinguished road
Aux and Bus?
This is probably a stupid question but I've heard a lot about aux's and buses and have no idea about their function, importance or when you use them.
Can anyone clue me in as to what they are?
Thanks.
Old 06-27-2005
bennychico11's Avatar
bennychico11 bennychico11 is offline
bennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond repute
An aux is usually referred to an auxilary track. In the digital world some people use it to send several signals to it so you have one track that controls the volume of all the other ones. In the both the analog and digital world it's also used for effects. This way you can assign a reverb to the aux track and still have the original dry signal on the other track. So when you turn up the aux level (also called the aux send) on a track you'll be turning up how much is being sent to the master aux track...in this case the reverb. But the signal on the original track still passes through like normal. In other words, you're just copying it to the other one.
A buss/bus is just a pathway from one place to another. Just like the bus in your city that takes you from place to place, a bus sends signal from one place to another. If someone says, "Let's bus channel 7 to channels 3 and 4," they just mean send channel 7 to channels 3 and 4. It is also possible to bus a channel to 3/4 but still keep it on 7....or bus it to 3/4 and remove it from channel 7. For example, if channel 7 on your mixer is not working (you'd do this more often on larger consoles)
hope this helps
www.redlabaudio.com
Old 06-28-2005
Newbie
Thanks man, that clears it up.
Still going to take some time to learn to apply it but I have a much better understanding of it now.
Old 06-28-2005
ecktronic's Avatar
ecktronic ecktronic is offline
Mr Mix and Master Man.
ecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond repute
You can use an Auxiliary track as an input for recording. This means you can add an effect to the signal as it is recording so the effect is printed on the recording. I use a hard compressor on the way in to avoid any peaks when recording. Set your input to an aux channel, put a compressor or maybe limiter on it and then buss the output of the aux track to the track you want to record to. ie. Input- aux - track1 (for kick).
But once recorded the effect is printed on so cannot be undone. So that is why i only use this method to stop peask rather than to add an effect that changes the sound in a way i want it to. That is left to the mixing stage.
Million dollar ears.
CRYSTAL MIXING
MY BAND
aux bus - specific question etnoziroh Mixing / Mastering 3 03-22-2005 15:49
aux bus question? Wireneck Other Equipment and Reviews 4 12-16-2004 07:36
mpx 100 > Q10 > Sonar/insert & Aux bus ? bullyhill Digital Recording & Computers 2 09-04-2003 07:00
Aux Bus Problem Rick Clare Cakewalk / Sonar Forum 7 04-06-2003 16:39
Aux Questions sibleypeck Mixing / Mastering 4 02-08-2002 17:37
