Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 06-27-2005
davefromfade davefromfade is offline
Newbie
davefromfade is on a distinguished road
+4 vs -10 : how do i use +4????
I've read a great deal about +4dbu and -10dbv. My console supports
both as well as my M-Audio Delta 44 soundcard. Everything I've read says you want to be using +4 since this has more headroom and less sensitivity (more room to play with the dynamics) than -10. However, when I set my soundcard to +4 output and my mixer as +4 on the input from the soundcard output and PFL the channel, my mixer shows a continuous clip light which registers over +10dbu. So, can someone explain the difference between the two and how I achieve a +4 environment with the equipment I have. I think there is just something that I am missing here.
Old 06-27-2005
reshp1's Avatar
reshp1 reshp1 is offline
1K Silver Member
reshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond repute
Are you pluging the soundcard out into the preamp/mic in on the mixer, oure are you using the "LINE IN?" Also, turn the trim/gain knob on your mixer channel all the way down.
I wish my lawn was Emo so it'd cut itself.
Old 06-27-2005
Newbie
i'm plugging the sound card outputs in to a stereo line input in my mixer (channels 9/10), which has a -10/+4 switch at the top, no trim knob.
i recognize your icon from a picture i saw on an ebay ad for an alesis dm5!
Old 06-27-2005
mshilarious's Avatar
mshilarious mshilarious is offline
Faithful Departed
mshilarious has disabled reputation
+10dBu shouldn't clip a +4 mixer. Clipping should be more like +22 dBu or more. Given that 0dBFS is probably +19dBu, I don't think it's surprising that your meter reads +10dBu.
Old 06-27-2005
Newbie
it's way beyond +10. that's the highest reading on my meter before the clip lights, which are constantly on as long as i satisfy the following conditions:
1. line in set to +4
2. sound card out set to +4
if i set the soundcard and my mixer for -10, the meter reads fine, although something is not calibrated because my sonar meter shows 0db and my mixer shows about -2 to -4. so, that's something that would need to be addressed as well.
i guess i'm really trying to figure out how to get +4 performance and headroom without completely sending the mixer input in to overload. haven't been able to figure it out. unless that is something that is specifically for professional studios only because of their architecture or something.
Old 06-27-2005
Faithful Departed
What mixer are you using? It sounds like your meter is calibrated to -10dBV. It also sounds like the +4 switch isn't working properly; it should pad that input 12dB. Set your soundcard at -10. What does the signal through the mixer sound like? Does it drop 12dB when you engage the +4 switch? Can you see that drop on the meter? Or maybe the PFL switch bypasses the -10/+4 switch? It shouldn't, but I'm grasping at straws here Check the meter with the PFL off and the fader set at unity.
If your card is set to -10dBV, then 0dBFS should be 12-15 dB higher than that, or +2 to +5 on your meter.
I think there is a misunderstanding here. +4 gear typically has more headroom than -10 gear. But with a given piece of gear, you'd have more headroom padding the input (which is what the +4 switch does) and leaving the source level low (-10). You should have identical headroom when set at -10/-10 or +4/+4, if everything is working properly.
Anyway, you shouldn't have to worry about headroom with a digital source input--it's fixed at 0dBFS max. As long as your mixer is set such that 0dBFS doesn't clip, you don't need any more headroom than that.
Old 06-27-2005
Newbie
Behringer UB1622FX-PRO
No, when engaging the +4 switch, it applys significant gain to the signal, not reduction. The meter increases to +4 when PFL'd.
That's true.
Old 06-27-2005
Faithful Departed
OK the manual says:
Originally Posted by Behringer
LEVEL
For level matching, the stereo inputs . . . have a LEVEL switch to select between +4 dBU and -10 dBV.At -10 dBV, the input is more sensitive than at +4dBu
OK, only two possibilities to reconcile this with your statement: your mixer is broken (the switch was wired in reverse); or, you are confusing the switch settings. It's hard for me to tell from a picture, but it looks like up is +4 and down is -10.
Old 06-27-2005
Newbie
yes, it appears as if the switch was wired in reverse since depressing the button (-10dbv) actually adds gain to the signal. so, it is working in reverse. the way i have it set right now is the only way that it won't clip the meters on my mixer:
-10dbv out of soundcard
+4 line in from soundcard to mixer
however, the pfl meters on the mixer do not match the stereo master bus meters in sonar. if everything was calibrated properly, they should be equal (i'm assuming).
Old 06-27-2005
Faithful Departed
No it's supposed to work that way! I don't get why proper settings are clipping though.
One thing to be aware of is that the clip light on that mixer probably comes on way too early. Given the max operating level of +22dBu, why does the clip light show at +13 dBu or so? That might make you think there's a problem with +4 when there actually isn't.
My concern with your level mismatch is that the card is probably expecting -10 inputs, and if the Behri is sending +4 outputs, then you'll have to roll off 12dB to avoid clipping, which makes your meter on your mixer useless for tracking.
