radio compression
my local radio station compresses the living snot out of everything...my best guess would be somewhere between 4 and 20:1 at -30 threshold. would it be a good idea to set something up that simulates this abuse to see if my mix holds up?
Yes, at the end of your mix. I would not advise trying to actively mix through that compression window however. Just remember, the radio sounds you are hearing are either 2x or 3x compressed.
Once, if you have used buss compression on the final mix. Twice, after the mastering engineer was finished. Third, radio compressors.
This is just a test |
Might be. Listen to your mix in Mono to see if it holds up then as some radio stations might broadcast in mono.
Keep in mind also that radio stations use a really low bit-rate.
G. |
How about *virtually infinite*. G. |
Okay, okay guys. Sorry, I guess I'm wrong. The program i use to convert .wavs to mp3s has the different bit-rates listed and the lowest one says 'radio quality'. My bad. :-(
uhh no; where I live they play crappy mp3s all the time. coupled with the horrid compression, you really can't tell what was recorded in a million dollar studio and what was recorded in some guy's bathroom.
But that's not even the question here; the question was what bitrates radio stations broadcast at. The answer is they don't - not in the sense we know. Not counting satellite radio (which they weren't talking about), radio is analog broadcasting. G. |
#12
why would they do it??? laziness. hell, I've even heard the windows "chime" go off in the middle of a song. for a good 2 months they had a bad cable somewhere in the system and it would crackle. apparently they never herad it in the studio. ridiculous.
and, the question is, what settings should I use to emulate this, and is it even worthwhile, and does anybody else do this? |
#13
But if you're really not shooting for radio play, but expecting mostly CD play, then stick with good sound instead of loud sound. When on your own CD and you don't have to follow some square wave of a recording like Joan Osborne's "Our Love Is Alive", people will be much more impressed by clean sound and solid dynamics than they will be with in-your-face-used-car-sales-commercial loudness. G. |
#14
Just poop on the mix and see how it sounds.
Congratulations! You have successfully emulated radio! ![]() |
#15
Some stations even add some verb. Especially oldies stations, but it's become popular again in the last few years.
7 Friends don't let friends mix drunk... You can lead a horse to water... but he has to put on his own scuba gear... I'd give my right arm to be ambidextrous... I like the tempo but I don't like the beat. I give it a 6, Dick... |
#16
In retrospect a vinyl record skipping now and then doesn't seem so terrible.
«:: «::B::» «::E::» «::C::» «::K::» ::» "Where in the hell are the red M&M's?" ~My Lil' Sister, 1976 |
| Casio WK-1630 = Radio Shack MD-1700 Cat.#: 42-4046 | GeorgeG3 | Keyboards and Sound Modules | 3 | 06-20-2006 13:03 |
| HAyulp! MAstering levels, radio compression etc etc... | Phildo | Mixing / Mastering | 7 | 03-14-2004 19:11 |
| Someone explain compression ratio... | Crayon Boy | The Rack | 2 | 11-08-2003 23:12 |
| Compression for radio play. Why? | Chibi Nappa | Mixing / Mastering | 14 | 07-24-2001 00:52 |
