Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 08-31-2000
CharlesThomas CharlesThomas is offline
Senior Member
CharlesThomas has a reputation beyond reputeCharlesThomas has a reputation beyond reputeCharlesThomas has a reputation beyond reputeCharlesThomas has a reputation beyond reputeCharlesThomas has a reputation beyond reputeCharlesThomas has a reputation beyond reputeCharlesThomas has a reputation beyond reputeCharlesThomas has a reputation beyond reputeCharlesThomas has a reputation beyond reputeCharlesThomas has a reputation beyond reputeCharlesThomas has a reputation beyond repute
I have some Event 20/20 monitors coming for my studio.
Ideally, how far away should they be for proper listening? I have noticed that perception of bass varys greatly depending on ones distance from the speaker.
I'd like to mount them the proper distance from the mixing console to give me the right idea of bass in the mix.
Thanks for any tips!
CT
Old 08-31-2000
Emeric Emeric is offline
Emeric has a reputation beyond reputeEmeric has a reputation beyond reputeEmeric has a reputation beyond reputeEmeric has a reputation beyond reputeEmeric has a reputation beyond reputeEmeric has a reputation beyond reputeEmeric has a reputation beyond reputeEmeric has a reputation beyond reputeEmeric has a reputation beyond reputeEmeric has a reputation beyond reputeEmeric has a reputation beyond repute
From Events site:
'As a rule, the two speakers and the listening position should form an equilateral triangle, with the sides of the triangle ranging in length from four to six feet. Notice, too, that the 20/20bas speakers are identical. Either speaker can be used on the left or right side, and the speakers can be used with equal success in the upright (tweeters on top) or side (tweeters pointing outward) positions. Avoid placing the monitors in corners, against walls, or on surfaces that physically couple to resonant objects, as these situations can alter the low frequency response.'
So, where you end up in the equilateral triangle all depends on the distance you have the speakers apart. Mine are about 5' apart. I remember sonusman mentioning he backs up from the monitors occasionally to check bass content - longer wave.
Old 09-01-2000
Buck62 Buck62 is offline
Blah, blah, blah...
Location: Chicano, Illinoyez... a.k.a. "Guadal-o'Hara North"
Buck62 has a reputation beyond reputeBuck62 has a reputation beyond reputeBuck62 has a reputation beyond reputeBuck62 has a reputation beyond reputeBuck62 has a reputation beyond reputeBuck62 has a reputation beyond reputeBuck62 has a reputation beyond reputeBuck62 has a reputation beyond reputeBuck62 has a reputation beyond reputeBuck62 has a reputation beyond reputeBuck62 has a reputation beyond repute
Cool
Ed...
What's the ideal surroundings for listening to a mix on monitors?
I have my studio in my basement, which has a carpeted floor and wood paneling. But I also built a 4-foot by 6-foot vocal booth, in which the interior has 1 1/2 inches of styrofoam, covered with 2 inches of Auralex Wedge foam.
I take it that mixing inside the booth would be a bit extreme, right?
How could I optimize my listening environment?
Should I have a wall behind me?
I've seen that Auralex portable thingy, but I ain't got that kind of cash.
I'd appreciate some advice on this. Thanx.
Buck
Old 09-02-2000
Blah, blah, blah...
Cool
Yeah...
I guess that's a tough one to answer, especially when you can't physically *see* the room I'm talking about.
I'll study up some more on it... Tanx
Old 09-02-2000
James HE's Avatar
James HE James HE is offline
a spoonfull weighs a ton
James HE is on a distinguished road
Question Ed
When you say three feet, do you mean between the cabinet's or between the center of the cones. Breaking out my imaginary yardstick, My Events are 3 feet apart from the center of the cone. Is this too close? Unfortunatly I can't really get them farther apart. If I did I would probably have to put them closer to the wall in order to keep them symetrical. They are about 2.5' from the wall (wall to the cones)right now. I can't really get them further out than that.
I read somewhere that if you can't get your monitors at least 4 feet from the wall, then you are better off having them right on the wall. I saw some chart about what frequencies get cancelled out at what distances, it made sense to me, but since the 20/20 cabinets are a foot deep, then you can't really put them right at the wall. hmmm... I think I'll try and find that chart again....
-jhe
-jhe
Old 09-02-2000
I was saying edge to edge, I guess center to center would better, mine are exactly 3' 6" from center to center of the speaker.
