Old 06-26-2005
jasongreen jasongreen is offline
Newbie
jasongreen is on a distinguished road
When recording...
Do people usually use a compressor while recording or is this done during the mixdown? I'm recording an acoustic guitar using an MXL 2001 at the 12th fret and an MXL 603S on the soundhole. I have a behringer composer pro, so I could use it while recording....but is that going to give me the result I want? What do most people do?
Also, when we start recording voices, the singer can be quiet at times and VERY loud at others. I don't want her to have to back off from the mic too much, if any, so would I use a compressor for this application?
Old 06-26-2005
SouthSIDE Glen's Avatar
SouthSIDE Glen SouthSIDE Glen is offline
independentrecording.net
SouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond repute
Using anything other than a straight line between the preamp and the recording should be left as a last resort only. If you color the sound during recording and it turns out to not be what you want, there is no good way to undo it without re-recording the track.
As far as the vocalist goes, gently advise her that if she wants to sound good on the recording, she's got to work with you a bit and try to work the microphone a bit better. That means backing off the mic a bit when she's belting it out and coming in closer when she's crooning her quieter passages. Don't be afraid to ask her; it's part of her performance just as much her voice control is. She can only help herself.
If she just doesn't have it in her to work the mic yet, then you might have to apply some light compression during the recording, but try getting it good without the compression first.
G.
Glen J. Stephan,
SouthSIDE Multimedia Productions
RECORDING RESOURCES AND INFO SITE:
Old 06-26-2005
Newbie
thank you very much
-Jason Green
Visit me on MySpace!
Old 06-27-2005
ecktronic's Avatar
ecktronic ecktronic is offline
Mr Mix and Master Man.
ecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond repute
I will put a hard compressor on the way in to ensure no peaks at recording. Typical settings: attack 2ms, Release 20ms, Threshold -3dB, Ratio 15:1.
But i am wanting to try and get tracking done without any efects on the way in as this will yeild better results. Defo.
Million dollar ears.
CRYSTAL MIXING
MY BAND
Old 06-27-2005
fraserhutch's Avatar
fraserhutch fraserhutch is offline
Flypaper for freaks
fraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond repute
A lot of pro engineers gently add compression during tracking. I'm personally with Glen, but I will use it when I have to tame inputs with wild transients.
The fact that no one understands you doesn't mean you're an artist...
Old 06-27-2005
matt rascal matt rascal is offline
Junior Member
matt rascal is on a distinguished road
well...
These days there are many vst and dxi effects out there (many free) that are competetive with good analog effects. If you use effects 'in the box' there are many more options are left open to you and you can see how it fits in the mix with the effects applied. That been said, I sometimes use a slight amount of compression going in if the singer needs it.
Old 06-27-2005
xfinsterx's Avatar
xfinsterx xfinsterx is offline
Metal Dork Extraordinaire
xfinsterx has a reputation beyond reputexfinsterx has a reputation beyond reputexfinsterx has a reputation beyond reputexfinsterx has a reputation beyond reputexfinsterx has a reputation beyond reputexfinsterx has a reputation beyond reputexfinsterx has a reputation beyond reputexfinsterx has a reputation beyond reputexfinsterx has a reputation beyond reputexfinsterx has a reputation beyond reputexfinsterx has a reputation beyond repute
i compress vox, snare, overheads, and guitars on the way in personally.
i just make the signal do what i want.
control it.
everything else goes straight in from the pre.
Chris Finster
Geomana on myspace!
Falcon Recording Studios
Can I get advice from those who have a home studio? Chrisku13 Studio Building & Display 56 08-21-2006 23:20
PC recording, not for the fence-sitters Diragor Digital Recording & Computers 11 02-28-2006 17:26
Best Value Mic(s) for Recording Male Vocals/Martin Acoustics Aceboympk Microphones 20 02-14-2005 13:40
Delta 44 vs. Windows Recording Mixer. God help me. Shepherd Digital Recording & Computers 2 06-09-2003 07:39
