Old 06-26-2005
jeff0633 jeff0633 is offline
Senior Member
jeff0633 has a reputation beyond reputejeff0633 has a reputation beyond reputejeff0633 has a reputation beyond reputejeff0633 has a reputation beyond reputejeff0633 has a reputation beyond reputejeff0633 has a reputation beyond reputejeff0633 has a reputation beyond reputejeff0633 has a reputation beyond reputejeff0633 has a reputation beyond reputejeff0633 has a reputation beyond reputejeff0633 has a reputation beyond repute
Question about the DMP3
Hi guys. I like my DMP3, and it really does nice on acoustic instruments, but this thing seems to be too damn hot. When I hook my AT-3035 up to it, I turn it all the way down and it still drives the line inputs on my recorder into the red, and I am pretty far away from the mic with a quiet acoustic guitar. I know there is a pad button, and that seems to work fine, but am I losing some quality when I use it? Do I lose some of the quiet noise floor, or dynamic range or something? It seems I would since I engage the pad and then have to turn up, doesn't that mean that I am cranking the input higher, losing some noise floor and getting less quality than if I were not using the pad? I can't use that pad without thinking that I mat be sacrificing a little quality. I am hoping this is just wrong and you guys will explain why that I lose nothing at all by using the pad.
Thanks
Jeff
Old 06-26-2005
sdelsolray sdelsolray is offline
Force of Nature
sdelsolray has a reputation beyond reputesdelsolray has a reputation beyond reputesdelsolray has a reputation beyond reputesdelsolray has a reputation beyond reputesdelsolray has a reputation beyond reputesdelsolray has a reputation beyond reputesdelsolray has a reputation beyond reputesdelsolray has a reputation beyond reputesdelsolray has a reputation beyond reputesdelsolray has a reputation beyond reputesdelsolray has a reputation beyond repute
You probably have some mismatch between the output of the preamp and the input of the recrder. A +4/-10 mismatch?
Old 06-26-2005
thajeremy's Avatar
thajeremy thajeremy is offline
registered abuser
thajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond repute
I have a similar problem. Im starting to think it is my soundcard. What kind of card do you have? I have to keep my soundcard levels all the way down and my pre's all the way down...mainly when recording drums though...not much of a problem elsewhere.
also, make sure that you dont have the hi/lo gain button engaged.
Old 06-26-2005
tdukex tdukex is offline
Man of the Muse
tdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond repute
Just read the manual, follow the directions, and you will get good sound. BTW, I don't think the high/low switch is a pad but rather and additional gain stage. If anything, it will probably add noise not decrease it, although the DMP3 is very quiet regardless of the gain.
Old 06-26-2005
Senior Member
I am using a Zoom 1608 16 track recorder, and going into the RCA line inputs. There should be no mismatch. The DMP3 is supposed to send a line level, isn't it?
Jeff
Old 06-29-2005
Paj Paj is offline
Force of Nature
Paj has a reputation beyond reputePaj has a reputation beyond reputePaj has a reputation beyond reputePaj has a reputation beyond reputePaj has a reputation beyond reputePaj has a reputation beyond reputePaj has a reputation beyond reputePaj has a reputation beyond reputePaj has a reputation beyond reputePaj has a reputation beyond reputePaj has a reputation beyond repute
RCA inputs
Jeff0633:
There's the major part of your problem. RCA inputs are usually "consumer" level liputs (-10dB), and line outputs on the DMP3 are on the professional line level side (+4dB). Simply stated, without padding or proper level adjustment, the DMP3 WILL be too hot for those inputs.
God help you if your RCA's are actual phono inputs!
Paj
8^)
8^)
Old 07-09-2005
Richard Monroe Richard Monroe is offline
Been Here, Posted That
Richard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond repute
I'm pretty sure your recorder is looking for a -10dBV line signal. The DMP-3 is putting out a +4dBu signal. Here's one solution:
http://www.8thstreet.com/product.asp...ng_Accessories
I use this when I feed my Korg PXR4 a stereo signal fom outboard pres. Just make sure yoiu use well shielded cables. The transformer is subject to radio frequency interference, and cheap or unshielded cables act as a real nice antenna.-Richie
Old 07-10-2005
amra's Avatar
amra amra is offline
1K Silver Member
amra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond repute
Here's what you need:
Samson - S-Convert +4 to -10 Level Converter
When the government's boot is on your throat, whether it is a left boot or a right boot is of no consequence. – Gary Lloyd
Old 07-10-2005
Yep, those 2 boxes are pretty much the same deal.-Richie
Old 07-10-2005
JM350 JM350 is offline
Junior Member
JM350 has a reputation beyond reputeJM350 has a reputation beyond reputeJM350 has a reputation beyond reputeJM350 has a reputation beyond reputeJM350 has a reputation beyond reputeJM350 has a reputation beyond reputeJM350 has a reputation beyond reputeJM350 has a reputation beyond reputeJM350 has a reputation beyond reputeJM350 has a reputation beyond reputeJM350 has a reputation beyond repute
The 3035 is a pretty hot mic, in other words for the same input it is going to put out more signal than many othe mics, add to that the DMP3 which offers a lot of gain as well and the fact you are running professional +4 level into consumer -10 RCA inputs and you are probably going to have to set the gain knob on the micpre very low on all but the quietest of sources.
Something like the Samson S Convert will help a bit but realize that it is only going to lower the overall gain by about 11db. I would say save your money and simply set the DMP3 on the lower gain position, it's not going to degrade the signal doing this and you will be I think around 25db lower than the high gain setting.
Conflicting Opinions on DMP3 vs Omni Pres? TheOneTrueMatt Digital Recording & Computers 0 01-27-2004 18:06
Stated Testing out the DMP3 Rev E The Rack 20 06-21-2003 18:47
DMP3 to VTB-1? Tomcat The Rack 20 04-08-2003 07:37
Question for DMP3 users omtayslick The Rack 5 03-18-2003 09:27
soundcraft question shadowfax The Rack 1 09-07-2002 22:46
