Go Back   Home Recording > User Forums by Brand > Cool Edit Pro / Adobe Audition Forum
Reply    Audiofanzine Music-software Music-software News Music-software Medias Music-software Tests Music-software Articles Music-software User Reviews Music-software Classifieds Ads
Old 06-25-2005
El Jefe El Jefe is offline
Newbie
El Jefe will become famous soon enough
unwanted fade in
For the last couple weeks, everytime I record guitar tracks, the track kinda fades-in (on playback) like it's overloaded when i hit that first note. Any suggestions?
Thanks!
POWER BASTARD
Midsouth Metal
Old 06-25-2005
thajeremy's Avatar
thajeremy thajeremy is offline
registered abuser
thajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond repute
1. check the track in both edit view and multi-track view and see if you have the same problem.
2. make sure you have not applied any effects to that track.
3. there is no 3 at this time...but ill try to think of something...
Old 06-26-2005
gasal69's Avatar
gasal69 gasal69 is offline
Junior Member
gasal69 is on a distinguished road
Try to record your guitar while your windows mixer is on the top of screen.
It happens that sound card controls signal in automaticly and does not allow it to be to high and fade it down after first too loud signal.
I saw this happened on some other software but it was controling microphone input. Not Line In.
Do you connect your guitar directly to your sound card or using a Microphone?
Still, it never happens on Adobe Audition.
Old 06-26-2005
Newbie
I posted in the newbie forum about not being able to control the amount of bass in the guitar...i had it running through the mic jack instead of line in..I run it through 'line-in' now, the low end is normal and the tracks i record sound great.
I tried recording with the windows mixer open...I have no effects on anything...it does it in edit view, and multi-track view...and since thajeremy had no number 3, i made one up and tried recording with a hat on...still no luck.
From what i've read on here it sounds like it's probably the soundcard, but i've never had any trouble before now...and all i've got on it is a drum track exported from beatcraft/fruity loops..
thanks for the feedback, guys..
POWER BASTARD
Midsouth Metal
Old 06-26-2005
lpdeluxe's Avatar
lpdeluxe lpdeluxe is offline
The Precision Bass Guy
lpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond repute
I don't know what's causing your problem, but my experience, after 5 years with Cool Edit SE, Cool Edit Pro 1.2, 2.0, 2.1, and Adobe Audition 1.0 and 1.5, is that there are a number of arcane settings that trip you up in various ways. I have chided Adobe in the past for not addressing this issue, but I guess with a complex program you run into complex setup difficulties. I know that I have run into baffling problems that turned out to the wrong box ticked in the Settings screen or something similar.
Which probably isn't terribly helpful. So go through the settings, with the help of the manual (or a book based on AA) and see if you can find a solution. The complexity of computer recording is such that problems have not always been duplicated by other users. You can also post a query at http://www.adobeforums.com/cgi-bin/w...HJ.0@.1de98f7a
and perhaps find an answer.
"Digo: 'paciencia, y barajar.'" -- Don Quijote de la Mancha, Part II, Chapter 23
fade out & fade in ? guitar junkie Cool Edit Pro / Adobe Audition Forum 6 01-31-2008 08:34
Masterlink fade outs mr. torture Alesis Forum 5 03-20-2005 08:11
Pro Audio 9/ fade in/ fade out M Havlen Cakewalk / Sonar Forum 3 09-23-2003 05:36
How to handle a long event with only three Fade handles? pumpkin Cubase User Forum 2 01-29-2003 16:28
wow, no way to fade to black in cakewalk9?? tsphillips Cakewalk / Sonar Forum 5 09-18-2002 14:15
