hd24xr LRC
can the cord on the little remote control be connected to 1/4" tr male/ female extension?The fans to damn noisey and i would like to also be able to reach multiple locations through out my studio at least 30 feet away from the hd24xr
Yes it can be extended. I've used one about that long and had no problems.
Mike |
did you use a 1/4" TR male/female cable?????????
TRS, yes.-----
Mike |
TR or TRS???????????????????????????????????
I have connections all over the studio for moving the remote.
I use two conductor wiring (TR). Works like a champ. C |
thanks, alesis just got to my email and confirmed it could be extended.they should have put it in the manual?the reason I asked was i figured maybe the lrc is resistance sensitive other wise how does it know a stop command from all the other options by using just 2 wires????????????
I have been successful extending it using a TRS cable as well. As for the noise, if there was one great thing to do - it would be to solder in a quieter fan. With the new fan, and a quiet HD, you can track in the same room nearby.
where did ya find a replacement fan at?what's the model #?what type of hard drives have you had success with?
http://www.pcpowercooling.com/produc...php?show=VCBSM Regarding hard drives, I used Maxtor DiamondMax 160GB, Seagate Barracuda 200GB, Hitachi Deskstar 120GB in the past with good results. |
#12
I haven't open up my alesis .but does that fan fit with out any mod's to the mounts or the plug/jack.will the plug match up and only fit correctly matching polaritys??????????thanks
#13
The plug doesn't fit, but I only tried the one with 4 pins. I just cut the wires and spliced them together. You could try the smaller 3 pin version. It's quiet, I can't hear the fan at all. |
#14
thanks for the info.I'm gonna open 'er up and check the spec's on the stock fan
#15
Both 3 and 4 pin fans will not fit into the power socket in the HD24. As mentioned, you simply cut off the old fan, strip the wires and solder them together. I then melted heatshrink over the connection. It wasnt a hard job in the least and the difference is very noticable.
As for harddrives - I personally like Seagates as they are quiet and come with a 5 yr warranty. For the fan - http://groups.yahoo.com/group/hd24/message/2027 |
| Alesis HD24XR | jlizard | Alesis Forum | 10 | 01-30-2008 08:14 |
| Questions on HD24XR with Digital Console | TomF | Alesis Forum | 2 | 03-19-2005 09:27 |
| lrc vs brc | notbradsohner | Alesis Forum | 2 | 09-13-2004 14:25 |
| Best Mixer to use with HD24XR | chris-from-ky | Alesis Forum | 19 | 05-11-2004 05:01 |
| Behringer mx2004a fronting HD24XR | chris-from-ky | Alesis Forum | 2 | 02-04-2004 12:01 |
