Go Back   Home Recording > Special Forums > Live Events
Old 06-25-2005
DigitalDon DigitalDon is offline
1K Silver Member
DigitalDon has a reputation beyond reputeDigitalDon has a reputation beyond reputeDigitalDon has a reputation beyond reputeDigitalDon has a reputation beyond reputeDigitalDon has a reputation beyond reputeDigitalDon has a reputation beyond reputeDigitalDon has a reputation beyond reputeDigitalDon has a reputation beyond reputeDigitalDon has a reputation beyond reputeDigitalDon has a reputation beyond reputeDigitalDon has a reputation beyond repute
Recommend a Dedicated Reverb for Live Use
Right now we are using a Behringer Virtualizer Pro for live use. It's ok but not what I'm really looking for. I don't need a gazillion options. I'm looking for a rack mounted, manually controlled (yes knobs) effects unit. Actually could be a multi-effects unit but my main concern is reverb and delay. I don't want to go through menus, I want to turn knobs. I've looked at the Lexicon MPX 100 but see a lot of comments about how low a signal you have to send it to prevent clipping. I know there's a mod to replace all the .22uf caps with .47uf caps which they say substantially improves the sound quality. Doesn't do anything for the low input level required. Anyhow, recommendations would be appreciated. Budget is about $100 so I'm sure it would be an eBay buy of a used unit.
DD
Old 06-25-2005
boingoman boingoman is offline
moldin' oldie
boingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond repute
$100?
Lexicon Alex. Sounds good, very easy to use.
Old 06-27-2005
1K Silver Member
Thanks, I'll take a look at that one.
DD
Sequence of Mixing Reverb Question fluxburn Mixing / Mastering 5 05-27-2004 10:25
Reverb Plug-in Vs. Hardware dudleys100 The Rack 21 03-25-2003 16:20
Midi controllers for Chorus and Reverb Lord Wan Cakewalk / Sonar Forum 0 09-30-2002 06:13
Reverb Plugins - Multi-Track? barefoot Mixing / Mastering 3 08-21-2001 11:17
