Excessive bleeding in Izotope Vinyl
I own PA9, and one of my many plug-ins is Izotope Vinyl, and I was just wondering if It's just me, or does this plug-in have no regard for seperation of tracks. I have it on an aux bus, and 4+5 are the only tracks pulling on that bus, while if i solo any other track, it still pulls on the plug-in. Any feedback.-
Train As You Fight, Fight As You Train. |
Ciao, Q.
<insert something witty here> |
It might be better to think of Vinyl as a sound effects generator instead of a standard plugin, it is really meant to be used for an overall effect on the main stereo output bus, it will generate it's sound effects even if placed on an aux with NO tracks assigned to it.
If you only want it's effects on specific tracks, you could use it as a channel insert one track at a time, solo up the track and bounce the results to an empty track, when you're happy with the bounced track, archive the original and use the effected track, you can then use automation and/or slip editing to remove the Vinyl effect in the sections where there should be silence on any effected tracks. You could also just automate the aux return to silence the effect when there is no audio passing thru it, but that won't change the behavior you're seeing when soloing non-effected tracks. ![]() |
couldn't you destructivly add it to a track?
as in double click the track (in CWPA9) and then add the effect that way? |
not familiar with pa9, but i have sonar... have you tried using automation to solve this?
I'm with Stryder on the destructive editing bit, but automation could solve the problem in what way?
well, about the destructive audio, you could always make a copy of the track you want to save and put it right below that one with mute on it. It would work, just not the BEST way...
| iZotope Vinyl plug-in | adamo_musica | Cool Edit Pro / Adobe Audition Forum | 6 | 05-25-2005 06:40 |
| Post production Bleeding Effect | walters | Recording Techniques | 39 | 05-05-2005 09:48 |
| Problems with cutting to vinyl!! | Shack | Mixing / Mastering | 3 | 07-14-2004 06:43 |
| Can you create an alternative to vinyl barrier? | ob | Studio Building & Display | 10 | 10-27-2002 20:02 |
