Old 06-23-2005
FattMusiek's Avatar
FattMusiek FattMusiek is offline
hates cables.
FattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond repute
What are arguably the best mics for micing classical guitars?
I have an upcoming recording session scheduled for two very good guitarists who play classical and jazz music. I have little experience recording those genres (I record a lot of rock music) and I'm wondering if my mic selection will suffice. My mics are:
Oktava MK012 x2
Shure SM57 x2
Shure Beta 52
Audix F-10 x3
Audix F-12
Audix F-15 x2
What mics do you suggest I use to mic a nylon string classical guitar from what I listed? If you don't think I have the proper mics, feel free to suggest a mic or two that fits the job; maybe I can do some last minute mic shopping. I've searched similar threads for information about mic selection
and mic placement but I decided to make my own for more direct advice.
Thanks for your time!
Listen to my songs at:
http://www.nowhereradio.com/artists/...y.php?aid=2076
The purpose of a cable is to get stuck under everything in its path.
Old 06-23-2005
bennychico11's Avatar
bennychico11 bennychico11 is offline
bennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond repute
out of your selection, i'd say the small condensers (oktavas). condensers definitely capture more of the nuances of the instrument. if you have a large condenser you may like that better on the body. i think most people would use condensers on any acoustic instrument (except maybe very loud, transient stuff)
www.redlabaudio.com
Old 06-23-2005
FattMusiek's Avatar
hates cables.
Thanks for the reply. I listed the Oktavas first because I knew they were probably the best choice. I'm still open for suggestions!
Old 06-23-2005
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
I've had good luck with the Oktavas in a vertical X-Y just "north" of the hole...
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 06-24-2005
giraffe's Avatar
giraffe giraffe is offline
i love negative rep
giraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond repute
i'm gonna say soheps just cause i suspect someone would eventually.
audio?
seriously, give me negative rep.
Old 06-30-2005
FattMusiek's Avatar
hates cables.
Massive Master - Could you elaborate a bit more on your experiences with those mic positions? I need to record these guys simultaneously but I only have two Oktavas.
Giraffe - What are "soheps"?
Old 06-30-2005
Just turn a horizontal X-Y pair vertically - One pointing slightly upward, one slightly downward, around the 15 fret, pointed slightly toward to the soundhole.
Won't do you much good if you need to record both at the same time, though...
Old 07-01-2005
FattMusiek's Avatar
hates cables.
Clip
I used an Oktava MK012 and an Audix F-15 in an X-Y pattern around the 15th fret and got some pretty good results. I think it could be a bit warmer, so next time I think I'll point the mics more towards the sound hole. The guitar was a Takamine; the guitarist who is playing in this clip is going to use his $4,000 classical guitar for the recording sessions. I think there is much room for improvement! Here's my first mix:
http://members.cox.net/fattmusiek/alex%20clip2.mp3
I'm going to post this in the clinic so hopefully I get more opinions.
Some things to think about when choosing mics. Harvey Gerst Microphones 53 1 Week Ago 11:08
Which mics would give my small collection balance and versatility? Samantha C. Microphones 39 06-06-2005 17:32
Classical guitar piece - Two MXL 603s mics Taylor_214 MP3 Mixing Clinic 5 03-27-2005 16:26
A question about electro-acoustic guitars (acoustics with pickups or mics inside them memo Guitars and Basses 18 11-30-2000 00:24
recording classical guitars LI Slim Recording Techniques 2 08-18-2000 00:46
