Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 06-22-2005
warble's Avatar
warble warble is offline
Registered User
warble has a reputation beyond reputewarble has a reputation beyond reputewarble has a reputation beyond reputewarble has a reputation beyond reputewarble has a reputation beyond reputewarble has a reputation beyond reputewarble has a reputation beyond reputewarble has a reputation beyond reputewarble has a reputation beyond reputewarble has a reputation beyond reputewarble has a reputation beyond repute
Help with "boxy" vocal track
Hey all,
I recently recorded three vox tracks using SM58's on each. I'd have preferred to use condensers, but only had one available and all three wanted to record at the same time. To make things a "little" worse, the monitoring through headphones while tracking thing didn't work out either - which means I had to have a little of the instrument tracks coming through a monitor in the room the vocals were recorded in.
For the most part, the tracks turned out surprisingly good with the exception of a "boxy" or "singing into a glass jar" mid-range problem with one of the lead vox tracks. It's only on a very small part of the lead, and really only in that one part of the entire track. I've been tweaking it with EQ but can't seem to center in on at least trying to dimish this sound - even slightly. Is there anything I can do via EQ or some other method to just reduce it? I'm using a gate of each of the vox tracks, so that helps with cutting the bleed when the vocalists weren't singing - just have this little problem I'm hoping to cut down a little.
Any ideas? Or should I just be happy that I got (for the most part) useable tracks?
Old 06-22-2005
RAMI's Avatar
RAMI RAMI is offline
www.ramirami.com
RAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond repute
This has been discussed in this thread. http://www.homerecording.com/bbs/sho...d.php?t=159824
Old 06-22-2005
chessrock's Avatar
chessrock chessrock is offline
Banned
chessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond repute
What probably happened is the singer(s) turned away from the mic for a moment. Usually, they'll do this if they don't know their lyrics well and they're looking down at their lyrics on a music stand / cheat sheet. So what happens is the mic pickes the vocalist up off-axis, and picks up more of the room, which I'm guessing isn't very well-treated if it's sounding boxy.
It can't really be fixed, but it can be prevented. When you hear it happen, stop the singer and explain to him/her the importance of singing right up on the mic, and how looking away even for a brief moment can ruin an otherwise good vocal track.
If you happen to be working with someone who has a habbit of doing this often, then you might consider using a mic that's really strong off-axis, like an Electrovoice RE-20, and treat your room so that any room ambience you pick up isn't going to be all nasty and boxy-sounding.
Oh, and one other thing I just thought of ... if you were tracking all three vocalists simultaneously, it's possible that what you were hearing was a phase issue with one or both of the other mics. You can solve this by gating / silencing the other mics while the lead vocal track is going. Assuming you've got three separate tracks, this should be simple.
Old 06-22-2005
FALKEN's Avatar
FALKEN FALKEN is offline
FALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond repute
just make sure you dont make it worse.
Creating a vocal only track? silver_addict Recording Techniques 5 01-24-2005 08:29
Roland VS 1824CD Davester Roland, Boss, VS Series Forum 36 09-18-2004 14:39
'Secrets' - Acoustic Folk Fem - Violin Solo studioviols MP3 Mixing Clinic 12 12-05-2003 22:42
doubling vocal track guttadaj Mixing / Mastering 2 01-30-2003 06:15
Fattening a Vocal Track dachay2tnr Mixing / Mastering 10 10-11-2001 02:57
