From sonar 4 to sonar 3 (plugin missing)
Hi,
I created a project on sonar 4PE and tried it on a sonar 3PE. The project works fine but when i open it on sonar 3PE, it says it misses a plugin (grooveplayer). I just want this warning to get away, how do i do that? Lapieuvre |
Try holding down the shift key while opening the project. This will start it in "safe mode." You should then get a prompt to load each plugin. Tell it not to load the problem plug-in, and then once the project is loaded, resave it (under a different name if you want to keep the existing version for S4).
Thank you!
| Foxtex VM200: control Sonar via the Universal Control Surface Plug-in & macro player | JJM | Fostex Forum | 2 | 05-05-2005 14:56 |
| SONAR XL 2.2 / Busses Missing from Bus Pane | mark4man | Cakewalk / Sonar Forum | 3 | 04-05-2005 08:51 |
| Use WaveLab's spectrum analyzer in Sonar? | pennylink | Cakewalk / Sonar Forum | 14 | 05-17-2004 01:43 |
| Oriion, Rebirth & Fruityloops with Sonar | acgt | Cakewalk / Sonar Forum | 10 | 09-13-2002 13:21 |
| SONAR + DIO 2448 soundcard = my headache | mime rifle | Cakewalk / Sonar Forum | 0 | 10-25-2001 11:15 |
