I just installed the demo of auto tune 4.0 to play around with and I can see it in the list of plugs in my CD Architech but it is nowhere to be found in sonar 4PE. Any ideas of what I should do?
Be careful of what you say, even more of what you don't |
is it a vst plug in? you may have to refresh your plug in list withthe vst wrapper utility.
www.sanijav.com www.myspace.com/sanijav |
It is the dx version.
have you tried refreshing your plug in list within sonar? i think that commeand is under edit or something. i can't remember.
I've looked for something like that but couldn't find it. Anyone know specifically where a plugin refresh is located? Also I got and installed Vintage Warmer at the same time. No prob with that it shows up in both Sonar and CD Architech.
what directory did you install the working plug in? maybe antares autotune 4 has to be installed in a directory that sonar recognizes as a plugin folder? I always just install my plugins to the plugin folder for cakewalk so i dont' know ifit works otherwise.
I will try that, I just let it do an automatic install. Same with Vintage Warmer.
No luck with that either, same results as the previous try.
Try downloading the Cakewalk Plugin Manager. That might help. I'm guessing for some reason the plugin is being excluded from Sonar. The Plugin Manager will allow you to "unexclude" it (or more properly, include it
).Do a search for it on the Cakewalk site. You will need your Sonar serial number in order to gain access to the download. Once installed, it should show up on your tools menu in Sonar. |
i knew you would come to the rescue...
i always thought that plugin in manager came with sonar... that is what i was thinking of when i suggested the refresh thing.
Thanks, I will try that out.
#12
That did it. I was afraid cuz the download asked for my sonar 2 code, but the code for sonar 4 allowed me to download. Thanks for the help.
| trouble tuning telecaster | futurepet | Guitars and Basses | 5 | 10-15-2004 02:48 |
| MIDI trouble.....does anyone own a DBX Pro Vocal processor | weatherbill007 | MIDI Mania | 0 | 02-05-2004 19:20 |
| Realtime Plugin vs. Offline | clazymike | Cakewalk / Sonar Forum | 4 | 04-18-2001 04:05 |
