Go Back   Home Recording > Equipment Forums > MIDI Mania
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 06-22-2005
torito torito is offline
Newbie
torito is on a distinguished road
Thumbs up Basic help with EWQL Silver sounds and midi
Hi guys, I've been working with midi scores for publishing but only a little for production. I have the EWQL Silver Orquestra wich have amazing sounds for my files, but how can I use them with Sibelius, Cubase sx 3, or Gigastudio 3?
I will upgrade my sound card; but for now Sound Blaster live! is working at least to playback with limited ins and outs. I've been serching in the EWQL web but the documentation does not address this simple issue of how to connect the applications to work together. I know it is a silly question for those experienced users...but for me is all that matters now!
Thanks in advance,
Torito, a rookie
Old 06-22-2005
ssscientist's Avatar
ssscientist ssscientist is offline
Info you can use...
ssscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond repute
Let's take the example of Cubase SX3.
What you have bought is a 'plugin' module that needs to be run from inside a program like Cubase. Plugins extend the capability of audio/midi sequencers by adding 'virtual instrument' capability.
Put the East West Quantum Library '.dll' file into the Cubase VST plugins folder. Then follow the program directions to activate the plugin on a the desired track.
And welcome to the board!
Old 06-23-2005
Newbie
Thanks for the advice...but...
Hi ssscientist, Thanks for the advice, but it did not make a lot of progress. Now the Cubase crashes while loading the EWQL mixer and/or load it on channel 17 and up, well out reach of my sound card, I guess (?) Next week I will install the audiophile 92 sound card
wich will do a better job handling drivers. I had to install a Kx generic driver to
work with Asio drivers. I see the potencial I have with samplers, so I will keep trying.
Thanks again,
Torito
Old 06-23-2005
Info you can use...
Did you put the .DLL file into the VST plugins folder? It sounds like you're still trying to run two programs at the same time.
This is all done from within Cubase. Use a blank song and track number one. Then bring up a plugin --- read the manual for instructions --- then select an instrument and you should be ready to play from your midi controller keyboard.
Old 06-24-2005
Newbie
Yes,
The sub-folder Synths is in the folder VST plugins and contatins the files EWQLSOSilverVST.dll and EWQLSOSDXiVST.dll. Everything is in the Cubase Folder installation. I am not making live music yet, i just
want to play and record my midi files thru the samplers, as I used to do with my old Roland JV-1010. That was easy, but I never heard about VST plugins, sorry. I have problems getting playback with the transporter. It's confusing. It played right the first time when I installed Cubase but after a lot a messing around it does not work for me. Thanks again for the excellent support,
Torito
Old 06-24-2005
Info you can use...
You're giving up? Without getting it working? When you're this close? Seems foolish to me, but OK.
Maybe you need some Cubase-specific help. Atterion and Halion are two current homerecording.com Cubase users and sending each of them a PM (private message) would probably net you more specific info than I can offer.
Old 06-24-2005
Newbie
Of course I'm not giving up! I just realize my limitations.
I've been self taught in computers and know what it takes to learn...as a music educator this is a challenge I have accepted. I will contact those users you mention for more help. This weekend I will install the Audiophile 192 and check some tutorials found at:
http://www.thewhippinpost.co.uk/cuba...-tutorials.htm
They look helpful for me.
I will keep you informed,
Torito
Old 06-24-2005
Info you can use...
Cool.
Old 06-26-2005
Atterion Atterion is offline
The Dark Knight
Atterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond repute
Oh sure!!!!!!!!!
Set me up with the rookies. I see how you are
Seriously though I'm on this, and working with Torito as we speak. And I just want to call him Dorito
Torment, Violent Aggression,
Systematic State of Oppression.
The Heretics, All Swing From The trees,
Cast To Hell, With Their Disease. DARKENED
MIDI guru needed elect drums soundfonts wfaraoni MIDI Mania 9 06-19-2006 10:36
Korg Triton into Digi 002 Rack cayotic MIDI Mania 20 06-26-2005 19:49
Quick Question sarkastic714 MIDI Mania 1 09-21-2004 06:21
Midi drum stuff for the hard of thinking: Alan McGuinness Cakewalk / Sonar Forum 3 12-12-2002 12:03
MIDI to Audio using a keyboard's sounds - question HomeRec Digital Recording & Computers 7 07-17-2001 19:07
