Old 06-21-2005
TommyJ1112 TommyJ1112 is offline
Newbie
TommyJ1112 has a reputation beyond reputeTommyJ1112 has a reputation beyond reputeTommyJ1112 has a reputation beyond reputeTommyJ1112 has a reputation beyond reputeTommyJ1112 has a reputation beyond reputeTommyJ1112 has a reputation beyond reputeTommyJ1112 has a reputation beyond reputeTommyJ1112 has a reputation beyond reputeTommyJ1112 has a reputation beyond reputeTommyJ1112 has a reputation beyond reputeTommyJ1112 has a reputation beyond repute
Connecting PreAmp to Compressor
Hi,
I am trying to connect my mic (Rode K2) to my PreAmp (The Brick) into my Compressor (RNC) into my Digi002.
Here's where I'm not sure what to do...
The output from the Brick is balanced (XLR). The RNC however only takes in unbalanced inputs. So how do I unbalance my connection so I can use these two peices of gear together?
(I do have a Neutrik Balanced patchbay, is there any way to use that to unbalance the signal?)
Thanks for your help in advance!
Old 06-21-2005
MrBoogie's Avatar
MrBoogie MrBoogie is offline
Senior Member
MrBoogie has a spectacular aura aboutMrBoogie has a spectacular aura about
According to the Groove Tubes website (http://www.groovetubes.com/product.cfm?Product_ID=2084),
you would use an xlr to 1/4" cable to go from the Brick to the RNC. They mention using the Brick going into the effects loop return of a guitar amp which is definitely not balanced.
Old 06-21-2005
Newbie
Ok, maybe this is a silly question, but do they make XLR to unbalanced 1/4" cables? I have a XLR to Balanced TRS 1/4" ... and that is not a good thing going into the RNC.
Thanks for your help!
Old 06-21-2005
MrBoogie's Avatar
Senior Member
good point. I forgot it was wired for the TRS, in/out thing....
I know they do make xlr to 1/4" TS cables because a long time ago I used one to go from my sm57 to my 4track, and it actually worked.
Old 06-21-2005
Mr. Moon's Avatar
Mr. Moon Mr. Moon is offline
Force of Nature
Mr. Moon has a reputation beyond reputeMr. Moon has a reputation beyond reputeMr. Moon has a reputation beyond reputeMr. Moon has a reputation beyond reputeMr. Moon has a reputation beyond reputeMr. Moon has a reputation beyond reputeMr. Moon has a reputation beyond reputeMr. Moon has a reputation beyond reputeMr. Moon has a reputation beyond reputeMr. Moon has a reputation beyond reputeMr. Moon has a reputation beyond repute
Here's the contents of an email I sent to GT's tech support about the same issue. They agreed with it all, I made the patch cable, and have used it successfully.
> Hello,
> I was wondering how I should connect my Brick preamp to my FMR RNC
> compressor so that I don't damage either piece of gear. FMR's product FAQ
> said that I should connect the brick to the RNC *only* via an unbalanced
> connection. It stated that I should go from the balanced output (of the
> brick) to an unbalanced XLR-1/4" patch cable, then into the unbalanced
> input of the RNC.
> FMR's FAQ here: http://www.fmraudio.com/faq.html
> The FAQ strongly recommended that I confirm that this will not damage the
> gear which I'm plugging into the RNC via this method, which in this case
> is the Brick. Here is how they suggested the patch cable should be wired:
> RNC 1/4" Plug______XLR Signal/Pin #
> Tip.....................->.....HOT (pin 2)
> Sleeve...............->.....COLD (pin 3)
> Sleeve...............->.....Ground
> Is this correct? Please advise.
> Thanks!
Hope this helps!
-mr moon
Intel Core 2 QUAD Q6600
Intel D975XBX2
2 GB OCZ 800MHz DDR2
RME FireFace 800
Windows 64 Pro
Old 06-21-2005
mr.rich mr.rich is offline
Senior Member
mr.rich will become famous soon enough
youl be fine i go from a pre to it alot via a bay. doesnt seem to run it hot. only time ive had a prob doin this was tryin to go unbalanced into a 1176 and it just wouldnt push it.
Old 06-23-2005
Newbie
Thanks for the help, guys!
I was able to find an unbalanced XLR to TS 1/4" cable, like you suggested MrBoogie, and that worked out pretty well. Hosa makes some cables already wired like this. I think the Hosa cable will work well enough for me, until I can learn more about wiring my own cables using some better components, like you mentioned Mr. Moon.
Old 06-23-2005
earworm's Avatar
earworm earworm is offline
it might be true...
earworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond repute
ok, now to hijack the thread;
i'm thinking of getting me a brick + dbx 160x for vocals,
does anyone think this will be an upgrade from my symetrix 528 ?
i find the 528 nice for recording vocals, but it just isn't superquiet,
you can get some hissing if you push the volume, besides that it works very nice, so i just wonder,
is there anyone out there with this signal path? brick-160x ?
would love to hear some thoughts on this,
thanks,
earworm
...listen...
Old 06-23-2005
SpiderM69 SpiderM69 is offline
Newbie
SpiderM69 is on a distinguished road
I just went through this with my RNC. Redco (www.redco.com) makes cables that are TS <-> XLR. I had them make me up the equivalent of Mogami Gold, although they have various options. Good company to deal with (and no, I don't work for them).
Cable for connecting preamp to audiophile 2496 NolensVolens Digital Recording & Computers 2 07-21-2004 16:41
Need some help setting my compressor please cjacek The Rack 2 05-26-2003 04:26
Compressor Preamp ? bullyhill The Rack 15 01-23-2003 06:31
preamp or compressor mentil69 The Rack 5 01-06-2003 18:32
preamp vs. dynamic mic jungkang Microphones 7 08-02-2001 21:10
