Old 06-21-2005
thecugga thecugga is offline
Junior Member
thecugga is on a distinguished road
metronome in sonar 4 PE is getting recorded as well
Hi,
i just started using sonar 4 producer edition and when i try to use the metronome for a click track sonar records the metronome clicks as well. i am using shitty realtek integrated audio, which i am thinking is the problem.
i am getting the m-audio delta 44 interface soon. will this solve my problems with the metronome? or is this just how the metronome is meant to work in this program???
i am recording thru a mixer hooked into the line in of the card right now. also, if im playing a song on my computer, even if the speakers arent hooked up and you cant hear anything, it'll still record the sound. is this just because of the integrated audio card? and eveything going thru the card is recorded? meaning that when i upgrade to the delta 44 that my problems with the metrnome will be solved as well???
i can get a decent deal on a digital metronome from the person selling me the card, so i am trying to figure out whether its necessary to purchase a digital metronome or if the one in sonar will do the trick??
please help
thanks
Old 06-21-2005
guttadaj guttadaj is offline
Perpetual Newbie
guttadaj is on a distinguished road
I have an M-Audio Audiophile 2496 and use Sonar 4 Studio edition. I have no such problems with the audio metronome - I love it! It sounds like you probably have your integrated audio card set to record in something equivalent to a "What U Hear" mode. Anyway, you should be golden with the Delta - no need to buy a separate metronome as Sonar's should work just fine.
-Jeff
Old 06-21-2005
travelin travis travelin travis is offline
Banned
travelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond repute
are you sure that the metronome is'nt setup to play during recording and playback? just in case, on the metronome toolbar go to metronome settings (2 icons to the right of the speaker icon) and make sure playback is'nt checked.
if the metronome toolbar is'nt in view, go to view, toolbars, check metronome, then repeat the above steps.
if that's not the case, is the metronome sound being leaked into a mic?
just some suggestions. I would'nt think that this would be a problem with your sound card.
Old 06-22-2005
Strryder Strryder is offline
Force of Nature
Strryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond repute
Go to the Cool Edit Pro forum and read the sticky called "when track one records onto track two", and make sure that you are only selecting the input source that you are actually using, (windows mixer, options, recording), as your recording source.
If that isn't the problem, then you must be creating a recording "loop" with the way you have things routed to/from your external mixer.
no metronome in sonar dwdruman Cakewalk / Sonar Forum 4 10-29-2004 01:20
Question: Sonar 3 Metronome Volume Low slayerment Cakewalk / Sonar Forum 3 06-27-2004 15:52
Sonar Update 2.2 out February 2. moskus Cakewalk / Sonar Forum 18 01-31-2003 11:37
Running VS 880 XVpanded into SONAR via spdif ZPphreak Roland, Boss, VS Series Forum 1 12-14-2002 04:56
Sonar 2 XL: Delta 1010 will not playback songs recorded with SB Live! MrLip Cakewalk / Sonar Forum 12 08-17-2002 12:55
