Old 06-20-2005
Monkey Allen's Avatar
Monkey Allen Monkey Allen is offline
creeping moses
Monkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond repute
Capturing Audio onto HD
What do you do?
Capture/ record audio directly to your main HD or capture/ record it to a slave HD?
I know a lot of people use a slave drive to hold their audio files. But I never know if they mean that they use it as the drive that is written to or if they use the slave HD as the drive where project files and audio files eventually get stored once they are finished mixing and mastering.
thanks
Old 06-20-2005
bennychico11's Avatar
bennychico11 bennychico11 is offline
bennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond repute
written and stored on a separate drive
generally you want to keep the audio drive separate from your system drive (which will contain the audio program you're using too). this way theoretically will result in less errors. If you had everything on one drive you'd be streaming info from the OS, the program you're using AND however many tracks (with a big session, this can be a lot). This can take up a lot of throughput on your drive and slow things down. and if you're writing to a drive...you don't want to slow things down otherwise it can resul in errors.
www.redlabaudio.com
Old 06-20-2005
mshilarious's Avatar
mshilarious mshilarious is offline
Faithful Departed
mshilarious has disabled reputation
Originally Posted by Monkey Allen
What do you do?
thanks
I'm not a computer jock but the standard advice is to record on a second HD that is master on the secondary IDE channel.
Old 06-20-2005
creeping moses
Thanks everyone. I tried to set up a 2nd sata drive acting as a slave to another sata where the OS was. However, I ran into problems with the SP2/ firewire conflicts and I ended up with "Delayed Write Failed" messages. The problem was that SP2 glitched firewire ports by restricting the amount of data that could be captured by 1/8th of real capabilities.
My audio card is a Presonus Firebox (firewire)
Anyway, I have since found a hotfix which addresses this SP2/ firewire problem, but I haven't been game to set my software to capture the audio to the slave. I figured that if SP2 and firewire were having conflicts, then it would be even worse trying to feed that firewire audio signal into a slave drive.
Anyway, it seems to be capturing no problem to my main 160gig drive. So, maybe one day soon I will reconfigure the capture back to my slave and see how I go.
Manning 1 Questions about making a drum pad onlydude MIDI Mania 14 04-20-2005 16:35
How do I... SnoboarderX27 Recording Techniques 9 03-28-2005 02:17
MIDI to Audio in DP 4.5 - Techniques and Levels? RhythmRmixd MIDI Mania 2 12-27-2004 14:06
Difference between SEND and INSERT in cubase Gabriel Sousa Digital Recording & Computers 4 01-27-2003 12:48
exporting audio vs mixdown audio Waysid Cakewalk / Sonar Forum 3 02-27-2001 14:48
