Re-setting Sonar-s VST plugin directory
Question: I was having some problems installing Atmosphere and when Sonar couldn't find it, Sonar asked me if i wanted to delete reference to it from its schedule/memory/register. Stupidly, I checked "yes".
So now, with Atmosphere nicely installed correctly, no matter how I run the vst wrapper, Sonar refuses to acknowledge that Atmosphere exists. Saving a fresh install of Sonar as a last resort, can anyone assist with a suggestion as to how I can instruct Sonar to refresh its memory so it can see my new Vsti? |
Under Start Menu -> Programs -> CakeWalk VST Adapter 4 open CakeWalk VST Adapter 4
That will give you the options to re-scan the VST directories.
The fact that no one understands you doesn't mean you're an artist... |
I guess what I'm not getting is when you say " Sonar has removed all references to Atmoshere".....
What is this atmospher?
Have you tried running the Cakewalk Plugin Manager?
Okay, fixed the problem
Cakewalks distributor in the UK wasn't much help - told me the problem was most likely with Atmosphere and didn't know how to edit the registry in win xp. (Fraserhutch, Atmosphere is a Vsti plug in from Spectrasonics )Anyway, I identified the Atmosphere plug in alpha numeric identifier from CAkewalks wrapper, ran regedit, surfed to HKEY_CURRENT_USER > CAkewalkMusic > Excluded plugins and then saw the registry entry alphanumeric that the wrapper had detailed. Deleted the line entry, re-ran the wrapper, booted HS2004 and hey Presto! Easy when you know how ![]() |
In Sonar 3.0, I think it came bundled with the software. Anyway, it shows up on the Tools menu of my copy of S3. Not sure about S4.0. Note to fraserhutch: you were referring to the VST adapter. That is not the same thing as the plug-in manager. The plug-in manager (which works for DX and VST) allows you to determine which plug-ins show up in Sonar, and helps you decide how you want to organize them. |
#12
However, regardless of that point, the plug-in manager is not an installer. It is a program that helps you manage the plugins you already have installed. |
#13
#14
Studio version, on account that you persuaded me some years back to invest in wavelab and waves gold Thinking about it, you have a lot to answer for Anyway, its all quite academic because I only have HS2004 For now ![]() |
#15
Hey Mike, how come you only got a rep power of 9, I have 6 and Big bear has 12 when there are massive differences in posting numbers.
So it must be based on quality of posts then ![]()
ASUS P4PE MoBo/vs 1007 BIOS/2.4 Gig P4 CPU/2 Gig RAM/Win XP/Delta 66+omni /SP-5B monitors/Sonar 7 PE/Trilogy/Atmosphere/Stylus RMX/Absynth3/Kontakt2/BFD XFL/BFD Percussion/BFD Jazz and Funk/POD XT/Z3ta+/Rapture/Lounge Lizard/Akoustik Piano /Latigo/Darbuka |
#16
#17
Where is the plugin manager in Sonar 4 Producer?
#18
#19
I was incorrect (a rarity indeed ) in my first post about it being bundled with 3.0. I'm pretty sure it is only available as a download. |
#20
#21
Mike, plugin manager is only available to Sonar users, not us lesser beings that use HS2004
#22
I just posted my details and d/loaded the program - version 1.0.Now all I have to do is figure what help it will be to me Actually, I can see that excluding all my video and ancillary sound/graphic fx that can't be used with sonar can be excluded, so thats handy. And I can also check to see which VSTi is also DXi enabled. Opens up in Tools>Sonar Plug in manager ![]()
| Upgrade: SONAR 3 Studio Edition $79 bucks | RAPD | Cakewalk / Sonar Forum | 15 | 12-22-2003 19:03 |
| Encoding Sonar MP3s for free | garrigus | Cakewalk / Sonar Forum | 2 | 11-12-2002 18:47 |
| Money back garuntee on Sonar upgrade | neirbo | Cakewalk / Sonar Forum | 0 | 04-10-2002 12:37 |
| Sonar reverb setting and saving to midi | mhuang | Cakewalk / Sonar Forum | 1 | 03-28-2002 07:38 |
| SONAR + DIO 2448 soundcard = my headache | mime rifle | Cakewalk / Sonar Forum | 0 | 10-25-2001 11:15 |
