Old 06-17-2005
Nick The Man's Avatar
Nick The Man Nick The Man is offline
SOUND
Nick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond repute
what to do with a pre
so you take your mic and plug that into your mic preamp (we'll use the SP VTB for example) so you plug it into the XRL input and then from there do you take your 1/4" outputs to the mixer or just straight into the recording device??????
thank you in advance
Old 06-17-2005
HangDawg's Avatar
HangDawg HangDawg is offline
bUnGhOlIo
HangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond repute
Shortest path possible would be best. Straight to the recorder. Unless you need to go through the mixer for monitoring or other purpose.
http://www.garagerecording.com/images/lava22.gif
SELECT W.People
FROM tbl_world W
WHERE W.Clue = TRUE
NO RECORDS RETURNED
Old 06-17-2005
tmix tmix is offline
1K Silver Member
tmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond repute
Exactly!
What HangDog said.
Tom Menikos
T-Mix Studios
Mansfield Texas
WWW.tmixstudio.com
Old 06-17-2005
SOUND
alright thanks guys!
Old 06-17-2005
Kevin Deschwazi's Avatar
Kevin Deschwazi Kevin Deschwazi is offline
Brittunculus
Kevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond repute
If you did want to go through the mixer (although as said it's best not to if you don't need to) then you'd use the line in and not the mic input.
The ULTIMATE Entry-Level Mic Pre Poll... :op WATYF Microphones 349 09-04-2009 21:06
Review – Studio Projects VTB1 mic pre Dot The Rack 68 07-21-2007 21:29
nanocomp better than art tube mic pre? trdn1 Other Equipment and Reviews 2 03-11-2006 12:22
Groove Tubes " The Brick" Mic pRe cradlefish The Rack 16 12-06-2004 17:07
POD questions Richard Monroe The Rack 4 01-26-2003 21:15
