Old 06-17-2005
awx awx is offline
Junior Member
awx is an unknown quantity at this point
Now i'm freaking out.
Hi guys,
I'm full freaking out as i have just purchased an M-Audio firewire 410 off ebay from a U.S. seller and I'm in Australia.
Problem is I am being sent a U.S. version that runs 110V as opposed to a Euro version that runs 240V.
My question is.....
- is it a simple matter of just getting pin converted to change it to the Australian wall socket connector?
- or will i have buy the 240v version?
-or is it a simple matter of getting a different power pack?
- or am i stuck having to use it off bus power the whole time..... (I only have a 4 pin firewire connector on my laptop so i will have to get a 6 pin PCMCIA firewire card?
Any help is greatly appreciated as i have no idea where this leaves me
Thanks
awx
Life. Its just a Ride
Old 06-17-2005
Tifstorey's Avatar
Tifstorey Tifstorey is offline
Guinea Pig
Tifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond repute
you just need an adapter mate. either get one from eBay? Any electrical goods shop... or you could even call M audio, explain that youve lost yours, and you need another one. they will send you one out.
Good luck mate, and dont panic too much!
Old 06-17-2005
awx awx is offline
Junior Member
What do you mean a pin converter or a voltage transformer?
Old 06-17-2005
Tifstorey's Avatar
Guinea Pig
is the cable built into the back of the 410? if so, you will need a voltage transformer. basically an adapter to fit on the end that will give it more V. Im sure they will sell them in electrical shops around you?
Take it in to them if you can and explain to the owner, he/she should know their stuff and sell you the right kinda adapter.
Good luck man.
peace
Old 06-17-2005
awx awx is offline
Junior Member
Nah it is just a pin connector...... i just need to make sure that 110v is running to the 410 that is all .....
Thank for your help
awx
Old 06-17-2005
Tifstorey's Avatar
Guinea Pig
Ok, hope you get it sorted mate.
Good luck!
Old 06-17-2005
awx awx is offline
Junior Member
will this do the job???
http://www.dse.com.au/cgi-bin/dse.st...uct/View/M1155
Old 06-17-2005
Tifstorey's Avatar
Guinea Pig
I would think so mate yeah, why not send them a link to your unit and ask them if it will? They should be able to find out from the electrical spec?
Old 06-17-2005
DonF's Avatar
DonF DonF is offline
Call Me "Grandpa"
DonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond repute
It seems to me that all you need is a "wall wart" that takes in 240VAC and puts out 9VAC, 1000mA, having the correct connectors on both ends. I wouldn't mess with 240/120 converters except as a last resort.
Old 06-17-2005
awx awx is offline
Junior Member
So regardless of whether i am running 240v from the wall the wall wart will convert it to the 9 vac that i need?
So is true to say the only difference between the US version and the EURO version of the 410 firewire is the connector on the end of the power pack?
Old 06-17-2005
DonF's Avatar
Call Me "Grandpa"
The wall wart is different. It has an input voltage of 240VAC instead of 110VAC. Other than that, the units should be identical.
My arm freaking hurts pdadda Keyboards and Sound Modules 12 08-25-2004 10:17
Too freaking happy! KaBudokan MP3 Mixing Clinic 1 03-16-2002 11:09
